Turn Signal Testing
Revision as of 18:19, 14 May 2012; view current revision
Categories: Diagnoses and Corrections | Body Electrical System
Turn Signal (indicators) problems?
Specific bulb doesn't light up
Remove the lens and twist the bulb out. Inspect it for:
* broken filament
* Loose glass
* Corrosion of socket
Clean any corrosion with a wire brush and contact cleaner like Deoxit spray. Be sure to clean the bulb contact metal as well as the light socket.
Replace any damaged bulb.
Indicators Flash Slowly
The flasher units are load-dependent. So if the load is not correct -- for example, if one of the three bulbs is burned out -- it will not operate correctly.
Verify that all three bulbs on the side are OK.
  • Front t/s lamp
  • Rear t/s lamp
  • dash t/s lamp
Indicates Do Not Flash
The flasher units are load-dependent. So if the load is not correct it will not operate correctly.
  • One bulb burned out. See above section.
  • Flasher unit is broken. Test it.
  • Wiring problems. Trace it.
Fuse Blows
Fuse blows when T/S lever is activated left or right. Possible causes include:
  • Incorrect fuse. For a Datsun 1200, the T/S fuse is the 15A Hazard/Horn/Stop fuse. If a smaller fuse is installed, replace with the correct 15A size.
  • The t/s switch (which is inside the steering column) may be loose. Tighten the switch, replace the fuse, and test again.
First Checks
Troubleshooting
