Seat Rails
Revision as of 10:24, 6 January 2013; view current revision
Category: Interior
Seat rails are two kinds: 1) Full adjustable fore-aft sliding 2) Non-sliding (truck passenger side).
[hide]
Unbolt the rails from your seats and bolt them to the new seat.
Left side seat - Coupe & all USA (sedan & coupe)
5185.jpg Seat Slide (aka Seat Rail)
Dimensions - Bolt holes To floor
  • Side to side: 15-11/16 inch
  • Front to back: 12-3/16 inch
USA seat with switch
Left seat slide
Left side Rail
Left-hand Slide
B110 rails in B10 (one-piece slide cut into two)
Truck
Truck driver's seat has an adjustable slide. The passenger seat is a fixed (non-adjustable) "seat riser" bracket.
87500-G1000 SLIDE ASS'Y-driver seat ドライバ- シート スライド -1974
87501-G1000 SLIDE-RH SEAT, OUTSIDE スライド、RH シート アウトサイド
87502-G1000 SLIDE-RH SEAT, INSIDE スライド、RH シート インサイド
87556
87505-G1000 BRACKET ASSY-FRONT SEAT, LH ブラクット アッセンブリ、フロント シートLH
 RISER ASS'Y-seat シート ライザー
 [non-adjustable]
08110-81862 BOLT fixing slide to floor (8)
08915-43810 WASHER fixing slide to floor (8)
08310-82014 SCREW fixing slide to seat (8)
 08310-81812 -7510
08915-13810 WASHER fixing slide to seat (8)
Bride
The famous Bride rails for Sunny Truck
200 mm seat travel fore-to-aft
Late Sunny Truck with converter bulge 1989-up
Left seat Dimensions - Bolt holes To floor
  • Front to back (left side): 12-3/16 inch
  • Front to back (right side) goes 1-1/2 farther back, and 1-1/2 farther forward compared to left side
    • slanted tabs
      15-1/2" at base, 16-1/4" at bottom edges
      front tab: 1-7/16" long
      rear tab: 1-3/8" long
Bride B122 Part Numbers
  • LH: code N030VO type V*1 TTM-L No. 939063
  • RH: code N029VO type V*1 TTM-L No. 939064
  • V type: for Bride full bucket, 30 mm height
  • S type: for Bride reclining seat
  • VF type: for Bride full bucket, no slide (fixed position)
th_000.jpg th_001.jpg th_002.jpg th_003.jpg th_004.jpg th_005.jpg th_006.jpg th_007.jpg th_008.jpg th_009.jpg th_010.jpg th_011.jpg th_012.jpg th_013.jpg th_014.jpg th_015.jpg th_016.jpg th_017.jpg th_018.jpg th_019.jpg th_020.jpg th_021.jpg th_022.jpg th_023.jpg th_024.jpg th_025.jpg th_026.jpg th_027.jpg th_028.jpg th_029.jpg th_030.jpg th_031.jpg th_032.jpg th_033.jpg th_037.jpg th_038.jpg th_039.jpg
シート スリイド シート リイザー ブラケット
