Datsun 1200 uses traditional 8mm stem diameter poppet valves.
Maintenance
See Valve adjustment
Stem Oil Seal
See main article: Valve Seals
Retainers
Valve Spring Retainer Keeper (Valve lock)
- Stem diameter 0.252
- 7 degree angle
- SEALED POWER Part # VK215
- BECK/ARNLEY Part # 0230045
- 1976-1979 Buick Opel/Isuzu 1.8
- 1976-1978 Chevrolet Luv/Isuzu 1.8
- 1981-1995 Isuzu, various models
- 1988-1996 Honda/Isuzu 2.6
- Datsun A-series
- Datsun L-series 4 and 6
- Datsun Z-series
- Intake valve head diameter: 35 mm
- Exhaust valve head diameter: 29 mm
- Stem diameter: 8 mm
- Overall length: 103.80 mm
- Seat angle: 45 degrees
- Head style: standard
- Stem end: NG
- 13201-H1000 VALVE-INTAKE [35mm]
- 13202-18000 VALVE-EXHAUST [29mm]
- 13201-H2300 VALVE-INTAKE A12GX [35mm]
- 13202-H2300 VALVE-EXHAUST A12GX [29mm]
Valve Keepers
13209-18000 RETAINER-VALVE SPRING (8) <> 13209-H2300 <> 13209-H2301 13209-H2302 RETAINER-VALVE SPRING (8) 0772- [without O-ring grooves] 13209-H2302 RETAINER-VALVE SPRING (8) B210
13210-73400 COLLET-VALVE 1 (16) A12 (MATERIAL C40) < 13210-U0100 13210-H1000 COLLET-VALVE 1 (16) A12 0272- <> 13210-U0100 13210-U0100 COLLET-VALVE (MATERIAL C1010) B210 > 13210-73400 $1.13 USD
Valve Guides
- 13212-H0112 GUIDE-VALVE INTAKE $8.08
- 13213-H0113 GUIDE-VALVE EXHAUST $8.25
They have a little snap ring to limit the depth inserted in into the head
Others
For other A-series valves (A14, etc) and for competition valves, see: Cylinder_Head_Identification#Valves
