Key Part Numbers
Revision as of 11:47, 8 August 2016; view current revision
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see:
Main article for usage, photos, cross-reference:
Keys
Ignition Switch
Sunny Truck
A 48563 CASE ASSY-KEY [included with KEY SET 7510-]
 80690-E6000 7510-8910
B 80600M KEY-BLANK
 KEY00-00035 8110- ブランク キ
KEY SETS contain 1-5
80010S KEY SET-CYLINDER LOCK
80010-G1000 CYLINDER SET-lock & key (up to '71-3)
80010-G1201 CYLINDER SET-lock & key (from '71-4)
80010-G1005 CYLINDER SET-lock & key (from '73-9) ^
80010-G1004 7510-7803 LESS STEERING LOCK
80010-G1060 7804-8109 WITH STEERING LOCK
80010-G1900 8110-
01 25150-H1000 SWITCH COMP.-ignition & starter (up to '71-3)
01 25150-H1010 SWITCH COMP.-ignition & starter (from '73-8)
01 25150-G1001 SWITCH COMP.-ignition & starter (up to '73-9) ^
02 80600-H1000 CYLINDER ASS'Y-lock door (R.H.)(up to '71-3)
02 80600-H1001 CYLINDER ASS'Y-lock door (R.H.)(from '71-4) 80600-H1000 2
02 80601-H1000 CYLINDER ASS'Y-lock door (L.H.)(up to '71-3)
02 80601-H1001 CYLINDER ASS'Y-lock door (L.H.)(from '71-4) 80601-H1000 2
03 80590-10600 CLIP-retaining cylinder lock (fixing door lock) 2
04 76960-H1001 LOCK ASS'Y-gas filler lock
04 76960-H4700 CYLINDER SET-GAS FILLER LOCK 7510-
05 76962-18200 CLIP-seating cylinder lock (fixing gas filler)
05 80590-21000 CLIP-RETAINING,CYLINDER LOCK 7510-
06 48700-H1600 LOCK ASS'Y-steering (up to '71-3) (op.)
06 48700-H2010 LOCK ASS'Y-steering (from '71-4) (op.)
06 48700-H2010 7510-7803
06 48700-G1060 7804-8210 S/#48700-H5010
06 48700-G1925 8211-
25150 SWITCH-IGNITION [for non-steering lock]
 25150-G1001 7510-7803
48750 SWITCH-IGNITION [for steering lock]
 48750-H1900 7510-7803
 48750-E4700 7804-
Key & Cylinder
80010-H1901 SET-CYLINDER LOCK & KEY FOR STEERING SEDAN
A 80610-H1000 ASSY-KEY [with holder] NLA
B 80600-H1000 ASSY-CYLINDER DOOR LOCK RH
C 80601-H1000 ASSY-CYLINDER DOOR LOCK LH
D 80590-10600 CLIP-CYLINDER DOOR LOCK
E 84460-H1000 ASSY-CYLINDER TRUNK LID LOCK (SEDAN)
F 80590-10600 CLIP-CYLINDER TRUNK LID LOCK
G 76960-H1001 ASSY-CYLINDER GAS FILLER LID LOCK
H 76962-18200 CLIP-CYLINDER GAS FILLER LID LOCK
I ASSY-LOCK STEERING - See Steering Wheel Part Numbers
80010-H1902 SET-CYLINDER LOCK & KEY FOR STEERING SEDAN 80010-H1901 7
A 80610-H1001 ASSY-KEY [with holder] NLA
B 80600-H1001 ASSY-CYLINDER DOOR LOCK RH
C 80601-H1001 ASSY-CYLINDER DOOR LOCK LH
E 84460-H1001 ASSY-CYLINDER TRUNK LID LOCK (SEDAN)
80010-H1903 SET-CYLINDER LOCK & KEY SEDAN 0471- 0 80010-H1902
I 48700-H1901 ASSY-LOCK STEERING
80010-H1904 SET-CYLINDER LOCK & KEY WITHOUT HOLD SEDAN 0772- 80010-H1903
A 80610-H1900 ASSY-KEY (WITHOUT HOLDER) NLA
80010-H1911 SET-CYLINDER LOCK & KEY FOR STEERING COUPE
E 84460-H1800 ASSY-CYLINDER TRUNK LID LOCK (COUPE)
80010-H1912 SET-CYLINDER LOCK & KEY FOR STEERING COUPE 80010-H1911 7
E 84460-H1801 ASSY-CYLINDER TRUNK LID LOCK (COUPE)
80010-H1913 SET-CYLINDER LOCK & KEY COUPE 0471- 80010-H1912 0
80010-H1914 SET-CYLINDER LOCK & KEY WITHOUT HOLD COUPE 0772- 80010-H1913 2
Blank Key
KEY00-00034 KEY-BLANK FOR VOSS TYPE STEERING LOC
KEY00-00035 KEY-BLANK FOR VOSS TYPE
