Propeller Shaft Part Numbers
Revision as of 05:32, 17 June 2012; view current revision
Categories: Powertrain | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Driveshaft
1 37000-H5100 COMP-SHAFT PROPELLER WITH JOINT SHELL AUTOMATIC 0373- 2 37000-H5100
1 37000-H1001 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1000
1 37000-H1010 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1001
1 37000-H1011 COMP-SHAFT PROPELLER WITH JOINT MANUAL 0972- 0 37000-H1010
1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1011
1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT SHELL MANUAL 0373- 2 37000-H1011
1 37000-H1101 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC
1 37000-H1110 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 0671- 2 37000-H1101
1 37000-H1000 COMP-SHAFT PROPELLER WITH JOINT MANUAL
2 37111-20300 ASSY-YOKE SLEEVE AUTOMATIC
2 37111-18001 ASSY-YOKE SLEEVE MANUAL
3 37117-18000 YOKE-FLANGE
4 37125-18025 ASSY-JOURNAL WITH BEARING (2)
4 37125-H1025 KIT-JOURNAL WITH BEARING (2) 2 37125-18025
5 37130-18000 ASSY-RACE BEARING WITH OIL SEAL (8)
5 37125-H1025 ASSY-RACE BEARING WITH OIL SEAL (8) AUTOMATIC 2 37130-18000
6 37147-18000 RING-SNAP BEARING RACE T=1.48 (8)
6 37148-18000 RING-SNAP BEARING RACE T=1.50 (8)
6 37149-18000 RING-SNAP BEARING RACE T=1.52 (8)
6 37146-18000 RING-SNAP BEARING RACE T=1.46 (8)
7 08120-82210 BOLT-HEX M8X1.25 (4)
7 01111-00061 BOLT-FIX PROPELLER SHAFT (4) AUTOMATIC 2 08120-82210
7 01111-00151 BOLT-FIX PROPELLER SHAFT (4) 3N71B 0371- 2 01111-00061
8 08911-20810 NUT-HEX M8X1.25 (4)
9 08915-13810 WASHER-LOCK M8 (4)
