The Oil Level Gauge, commonly called a Dipstick, differs between early and late A12 engines.
Early type goes directly into block (1967-1973)
Late type goes into a tube which is inserted into block (1973-up)
The H50 gauge is used by B210 and B310 A12/A14/A15/A12A
H10 version is used by front-distributor engines, including A10 and early A12.
B110 USA 11140-H1002 GAUGE-OIL LEVEL A12 11140-H1003 GAUGE-OIL LEVEL A12 0271- 2 11140-H1002
B210 USA 15146-H5001 GUIDE-OIL LEVEL GAUGE 11140-H5001 GAUGE-OIL LEVEL -0275 5 11140-H5001 11140-H7200 GAUGE-OIL LEVEL 0375- 4/5 11140-H5001
FWD
FWD A-series engines use a totally different dipstick.
F10 USA 11140-M3001 ASSY-GAUGE,OIL LEVEL -1076 11140-M4965 ASSY-GAUGE,OIL LEVEL 1076- Y 11140-M3001 11145-M3001 ASSY-GUIDE,OIL LEVEL -1076 11145-M4966 ASSY-GUIDE,OIL LEVEL 1076- Y 11145-M3001 11146-M3000 ASSY-SUPPORT,OIL LEV
Oil Level
Oil should be between H and L marks.
Marks are the same for early (H10) vs late (H50) gauges, even though the overal gauge length differs. That's because they use the same oil pan! The oil level from the bottom of the pan is what is important.
Tube Removal
Use vice-grips and tap it up and out while twisting back and forth.
