Part Numbers Index
Revision as of 03:57, 9 January 2012; view current revision
This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine
GROUP 01
001 Engine 001 ENGINE ASSEMBLY (all NLA)
002 Engine Gasket Kit Repair Kit, Regrind Kit
003 Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN
* Timing Chain Cover, Cylinder Liner
004 Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT
005 Emission Control EMISSION CONTROL DEVICE
006 Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD
* flywheel, flex plate, cam bearings
007 Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN
008 Manifold MANIFOLD intake, exhaust
009 Exhaust Tube & Muffler -- See Chassis section below
010 Oil Pump OIL PUMP & OIL STRAINER (oil filter)
011. Carburetor -- see Fuel section below
011A Carburetor, Exhaust Type -- see Fuel section below
011B Carburetor with Auto Choke -- see Fuel section below
012 Air Cleaner -- see Fuel section below
013 Fuel Strainer -- see Fuel section below
014 Fuel Pump -- see Fuel section below
015 Fuel Tank, Sedan -- see Chassis section below
016 Fuel Tank, Coupe -- See Chassis section below
018. Fuel Strainer, Sedan -- see Fuel section below
018A Fuel Strainer, Coupe -- see Fuel section below
019 Accelerator Pedal & Choke Control, see Chassis section below
020 Water Pump WATER PUMP & FAN
021 Radiator -- See Chassis section below
022 Engine Mounting -- See Chassis section below
Fuel
011. Carburetor CARBURETOR(CRANK) with Manual Choke
011A Carburetor CARBURETOR(EXHAUST & EVAPO) with Manual Choke
011B DCH Carburetor CARBURETOR with Auto Choke
012 Air Cleaner AIR CLEANER To May 1971
013 Fuel Strainer -- see 018
014 Fuel Pump FUEL PUMP
018. Fuel Piping FUEL STRAINER & PIPING
Carburetor, Twin
Air Cleaner, GX
Engine Electrical
Engine Control
Accelerator Linkage -- See Chassis section below
Choke Cable -- See Chassis section below
Chassis & Body
Engine Support
009 Exhaust EXHAUST TUBE & MUFFLER
015. Sedan Fuel Tank FUEL TANK(SEDAN)
015A Sedan Fuel Tank FUEL TANK(SEDAN EVAPO)
016. Coupe Fuel Tank FUEL TANK(COUPE)
016A Coupe Fuel Tank FUEL TANK(COUPE EVAPO)
019 Engine Control ACCELERATOR PEDAL & CHOKE CONTROL
021 Radiator
022 Engine Mounting
Power Train
GROUP 03
042 Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER
043 Hydraulic Clutch Pedal CLUTCH PEDAL (Hydraulic Clutch)
044 Clutch Cylinder CLUTCH MASTER CYLINDER
045 Clutch Cylinder CLUTCH OPERATING CYLINDER
046 Transmission Assembly TRANSMISSION ASSEMBLY(4 SPEED)
050 F4W56L Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE To March 1973
050A F4W56A Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE From April 1973
051 F4W56L Gear TRANSMISSION GEAR(4 SPEED) To March 1973
051A F4W56A Gear TRANSMISSION GEAR(4 SPEED) From April 1973
052 F4W56L Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To March 1973
052A F4W56A Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To From April 1973
055A TRANSMISSION CASE & FITTING(AUTOMATIC 3N71B)
055B TRANSMISSION GEAR(AUTOMATIC 3N71B)
055C OIL PUMP, CLUTCH & BRAKE(AUTOMATIC 3N71B)
055D CONTROL VALVE(AUTOMATIC 3N71B)
056 Propeller Shaft PROPELLER SHAFT
057 Differential GEAR CARRIER & GEAR
Axle
GROUP 04
060 Front Axle FRONT AXLE, ROAD WHEEL & TIRE
061 Front Suspension FRONT SUSPENSION(STRUT, SHOCK ABSORBER)
062 Rear Axle REAR AXLE, ROAD WHEEL & TIRE
063 Rear Suspension REAR SUSPENSION(SPRING LEAF, SHOCK ABSORBER)
Brake
GROUP 05
064 Hand Brake HAND BRAKE & HAND BRAKE CABLE
065 Front Drum Brake FRONT BRAKE(DRUM TYPE)
065A Disc Brake FRONT BRAKE(DISC TYPE)
066 Rear Brake REAR BRAKE & WHEEL CYLINDER(FOR FRONT DRUM BRAKE)
066A Rear Brake REAR BRAKE & WHEEL CYLINDER(FOR FRONT DISC BRAKE)
067 Brake Piping BRAKE PIPING(TANDEM)
068 Brake Pedal BRAKE PEDAL
070 Tokico Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM TOKICO) To September 1971
070A Nabco Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM NABCO) To September 1971
070B Tokico Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM TOKICO) From October 1971
070C Nabco Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM NABCO) From October 1971
Steering
GROUP 06
072 Steering Gear STEERING GEAR(COLLAPSIBLE) includes Steering Column
073 Steering Linkage STEERING LINKAGE
074 Steering Wheel STEERING WHEEL & STEERING LOCK
Electrical
GROUP 02
Engine Electrical System
023 Distributor DISTRIBUTOR(CRANK)
023A Distributor DISTRIBUTOR(EXHAUST & EVAPO)
024 Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG
  * includes Alternator Mounting
025A Alternator & Regulator ALTERNATOR & REGULATOR
025C ALTERNATOR(HITACHI)
026 Starter Motor STARTER MOTOR
Body Electrical System
027 Wiring includes Wiring Harness
028 Switch SWITCHES, FLASHER UNIT, HORN & CIGARETTE LIGHTER
* Includes Electrical Unit, Instrument, Switch & Relay
029A Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND)
* includes instrument panel
030. Room Heater & Ventilator
030A Room Heater, Heavy Duty
030C Ventilator
031 Radio & Clock RADIO,ANTENNA & CLOCK
033 Battery & Battery Mounting
034 Wiper & Washer WINDSHIELD WIPER, MOTOR & WIPER BLADE
035 Wiper & Washer WINDSHIELD WASHER
036 Head Light HEAD LAMP
037 Front Combination Lamp Part Numbers FRONT COMBINATION LAMP
038 SIDE MARKER LAMP Side Lighting
039 Sedan Rear Combination Lamp REAR COMBINATION LAMP(SEDAN)
39A Coupe Rear Combination Lamp REAR COMBINATION LAMP(COUPE)
040 License Lamp LICENCE LAMP(SEDAN)
040A License Lamp LICENCE LAMP(COUPE)
041 Room Lamp ROOM LAMP (Dome Light)
Body & Trim
GROUP 07
GROUP 08
Body Panels
Front Grille & Fitting
Rear Body
Bumper
Body Side Moulding & Stripes
Front Body Panels
Cowl & Dash Fitting
Cowl Top & Grille
Front Fender & Hood (bonnet)
Hood Lock Control
Dash, Side & Instrument Panel
Dash Fitting
Glove Box & Ash Tray
Side Panel & Lock
Glass
* Windshield
Roof Panel, Sunvisor & Mirror
Floor Panel & Fitting
Floor Mat, Carpet, Kicking Plate & Console Box
Body
 Body Side Panel & Rear Wheel House
 Body Side Fitting & Moulding
 Body Side Trimming
 Rear Fender & Panel
Glass
 Windshield
 Side Window
 Rear Window
Doors
 Front Door Panel, Glass & Door Ventilator
 Front Door Lock, Regulator & Handle
 Front Door Moulding, Finish & Arm Rest
Trunk Lid & Bumper
Trunk Room Trimming
Front Seat
Rear Seat & Tonneau Cover
Safety Belt & Head Rest
Miscellaneous
GROUP 09
167 Emblem EMBLEM (Badges)
168 Key & Cylinder KEY & CYLINDER
169 Key & Cylinder BLANK KEY
170 Model Plate MODEL NO. PLATE
171 Paint TOUCH-UP PAINT
172 Coolant LONG LIFE COOLANT & N.C.S. SEALER
173 Tool Kit TOOL KIT
173A Special Tool SPECIAL TOOL
175 Leather Top LEATHER TOP (Vinyl Roof)
