Steering Linkage
Revision as of 06:44, 20 June 2011; view current revision
Category: Steering System
The Datsun 1200 uses a tradition recirculating-ball Steering Gearbox with behind-the axle linkage.
Also see Steering Gearbox
[hide]
Terminology
  • 1. Idler Arm. This bolts to the subframe rail on opposite side from the steering gearbox
  • 9. Steering Gear Arm, a.k.a. "Pitman arm"
  • 19,20. Side Rod, a.k.a. "tie rod". Left and right hand differ
  • 12. Cross Rod, a.k.a. "drag link" or "center link"
  • 21, 22, 23, 24. Side Rod Socket Ass'y a.k.a. "tie rod ends". There are four separate parts with left and right-hand threads. Each "socket" has a "ball stud", which is similar to a Ball Joint.
The six ball studs have a Filler Plug on the bottom of each. Replace it with a grease fitting and fill it during each periodic "lube, oil and filter".
Power Steering
See Steering Gearbox Swaps
Idler Arm
Idler Arm RHD
48530-H1000 ASSY-IDLER STEERING [RHD]
Idler Arm LHD
* 48530-H1600 ASSY-IDLER STEERING [LHD]
* http://www.rockauto.com/catalog/x,carcode,1208483,pgname,Steering
* TRW 18778 through 7/72
Idler Arm Bushing
Idler Arm Repair Kit (2 bushes, washers & lock nut)
ステアリング アイドラ アーム
Cross Rod
The Cross Rod is also known as center link or drag link.
RHD measurements
  • about 21-1/16 x 18-5/8
  • about 535 mm x 473 mm
B10
  • B10: 48545-18001 BUSHING-idler shaft
  • 48560-H6200 ASSY-CROSS ROD LHD USA
  • 48560-H2500 ROD ASS'Y-CROSS PB110, PB210
  • 48560-H5025 ROD ASS'Y cross steering RHD JDM
    RHD B210 bottom, B110 top:
    B210 has a kink for clearance
B310 (and A10)
  • 48560-W5725 ROD ASSY-CROSS,STEERING North America B310, A10
  • 48560-W5025 ROD ASSY-CROSS JDM B310, A10
Side Rods
Side Rod also known as Tie Rod, consists of a threaded shaft and two ball-socket "ends".
Side Rod Ends also known as Tie Rod Ends
Inspect, and replace if bent
B110, B120 [NOTE: B210 differs]
  • 48510-H1025 ROD ASSY-SIDE RH 7210- $134.33 USD
    • supercedes 48510-H1002 ROD KIT-side (R.H.) (from '72-10)
  • 48630-H1025 ROD ASSY-SIDE LH 7210- $134.33 USD
    • supercedes 48630-H1002 ROD KIT-side (L.H.) (from '72-10)
  • 48510-H1001 ROD ASS'Y-side (R.H.) (up to '72-9) $80.28 USD
  • 01227-00011 NUT (4) [also B210]
  • 08921-32010 PIN-cotter (4) [also B210]
PB110
  • 48510-A0600 ROD ASS'Y-side (R.H.) (up to '72-10)
  • 48630-A0600 ROD ASS'Y-side (L.H.) (up to '72-10)
  • 48510-U0100 ROD ASS'Y-side (R.H.) (from '72-11)
  • 48630-U0100 ROD ASS'Y-side (L.H.) (from '72-11)
  • 01272-00031 NUT (4) PB110 or 89-11042-1
  • 08901-32510 PIN-cotter (4) PB110, PB210
PB210
  • 48510-H5800 ROD ASS'Y-side (R.H.)
  • 48630-H5800 ROD ASS'Y-side (L.H.)
  • 01227-00061 NUT (4) PB210
NOTE: Cotter pin & Nut are same as used with Steering Gear Arm & Idler Arm (total 6 per car)
Side Rod Bar
Aka Tie Rod End Adjusting Sleeve. The flat in the middle is for a wrench to hold it stationary while you thread on the ends. The ends are left- and right-threaded.
  • 48512-H1001 BAR-SIDE ROD
  • ACDELCO 45A6021 or 88910767
Inner Ends
Inner ends are curved
Inner RIGHT
  • 48521-H1001 ASSY-SOCKET SIDE ROD RH INNER
  • McQuay-Noriss ES2620X
  • Raybestos 4011324
  • ACDELCO 45A0324 or 88910158
Inner LEFT
  • 48641-H1001 ASSY-SOCKET SIDE ROD LH INNER
  • Raybestos 4011327
  • ACDELCO 45A0327 or 88910161
Outer Ends
Outer ends are straight.
Outer RIGHT
  • 48520-H1001 ASSY-SOCKET SIDE ROD RH OUTER
  • TRW ES488L -0772
  • Raybestos 4011167
  • ACDelco 45A0167 or 88910001 $18.94
Outer LEFT
  • 48640-H1001 ASSY-SOCKET SIDE ROD LH OUTER
  • TRW ES488R -0772
  • Raybestos 4011168
  • ACDelco 45A0168 or 88910002 $18.95
