The PB110 Sunny 1400 gearbox looks similar to the regular 1200, and may even bolts in its place. However all the parts are different. The internal parts are from Datsun 510.
- 3-bolt frame-to-gearbox mounting looks same as B110
- But uses Datsun 510 gearbox arm, probably requires use of larger B210/B310 cross rod
- The ratio may be different than B110
- PB110: 3-bolt housing cover, 3-bolt column/worm shaft flange
- B110: 4-bolt housing cover, 4-bolt column/worm shaft flange
The GL and GX models were fitted with collapsible column and separate gearbox.
NOTE: collapsible column with separate gearbox
Part Number Overview
Applied Model Codes use by the gearbox parts:
- H25 part number are generally unique to PB110
- 041: Datsun 310
- 165: Datsun P411
- 322: Nissan 30 [Cedric, circa 1960]
- 712: Nissan H31 ('65) [Cedric 1900]
- A06: Datsun 510S ('69)
- 210: Datsun 510-S [Standard trim]
- 220: Datsun P510-TK [4-speed, Twin Carb]
- 261: Datsun D510-T
Rigid Steering Gearbox & Column
- 48010-H2551 GEAR ASS'Y-steering DX [rigid, with integral column]
- 48150-H2500 WORM ASS'Y-steering DX
- 48103-21000 SHAFT-sector, steering ALL [Datsun 510 USA OP] $182.95 USD
- 89-11250-1 NUT
- 89-15150-1 WASHER-lock
PB110 gearbox parts all virtually all different from B110
48010-H2551 GEAR ASS'Y-steering DX 48011-21000 HOUSING COMP.-steering 48127-16500 BEARING COMP.-needle (2) 9-33330 PLUG-expansion 48137-16500 SEAL-oil, sector shaft 48201-16500 COVER-sector shaft 48204-16500 GASKET-sector shaft cover 48064-16500 PLUG 81-20818-1 BOLT (3) [fixing cover] 89-15138-1 WASHER-lock (3) [fixing cover] 48029-71200 SHIM-worm bearing (0.762t) 48030-71200 SHIM-worm bearing (0.254t) 48031-71200 SHIM-worm bearing (0.127t) 48032-71200 SHIM-worm bearing (0.050t) 48035-71200 "O" RING 48250-H2500 JACKET COMP.-steering 48054-32200 BEARING ASS'Y-steering column 81-20820-1 BOLT (3) [fixing column to gearbox housing] 89-15138-1 WASHER-lock (3) [fixing column to gearbox housing] 48190-21000 BEARING ASS'Y-warm gear (2) 48150-H2500 WORM ASS'Y-steering 48103-21000 SHAFT-sector, steering 48135-32200 SCREW-adjusting, sector shaft 48233-21000 NUT-lock, adjusting, screw 48129-71200 SHIM-adjusing, sector shaft (1.600t) 48130-71200 SHIM-adjusing, sector shaft (1.575t) 48131-71200 SHIM-adjusing, sector shaft (1.550t) 48132-71200 SHIM-adjusing, sector shaft (1.525t) 89-11342-1 NUT (fixing steering wheel) 89-16242-1 WASHER-tooth lock (fixing steering wheel) 48502-A0600 ARM-steering gear 89-11250-1 NUT (fixing gear arm) 89-15150-1 WASHER-lock (fixing gear arm) 48058-16500 LID-jacket tube (rubber) 81-12642-1 BOLT (fixing steering gear) (3) 89-12642-1 NUT (fixing steering gear) (3) 89-15442-1 WASHER-plain (fixing steering gear) (3) 48324-H2500 CLAMP-steering, upper 48326-H2500 CLAMP-steering, lower 48325-04100 PACKING-steering post 01121-00051 BOLT (2) [fixing steering post]
Collapsible Steering Gearbox
- 48011-21000 HOUSING COMP.-steering ALL [RHD]
- compare to Datsun 510 USA 48011-21400 OPTION [LHD]
- 48010-26150 GEAR ASS'Y-steering GL,GX [collapsible with U-joint]
- 48150-26100 WORM ASS'Y-steering GL,GX $212.82 USD
