E-Series Distributor
Revision as of 07:07, 17 June 2011; view current revision
[hide]
Vehicles
JAPAN MARKET E-Series vehicles
B11: 8110-8701 Sunny E15
M10: 8208-8701 Prairie E15S
N12: 8205-8701 Pulsar E15S+E15E
N12: 8305-8701 Pulsar E15T
VB11: 8210-8701 AD Van E15S
USA MARKET
B11: 0282-0882 Sentra E15S
B11: 0882-0187 Sentra E15S+E16S
N10: 1081- 310 E15S
N12: 0882- Pulsar E16S
N12: 0283-0784 Pulsar E15ET
ER MARKET (worldwide, non-Japan, RHD market)
B11 EUR 0382- E15S
B11 EUR 0385-0187 E16S
M10 EUR 0982-0187 E15S
N10 EUR 1081- E15S
N12 EUR 0482- E15S
N12 EUR 0682- E15ET
N12 EUR 0685- E16S
Types
D4P
D4P no visible ignition parts, no vacuum advance
E15ET
E16I
ROUND
ROUND TYPE IGNITION (on some E15E)
* 22020-15M10
** GM/MAZDA/NISSAN SMP LX117
EI
EI TYPE IGNITION
Ignitor/HEI Transistor
* Nissan 22020-G5111 from Vanette Distributor
** FORD E8BZ212A297A/E92Z12A297A/F0212A297A
** MAZDA F82918V20
** MITSUBISHI J007X00671/J007X00871
** MOTORCRAFT DYE524/DYE539
EI 2
Ignitor (Ignition Control Module And Pickup Assembly)
  • 12336248
  • 30120PA0661
  • 30120PH4005
  • 491467401
  • 8942433440
  • 94243344
  • E1922
APPLICATIONS
  • Chevrolet S10/Blazer 1982-1985 1.9/2.0
  • GMC S15/Jimmy "
  • Honda 1980-1990
  • Isuzu 1986-1995
  • Nissan 1983- E-series, CA16DE
  • Subaru 1981-1989
MATCHBOX
MATCHBOX TYPE IGNITION - bolts to outside of distributor body
* 22020-S8002
List
22100-17M01 B11 JDM 8209-8310 E15ET HITACHI
22100-17M02 B11 JDM 8310- E15ET HITACHI
22100-15M11 B11 JDM 8110-8502 E15E.MT MITSUBISHI ROUND
22100-15M13 B11 JDM 8502- E15E.MT MITSUBISHI ROUND
22100-16M10 B11 JDM 8110- E15E.AT MITSUBISHI ROUND
22100-11M00 B11 JDM 8110-8502 E15S.MT-(GL,LT).F5 HITACHI EI
22100-11M02 B11 JDM 8502-8612 E15S.MT-(GL,LT).F5 HITACHI EI
22100-11M03 B11 JDM 8612- E15S.MT-(GL,LT).F5 HITACHI EI
22100-11M00 B11 JDM 8110-8502 E15S.A5 HITACHI EI
22100-11M02 B11 JDM 8502-8612 E15S.A5 HITACHI EI
22100-11M03 B11 JDM 8612- E15S.A5 HITACHI EI
22100-13M00 B11 JDM 8110-[8608] E15S.(GL,LT).F5 HITACHI MATCHBOX
22100-01M01 B11 JDM 8110-8111 E13S HITACHI POINTS
22100-01M11 B11 JDM 8110-8310 E13S MITSUBISHI POINTS
22100-01M12 B11 JDM 8310-8506 E13S MITSUBISHI POINTS
22100-01M14 B11 JDM 8506- E13S MITSUBISHI POINTS
22100-11M00 M10 JDM 8208-8501 S.E15S HITACHI EI
22100-11M02 M10 JDM 8501-8612 S.E15S HITACHI EI
22100-11M03 M10 JDM 8612-8712 S.E15S HITACHI EI
22100-11M05 M10 JDM 8712-8812 S.E15S HITACHI EI
22100-11M06 M10 JDM 8812- S.E15S HITACHI EI
22100-19M01 M10 JDM 8208-8606 V.E15S HITACHI POINTS
22100-19M03 M10 JDM 8606- V.E15S HITACHI POINTS
22100-17M01 N12 JDM 8305-8403 E15T HITACHI D4P82-02 アル コネクタ
22100-17M02 N12 JDM 8403-8507 E15T HITACHI D4P83-02 カク コネクタ
22100-17M04 N12 JDM 8507-8508 E15T HITACHI D4P83-02(A) カク コネクタ
22100-17M06 N12 JDM 8508- E15T HITACHI D4P83-02(B) カク コネクタ [bolt-on connector]
22100-17M14 N12 JDM 8507-8508 E15T MITSUBISHI
22100-17M16 N12 JDM 8508-8609 E15T MITSUBISHI T4T84473 カク コネクタ
22100-17M17 N12 JDM 8609- E15T MITSUBISHI
22100-15M11 N12 JDM 8205-8609 E15E.MT MITSUBISHI T4T83671 ROUND 22020-15M10
22100-15M13 N12 JDM 8609- E15E.MT MITSUBISHI T4T83671B
22100-16M10 N12 JDM 8205-8609 E15E.AT MITSUBISHI T4T83574 ROUND
22100-16M12 N12 JDM 8609- E15E.AT MITSUBISHI T4T83574B 22020-G5110
22100-11M00 N12 JDM 8205-8502 E15S.MT-5F.(TS,D,FC) HITACHI D4R80-08 EI
22100-11M02 N12 JDM 8502-8612 E15S.MT-5F.(TS,D,FC) HITACHI D4R80-08 EI
22100-11M03 N12 JDM 8612- E15S.MT-5F.(TS,D,FC) HITACHI D4R80-08 EI
22100-12M00 N12 JDM 8205-8502 E15S.AT HITACHI D4R80-11 EI
22100-12M02 N12 JDM 8502-8612 E15S.AT HITACHI D4R80-11 EI
22100-12M03 N12 JDM 8612- E15S.AT HITACHI D4R80-11 EI
22100-13M00 N12 JDM 8205-[8610] E15S.5F.(TS,D,FC) HITACHI D4K80-09 MATCHBOX
22100-01M15 N12 JDM E13S MITSUBISHI POINTS
22100-19M01 VB11 JDM 8210-8604 E15S.MT HITACHI POINTS
22100-19M03 VB11 JDM 8604-8805 E15S.MT HITACHI POINTS
22100-19M05 VB11 JDM 8210-8604 E15S.AT HITACHI POINTS
22100-19M06 VB11 JDM 8604-8805 E15S.AT HITACHI D4A86-04 POINTS
22100-52A02 VB11 JDM 8805-8812 E15S.MT HITACHI D4R85-06 EI
22100-52A03 VB11 JDM 8812- E15S.MT HITACHI EI
22100-52A07 VB11 JDM 8805-8812 E15S.AT HITACHI D4R85-07 EI
22100-52A08 VB11 JDM 8812- E15S.AT HITACHI EI
22100-09M12 VB11 JDM 8210-8506 E13S MITSUBISHI T3T20976 POINTS CLIP-ON
22100-09M14 VB11 JDM 8506-8604 E13S MITSUBISHI T3T21476 POINTS
22100-09M15 VB11 JDM 8604-8805 E13S MITSUBISHI T3T21476 POINTS SCREW-ON
22100-75A10 VB11 JDM 8805- E13S.MT MITSUBISHI T4T8409 22020-G5111
22100-75A15 VB11 JDM 8805- E13S.AT MITSUBISHI T4T8409 22020-G5111
22100-21M00 N10 USA 0881- CAL.2HB.E15S.MT.F4 +(CAL.2HB+CAL.4HB+CAL.C).E15S.MT.F5 HITACHI D4R80-14
22100-22M00 N10 USA 1181- (CAL.2HB+CAL.4HB+CAL.C).E15S.AT HITACHI [D4R]
22100-22M00 N10 USA 0881- FED.2HB.E15S.MT.F4 +(FED.2HB+FED.4HB+FED.C).E15S.MT.F5 HITACHI D4R80-13
22100-24M00 N10 USA 1181- (FED.2HB+FED.FED+FED.C).E15S.AT HITACHI [D4R]
22100-21M00 B11 USA 0282-0881 (CAL.2S+CAL.4S+CAL.C+CAL.W).E15S.MT.F5 EI
22100-22M00 B11 USA 0282-0882 (CAL.2S+CAL.4S+CAL.C+CAL.W).E15S.AT EI
22100-23M05 B11 USA 0282-0882 FED.NMPG.E15S.MT EI
22100-23M06 B11 USA 0282-0882 MPG.E15S EI
22100-24M00 B11 USA 0282-0882 (FED.2S+FED.4S+FED.C+FED.W).E15S.AT EI
22100-23M07 B11 USA 0982-0983 E15S EI
22100-32M01 B11 USA 0882-0285 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.AT EI
22100-32M02 B11 USA 0285-0588 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.AT EI
22100-33M01 B11 USA 0983-0285 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.MT.F5 EI
22100-33M01 B11 USA 0882-0983 E16S.(MT.F4+M5.F5) EI
22100-33M02 B11 USA 0882-1286 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.MT.F5 EI
22100-33M03 B11 USA 1286-0588 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.MT.F5 EI
22100-34M00 B11 USA 0882-0983 (FED.2S+FED.4S+FED.C+FED.W).E16S.AT EI
22100-36A00 B11 USA 0983-0885 E16S.MT.F4 +(FED.2S+FED.4S+FED.C+FED.W).E16S.(MT.F5+AT) D4P
22100-36A01 B11 USA 0885-0186 E16S.MT.F4 +(FED.2S+FED.4S+FED.C+FED.W).E16S.(MT.F5+AT) D4P
22100-36A02 B11 USA 0186-0588 E16S.MT.F4 +(FED.2S+FED.4S+FED.C+FED.W).E16S.(MT.F5+AT) D4P
22100-32M01 N12 USA 0882-0285 (CAL.C+CAL.3HB+CAL.5HB).E16S.AT HITACHI D4R82-24
22100-32M02 N12 USA 0285-0986 (CAL.C+CAL.3HB+CAL.5HB).E16S.AT HITACHI D4R82-24
22100-32M03 N12 USA 0986- (CAL.C+CAL.3HB+CAL.5HB).E16S.AT HITACHI D4R82-24 W/VENT
22100-33M01 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.MT.F5 HITACHI D4R82-12
22100-33M01 N12 USA 0882-0285 (CAL.C+CAL.3HB+CAL.5HB).E16S.MT.F5 HITACHI D4R82-12
22100-33M02 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.MT.F5 HITACHI D4R82-12
22100-33M02 N12 USA 0285-0986 (CAL.C+CAL.3HB+CAL.5HB).E16S.MT.F5 HITACHI D4R82-12
22100-33M03 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.MT.F5 HITACHI D4R82-12 W/VENT
22100-33M03 N12 USA 0986- (CAL.C+CAL.3HB+CAL.5HB).E16S.MT.F5 HITACHI D4R82-12 W/VENT
22100-34M00 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.AT HITACHI D4R82-13
22100-34M01 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.AT HITACHI D4R82-13
22100-34M02 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.AT HITACHI D4R82-13 W/VENT
22100-36A00 N12 USA 0983-0885 (FED.C+FED.3HB+FED.5HB).E16S HITACHI D4P83-03
22100-36A01 N12 USA 0885-0486 (FED.C+FED.3HB+FED.5HB).E16S HITACHI D4P83-03D
22100-36A02 N12 USA 0486- (FED.C+FED.3HB+FED.5HB).E16S HITACHI D4P83-03E W/VENT
22100-27M00 N12 USA 0283-0983 E15ET HITACHI D4P82-06
22100-27M01 N12 USA 0983-0784 E15ET HITACHI D4P82-03
22100-27M02 N12 USA 0283-0983 E15ET HITACHI D4P82-06B
22100-27M03 N12 USA 0983-0784 E15ET HITACHI D4P82-03B
22100-27M04 N12 USA 0283-0983 E15ET HITACHI D4P82-06B W/VENT
22100-27M05 N12 USA 0983-0784 E15ET HITACHI D4P82-03B W/VENT
22100-03A00 B11 EUR 0284-0486 (S+W).E15S.MT
22100-03A00 B11 EUR 0284-0486 (S+C).E13S.MT
22100-03101 B11 EUR 0284-1286 (S+C).E13S.MT
22100-03101 B11 EUR 0284-1286 (S+C).E15S.MT
22100-03A02 B11 EUR 0284-1286 (S+W).E16S.MT
22100-03A02 B11 EUR 1286-0588 (S+C+W).(E13S+E15S).MT HITACHI
22100-03A02 B11 EUR 0284-0486 (S+C).E13S.MT
22100-03A02 B11 EUR 0284-0486 (S+W).E15S.MT
22100-03A03 B11 EUR 1286-0588 (S+C+W).(E13S+E15S).MT HITACHI
22100-03A03 B11 EUR 0284-0486 (S+C).E13S.MT
22100-03A03 B11 EUR 0284-0486 (S+W).E15S.MT
22100-03A04 B11 EUR 1286-0588 (S+C+W).(E13S+E15S).MT HITACHI
22100-03A04 B11 EUR 0284-0486 (S+C).E13S.MT
22100-03A04 B11 EUR 0284-0486 (S+W).E15S.MT
22100-03A04 B11 EUR 0588- E13S HITACHI EI
22100-05M02 B11 EUR 0382-0284 E15S.(MT.F4+MT.F5)+E13S
22100-05M02 B11 EUR 0284-1286 V.(E13S+E15S)
22100-05M04 B11 EUR 0382-0284 E15S.(MT.F4+MT.F5)+E13S POINTS CLIP-ON
22100-05M04 B11 EUR 0284-0588 V.(E13S+E15S) POINTS CLIP-ON
22100-05M05 B11 EUR 0382-0284 E15S.AT
22100-05M06 B11 EUR 0382-028R OPTION.E15S.AT
22100-08A00 B11 EUR 0284-0486 (S+W).E15S.AT
22100-08A01 B11 EUR 0486-1286 (S+W).E15S.AT
22100-08A02 B11 EUR 1286-0588 (S+W).E15S.AT
22100-25M00 B11 EUR 0382-0284 OPTION.E15S.(MT.F4+MT.F5)
22100-25M02 B11 EUR 0382-0284 OPTION.E15S.(MT.F4+MT.F5)
22100-36A00 B11 EUR 0385-0885 E16S HITACH D4P83-03
22100-36A01 B11 EUR 0885-1285 E16S HITACH D4P83-03D
22100-36A02 B11 EUR 1285-0588 E16S HITACH D4P83-03E
22100-P4000 B11 EUR 0284-0486 OPTION(E13S+E15S).MT
22100-P4001 B11 EUR 0486-1286 OPTION(E13S+E15S).MT
22100-P4002 B11 EUR 1286-0588 OPTION(E13S+E15S).MT HITACHI
22100-P4005 B11 EUR 1084-0486 OPTION(E15S.AT)
22100-P4006 B11 EUR 0486-1286 OPTION(E15S.AT)
22100-P4007 B11 EUR 1286-0588 OPTION(E15S.AT) HITACHI
22100-P4008 B11 EUR 1286-0588 OPTION(E15S.AT) HITACHI
22100-P4009 B11 EUR 1286-0588 OPTION(E15S.AT) HITACHI
22100-03A00 M10 EUR 0285-0486 E15S HITACHI D4R83-30 EI
22100-03A01 M10 EUR 0486-1286 E15S HITACHI D4R83-30 EI
22100-03A02 M10 EUR 1286-1187 E15S HITACHI D4R83-30 EI
22100-03A03 M10 EUR 1187- E15S HITACHI D4R83-30 EI
22100-03A04 M10 EUR 1187- E15S HITACHI D4R83-30 EI
22100-12R01 M10 EUR 0982-0285 OPTION.E15S POINTS CLIP-ON
22100-13R00 M10 EUR 0982-0285 E15S POINTS CLIP-ON
22100-13R01 M10 EUR 0982-0285 E15S F/SERVICE POINTS CLIP-ON
22100-13R05 M10 EUR 0982-0285 OPTION.E15S POINTS CLIP-ON
22100-13R06 M10 EUR 0982-0285 OPTION.E15S F/SERVICE POINTS CLIP-ON
22100-P4000 M10 EUR 0285-0486 OPTION.E15S HITACHI D4R83-39 EI
22100-P4001 M10 EUR 0486-1286 OPTION.E15S HITACHI D4R83-39 EI
22100-P4002 M10 EUR 1286-1187 OPTION.E15S HITACHI D4R83-39 EI
22100-P4003 M10 EUR 1187- OPTION.E15S HITACHI D4R83-39 EI
22100-41M01 N10 EUR 0881- E10S HITACHI D410-92 POINTS CLIP-ON
22100-25M00 N10 EUR 0881- E15S.(MT.F4+M5.F5) HITACHI D414-A4 POINTS CLIP-ON
22100-06M00 N10 EUR 0881- E15S.AT HITACHI D414-A5 POINTS CLIP-ON
22100-05M05 N10 EUR 0881- E13S.AT HITACHI D412-B1 POINTS CLIP-ON
22100-05M02 N10 EUR 0881- E13S.(MT.F4+M5.F5) HITACHI D412-A9 POINTS CLIP-ON
22100-08M00 N12 EUR 0684-0486 E10S HITACHI D4R83-38 EI
22100-08M01 N12 EUR 0486-0686 E10S HITACHI D4R83-38
22100-08M02 N12 EUR 0686- E10S HITACHI D4R83-38 W/VENT
22100-41M02 N12 EUR 0482-0584 E10S HITACHI D410-A4 POINTS CLIP-ON
22100-41M04 N12 EUR 0482-0584 E10S HITACHI D4A86-10 W/VENT
22100-03A00 N12 EUR 0684-0486 E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D4R83-30
22100-03A01 N12 EUR 0486-0686 E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D4R83-30
22100-03A02 N12 EUR 0686- E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D4R83-30 W/VENT
22100-03A05 N12 EUR 0684-0486 E13S.AT HITACHI D4R83-36
22100-03A06 N12 EUR 0486-0686 E13S.AT HITACHI D4R83-36
22100-03A07 N12 EUR 0686- E13S.AT HITACHI D4R83-36 W/VENT
22100-05M02 N12 EUR 0482-0584 E13S.(MT.F4+MT.F5) +E15S.(MT.F4+MT.F5) HITACHI A412-A9
22100-05M02 N12 EUR 0482-0584 OPTION.E13S.MT +E15S.(MT.F4+MT.F5) HITACHI A412-A9
22100-05M04 N12 EUR 0482-0584 E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D412-A9 W/VENT F/SERVICE
22100-13R00 N12 EUR 0283-0584 E13S.AT HITACHI D412-B5
22100-13R01 N12 EUR 0482-0584 E13S.AT HITACHI D4A86012 W/VENT F/SERVICE
22100-05M05 N12 EUR 0482-0584 E15S.AT HITACHI D412-B1 POINTS CLIP-ON
22100-05M07 N12 EUR 0482-0584 E15S.AT HITACHI D414-A9 POINTS CLIP-ON
22100-06M06 N12 EUR 0482-0584 OPTION.E15S.AT HITACHI D4149-A9 POINTS CLIP-ON
22100-06M08 N12 EUR 0482-0584 OPTION.E15S.AT HITACHI D4R86-18 W/VENT F/SERVICE
22100-08A00 N12 EUR 0684-0486 E15S.AT HITACHI D4R83-31 EI
22100-08A01 N12 EUR 0486-0686 E15S.AT HITACHI D4R83-31 EI
22100-08A02 N12 EUR 0686- E15S.AT HITACHI D4R83-31 W/VENT EI
22100-25M00 N12 EUR 0482-0584 OPTION.E15S.MT HITACHI D414-A4 POINTS CLIP-ON
22100-25M02 N12 EUR 0482-0584 OPTION.E15S.MT HITACHI D4A86-13 W/VENT F/SERVICE
22100-P4000 N12 EUR 0684-0486 OPTION.E15S.MT HITACHI D4R83-39 EI
22100-P4001 N12 EUR 0486-0686 OPTION.E15S.MT HITACHI D4R83-39 EI
22100-P4002 N12 EUR 0686- OPTION.E15S.MT HITACHI D4R83-39 W/VENT EI
22100-P4005 N12 EUR 0684-0486 OPTION.E15S.AT HITACHI D4R83-40 EI
22100-P4006 N12 EUR 0486-0686 OPTION.E15S.AT HITACHI D4R83-40 EI
22100-P4007 N12 EUR 0686- OPTION.E15S.AT HITACHI D4R83-40 W/VENT EI
22100-27M00 N12 EUR 0682-0584 E15ET HITACHI D4P82-06
22100-27M02 N12 EUR 0682-0584 E15ET HITACHI D4P82-06B
22100-27M04 N12 EUR 0682-0584 E15ET HITACHI D4P82-06C W/VENT
22100-35M00 N12 EUR 0584-0885 E15ET HITACHI D4P82-06
22100-35M01 N12 EUR 0885- E15ET HITACHI D4P82-06D
22100-35M02 N12 EUR 0885- E15ET HITACHI D4P82-06E W/VENT
22100-36A00 N12 EUR 0686-0885 E16S HITACHI D4P83-03
22100-36A01 N12 EUR 0885-0486 E16S HITACHI D4P83-03D
22100-36A02 N12 EUR 0486- E16S HITACHI D4P83-03E W/VENT
