Datsun 1200s use a typical paper-type engine air filter in a real metal air cleaner.
Tightening
Tighten the wing nut 3 turns:
Also See
Also see:
- GX Air Cleaner
- Air Intake Systems for upgrades/alternatives, including cold air intakes
Anti-Icing
To prevent ice up in winter (carb icing can over many degrees above freezing), air cleaners for temperate markets have a temperature control. For example, this Japan-market air cleaner:
Automatic Temperature Control
USA models use an Automatic Temperature Control air cleaner for year-round constant inlet temperature. For details, see ATC.
B110 RAW LIST 16500-H1005 ASSY-AIR CLEANER 16500-H1901 ASSY-AIR CLEANER 16500-H1905 ASSY-AIR CLEANER 16500-H1001 ASSY-AIR CLEANER 16500-H1010 ASSY-AIR CLEANER,FOR COLD REGION 16500-H1015 ASSY-AIR CLEANER,FOR COLD REGION 16500-H1910 ASSY-AIR CLEANER,FOR COLD REGION 16500-H1915 ASSY-AIR CLEANER,FOR COLD REGION 16547-52A00 PACKING 16547-H1000 PACKING A6548-M5600 PACKING 16548-18000 PACKING 16568-H1000 ASSY-PACKING 16546-18000 ASSY-ELEMENT,PAPER(VISCOUS) 16523-H1000 INSULATOR 16547-H1000 PACKING 16596-78521 MARK 01237-00011 NUT-WING 16551-08000 NUT-WING 16551-W7000 16551-H1000 NUT-WING 16525-H1001 STUD-AIR CLEANER 16525-H5000 STUD-AIR CLEANER 16573-H1001 SUPPORT-AIR CLEANER 08915-43610 WASHER-RLAIN 08120-61210 BOLT 08915-13610 WASHER-LOCK 16574-H1001 SUPPORT-AIR CLEANER,FRONT 08915-53610 WASHER-PLAIN A6530-70N40 DUCT-COVER TO AIR CLEANER 16530-H1001 DUCT-COVER TO AIR CLEANER 01555-00291 CLAMP-DUCT 08723-14400 CLAMP-DUCT 16590-H1000 ASSY-COVER,EXHAUST MANIFOLD
