<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Radiator
1 21400-H1900 ASSY-RADIATOR 2 21400-H1002 1 21400-H1003 ASSY-RADIATOR A12 0871- 2 21400-H1900 1 21400-H1002 ASSY-RADIATOR 2 21430-10600 ASSY-CAP 21430-89902 ASSY-CAP PADIATOR A12 1272- 21430-U0100 2 21430-U0100 ASSY-CAP PADIATOR A12 1272- 2 21430-10600 3 21480-18000 HANDLE-DRAIN COCK 4 21481-18000 PACKING-DRAIN COCK 5 08110-61662 BOLT-HEX,WITH WASHER (4) 6 21501-H1000 HOSE-RADIATOR,UPPER 7 21503-H1000 HOSE-RADIATOR,LOWER 8 21506-H1101 ASSY-HOSE,RADIATOR,LOWER,FORHEATER OP. 0970- 21503-H1000,21503-H1100,21504-H1100 9 21503-H1100 HOSE-RADIATOR,LOWER,FRONT FOR HEATER OP. -870 0 10 21504-H1100 HOSE-RADIATOR,LOWER,REAR FORHEATER OP -870 0 11 08723-13600 CLAMP-HOSE (4) 27075-H1000 CONNECTOR-HEATER OP. 27075-27700 12 27075-27700 CONNECTOR-HEATER OP. 13 21475-H2300 SHROUD-RADIATOR UPPER AUTOMATIC 13 21475-H2300 SHROUD-RADIATOR,UPPER FOR HEAVY DUTY S OP. 14 21476-H2300 SHROUD-RADIATOR,LOWER AUTOMATIC 14 21476-H2300 SHROUD-RADIATOR,FOR HEAVY DUTY SPEC OP. 15 08513-51612 SCREW-TAPPING M5 (6) 16 08915-43510 WASHER-PLAIN (6) 17 08963-10510 NUT-SPRING M5 (4)
1973 LB110 USA Parts Catalog
