Kicking Plate
Revision as of 08:47, 14 November 2011; view current revision
Category: Body
Kicking plate (キッキング プレート) is the door jamb. Also known as 'scuff plate'. The door sill is the exterior panel. The kicking plate is the interior trim.
Custom
Sources
Bprojects
Nissan Part Numbers
Early
Early plates have no screw holes on the top surface.
Short Doors
  • 74951-H1000 PLATE-kicking, front (R.H.) 4-dr (Sedan/Van), Truck
  • 74952-H1000 PLATE-kicking, front (L.H.) 4-dr (Sedan/Van), Truck
  • 74953-H1000 PLATE-kicking, rear (R.H.) 4-dr (Sedan/Van)
  • 74954-H1000 PLATE-kicking, rear (L.H.) 4-dr (Sedan/Van)
  • 74955-H1000 PLATE-kicking, center (2) 4-dr (Sedan/Van)
  • 85-40412-12 SCREW (8)
Long Doors
  • 74951-H1200 JDM PLATE-kicking, front (R.H.) 2-dr (Sedan/Coupe)
  • 74952-H1200 JDM PLATE-kicking, front (L.H.) 2-dr (Sedan/Coupe)
  • 85-40412-12 SCREW (fixing kicking plate) (8)
Late
From Dec 1971, uses more screws than early plates.
Short Doors
  • 74951-H3100 1972 PLATE-kicking, front (R.H.) 4-dr (Sedan/Van), Truck
  • 74952-H3100 1972 PLATE-kicking, front (L.H.) 4-dr (Sedan/Van), Truck
  • 74953-H3100 1972 PLATE-kicking, rear (R.H.) 4-dr (Sedan/Van)
  • 74954-H3100 1972 PLATE-kicking, rear (L.H.) 4-dr (Sedan/Van)
  • 74955-H3100 PLATE-kicking, center (2) 4-dr (Sedan/Van)
  • 08540-41212 SCREW (24) 4-dr
  • 08540-41212 SCREW (14) Truck (pickup/ute)
Ute sills: 4 side screws, 3 top screws per side (7 per side, 14 per truck)
Long Doors
  • 74951-H3600 1972 PLATE-kicking, front (R.H.) 2-dr (Sedan/Coupe/Van)
  • 74952-H3600 1972 PLATE-kicking, front (L.H.) 2-dr (Sedan/Coupe/Van)
  • 08540-41212 SCREW (fixing kicking plate) (16)
Early to Nov 1971 - 4 screws per side
  • 74951-H1200
  • 74952-H1200
    • 08540-41242 SCREW-TAPPING M4 (4)
Late from Dec 1971 - 8 screws per side
  • 74951-H3600 PLATE-KICKING FRONT RH SEDAN 2DR, COUPE $27.67 USD
  • 74952-H3600 PLATE-KICKING FRONT LH SEDAN 2DR, COUPE $25.17 USD
    • 08540-14242 SCREW-TAPPING M4 (8)
