Keys on some 1200s in some markets are matched: One key opens all doors as well as operates the ignition. In other markets there is a different key for the ignition. Also there are left-hand and right-hand keys that otherwise look identical.
Usage
1972 USA Owners manual (see pages 3-4 for key information):
Your Datsun is equipped with an ignition key warning buzzer... the key left in the switch, warning buzzer will warn you of being robbed.
Key Types
All Datsun 1200 used a VOSS double-sided (reversible) Nissan Motor key.
Early models with optional steering lock used a VOSS single-sided oval key for the ignition. So these 1200s used two keys:
The use of one-key-fits-all or two keys depended on the model, year and country:
- USA 1971 sedan: 2 different keys
- USA 1971 coupe: single key
- USA 1972-1973: single key
OVAL KEYS
Early 1200 models with optional steering lock used an oval key for the steering column.
VOSS KEY00-00034/VH1000 single-sided
VOSS-type keys (KEY00-00034) were made by Kanto Seiki under license of VOSS of Germany. These were used starting around 1969. The former WASO type (KEY00-00028) were made by Kanto Seiki under license of WASO of Sweden. The only real difference is the length. The VOSS keys are shorter, which means WASO key won't fit in the VOSS cylinder. The longer VOSS keys should never be used in a WASO cylinder, as it may lock the steering incorrectly.
Nissan Motor Keys
All Datsun 1200 used VOSS Double-sided keys with the "Nissan Motor" text and "N" symbol. These fit the dash ignition switch, doors, boot and fuel filler lid locks. Also, later 1200s with steering lock used this key instead of the oval key.
VOSS double-sided newer shape used in JDM (Sunny Truck) and SADM (Bakkie)
KEY00-00055 Left-hand $8.27 USD (not KEY00-00056 Right-hand)
Ignition Switch
3-position early JDM switch vs later 5-position switch:
Early JDM switches have "Garage" position.
5-position switch vs 4-position switch:
Note addition of ACC position.
1972 USA Owners manual (see page 11):
Portugal market:
Interruptor de ignićāo: Ingition switch
Desligado: Disconnected
Ligado: Connected
Arranque: Start
Standard Switch
Japan-market STD and DX models used a non-locking steering column. The ignition switch was mounted via bracket on the dash.
The key lock cylinder and ignition switch were one unit.
Early units had a 3-connector ignition switch. Later units had four connectors.
Steering Lock Switch
A locking steering column was a Datsun 1200 OPTION for early STD and DX models. It was standard equipment for USA 1200s, JDM GL and GX, and newer JDM 1200 pickups. The body of the steering lock is the same LHD vs RHD and early vs late. But the removable lock barrel, face plate and ignition switch differ.
In all 1200s -- both RHD and LHD -- it bolts to the right side of the steering column.
The body is cast 'KV-1'
'KV-1' cast at the saddle
The actual electrical ignition switch for this type is removable, and bolts to the back of the key cylinder. In other words, the Ignition Switch is not strictly part of the Lock Cylinder, but connects to it.
Fitment of ignition switch into ASSY-LOCK STEERING
Left: 1972-1973 5-position, Right: 1971 4-position
- KEY00-00035 KEY-BLANK FOR VOSS TYPE [reversible]
- KEY00-00034 KEY-BLANK FOR VOSS TYPE STEERING LOCK [single-sided]
- 80010-H1913 SET CYLINDER LOCK & KEY
- 48700-H1900 ASSY-LOCK STEERING
- 48700-H1901 ASSY-LOCK STEERING from 0471
- Reversible key, left-handed
- 80010-H1914 SET CYLINDER LOCK & KEY
- 80010-H1901 SET-CYLINDER LOCK & KEY
- 80610-H1001 ASSY-KEY [with leather holder]
- 80600-H1000 ASSY-CYLINDER DOOR LOCK RH
- 80590-10600 CLIP-CYLINDER LOCK
- 80601-H1000 ASSY-CYLINDER DOOR LOCK LH
- 84460-H1000 ASSY-CYLINDER TRUNK LID LOCK
- 76960-H1001 ASSY-CYLINDER GAS FILLER LID LOCK
- 76962-18200 CLIP-CYLINDER GAS FILLER LID LOCK
- 80010-H1902 SET-CYLINDER LOCK & KEY
- 80600-H1001 ASSY-CYLINDER DOOR LOCK RH
- 80601-H1001 ASSY-CYLINDER DOOR LOCK LH
- 84460-H1001 ASSY-CYLINDER TRUNK LID LOCK
- 80010-H1903 SET-CYLINDER LOCK & KEY
- 80010-H1904 SET-CYLINDER LOCK & KEY
- 80610-H1900 KEY (WITHOUT HOLDER)
USA B210 ignition lock is totally different. Clamps at mid-barell instead of end
- 80610-H6200 ASSY-HOLDER,WITH KEY
- KEY00-00039 KEY-BLANK ST'G LOCK & DOOR
B310
- 48700-U8725 LOCK ASSY-STEERING
- K9810-H9101 KEY SET -0880
- 99810-H9101 KEY SET 0179-
- 99810-H9100 KEY SET -1278
- KEY00-00039 KEY-BLANK,TYPE L
- 80010-H1021 CYLINDER LOCK & KEY SET S-STD, S-DX
- 80010-H2021 CYLINDER LOCK & KEY SET S-GL, S-GX
- 80010-H1821 CYLINDER LOCK & KEY SET Coupe DX
- 80010-H2221 CYLINDER LOCK & KEY SET Coupe GL, GX
- 80010-H1421 CYLINDER LOCK & KEY SET Van
- 80610-H1001 KEY ASS'Y-with holder Coupe
- 25150-H1010 SWITCH COMP.-ignition & starter STD, DX
- 25157-H1001 BRACKET-ignition switch
- 48700-H2020 LOCK ASS'Y-cylinder [steering lock type] Coupe OPTION, S-GL, S-GX
- 80600-H1001 CYLINDER ASS'Y-door lock (R.H.)
- 80601-H1001 CYLINDER ASS'Y-door lock (L.H.)
- 84460-H1801 CYLINDER ASS'Y-trunk lid lock
- 80590-10600 CLIP-retaining, cylinder lock (3)
- 90600-H1401 CYLINDER ASS'Y-back door Van
- 96809-19700 CLIP-retaining [van rear door lock]
- 76960-H1001 LOCK ASS'Y-gas filler lid
- 76962-18200 CLIP-retaining, cylinder lock [small, for filler lid]
JDM B210 steering lock looks like USA B110 type:
- 80010-H5000 CYLINDER LOCK & KEY SET
- 80690-E6000 HOLDER ASS'Y-key
- 48700-H5000 LOCK ASS'Y-steering
- 48700-H5010 LOCK ASS'Y-steering
B120
Key style shown here is '86 up.
Key Set
- 80010-G1000 CYLINDER SET-lock & key (up to '71-3)
- 80010-G1201 CYLINDER SET-lock & key (from '71-4)
- 80010-G1005 CYLINDER SET-lock & key (from '73-9)
- (注) 保 印は48年度保安基進改正に伴う変更および関連変更部品を示します。
- 80010-G1004 KEY SET-CYLINDER LOCK 7510-7803
- 80010-G1060 KEY SET-CYLINDER LOCK 7804-8109
- 80010-G1900 KEY SET-CYLINDER LOCK 8110-
Key Set includes one of the following, and includes a key:
- 25150-H1000 SWITCH-COMP-ignition & starter (up to '71-3)
- 25150-H1010 SWITCH-COMP-ignition & starter (from '71-4 to '73-8)
- 25150-G1001 SWITCH-IGNITION [for non-steering lock type] 7309-7803
- Or
- 48700-H1600 LOCK ASSY-steering (up to '71-3) OPTION
- 48700-H2010 LOCK SET-STEERING 7104-7803 OPTION
- 48700-G1060 LOCK SET-STEERING 7804-8210
- 48700-G1925 LOCK SET-STEERING 8211-
- Steering Lock Set includes one of the following ignition switch:
- 48750-H1900 SWITCH-IGNITION 7510-7803
- 48750-E4700 SWITCH-IGNITION 7804-
All Key Set include:
- 80690-E6000 CASE ASSY-KEY [leather case for key]
- 80600-H1001 CYLINDER SET-DOOR LOCK, RH from 7104
- superceeded 80600-H1000 CYLINDER ASS'Y-door lock (R.H.)
- 80601-H1001 CYLINDER SET-DOOR LOCK, LH from 7104
- superceeded 80601-H1000 CYLINDER ASS'Y-door lock (L.H.)
- 80590-10600 CLIP-RETAINING CYLINDER LOCK (2)
- 76960-H7400 CYLINDER SET-GAS FILLER LOCK 7510-
- 80590-21000 CLIP-RETAINING CYLINDER LOCK [small, for filler door lock]
- replaced 76960-H1001 LOCK ASS'Y-gas filler lock
- 76962-18200 CLIP-seating cylinder lock (fixing gas filler)
- KEY00-00035 KEY-BLANK 8110-
Small clip is for the fuel filler door lock cylinder
Dimensions
Length
Nissan keys come in various lengths. The original Datsun 1200 keys were the short length.
- Short: ~31 mm groove length
- 2.0 inch overall
- Original 1200 reversible key length
- Medium: ~38 mm groove length
- 2.4 inch overall
- Used by Datsuns & Nissans 1974-1981, Subaru, and Mazda Cosmo
- Long: ~46 mm groove length
- 2.7 inch overall
Width
Width is 8.9 mm at the point where the grooves start.
Width of the teeth area is 7.1 mm
Center groove width: 2.3 mm
Outside groove width: about 1.0 mm minimum (some keys have it machined all the way out, that is to say a wider groove)
Right-Handed vs Left-Handed
The reversible key came in left-hand and right-hand versions.
KEY00-00035 left groove (Datsun 1200)
2nd groove is left of center groove
2nd groove is right of center groove
Aftermarket Keys
Two styles were used (center, right). The newer, longer one (left) will work, but is not the original style.
The little groove diagrams below the photos are for the keylock, so they are the reverse of the actual key.
WARNING: The first key is right-handed, while the second is left-handed. Each key comes either way. Be sure to purchase the correct one for your 1200 locks.
Interesting that some 1200s (newer utes?) came with two different keys originally. The 1971-1973 north american models came with single key for ignition, doors and trunk.
Oval Single-Sided Nissan Ignition Key
This is the earlier style for 1968-1971 Datsun, Mazda before the double-sided keys were used. This was used by 1971 USA 1200.
- Nissan: KEY00-00034 (Key-Blank for Voss Type Steering Lock)
- Ilco/Ilco-Kaba: DA20
NOT THIS Waso:
- Waso Type FH
- Taylor: D80K
Short Double-Sided Nissan Key
This was used by 1972-up 1200s for the ignition switch.
- Nissan: KEY00-00035 (Key-Blank for Voss Type)
- Ilco: 62DV
- Dominion/DL/Hook: DT17
- Taylor: X10
- JMA DAT-8
- Silca : DAT 7
- HD Hook : C050
- HD Hook : C50
- Orion : DA12
- Errebi : NS3R
- CEA : NS7
- RST : D131
- CB Hook : 212
- Standard : 212
- Curtis : DA-21
Long Nissan/Subaru Key
Used by Datsuns, Nissans 1974-1981, Subaru, and Mazda Cosmo. This "long" key is not original to the 1200, but works perfectly fine.
Reversible (left) 2.4 inches long
- Taylor 62DU
- Ilco X7
- Nissan M5001
- Taylor X7
- JMA DAT-1D
- Silca : DAT 6R
- HD : DT19
- HD Hook : C052
- HD Hook : C52
- Orion : DA11L
- Errebi : NS2R
- CEA : NS6S
- RST : D151
- RST : D151R
- CB Hook : 214
- DL : DT19
- Curtis : DA-21
NOT this! Reversible (Right, mirror image)
- Nissan M4001
- Taylor X6
- Ilco X6
- JMA DAT-1I
- Silca : DAT 6
- HD : DT18
- HD Hook : C051
- HD Hook : C51
- Orion : DA11
- Errebi : NS2
- CEA : NS6
- RST : C151R
- RST : D151R
- CB Hook : 213
- CB Hook : 215
- DL : DT18
- Curtis : DA-22
Single-sided
- Taylor D80D/D80E/D80F/D80G
Option
- Key Assy (with holder) 80610-H1001
Key Code
When your key gets worn down too far, making a copy results in a poorly-working new key. Instead, have a new key cut from the original key code.
- In Australia, the key cut number was stamped directly into the original keys
- Additionally, the code may be stamped on the right-side door lock cylinder. Remove the door panel to get at the clip which holds the lock in.
- Not necessarily stamped on left-side door lock, nor trunk/boot lock, nor ignition lock
In USA, the key cut number was penciled onto the inside of the glove box door:
- VF: for VOSS single-side KEY00-00034
- mine is marked "1", possibly to indicate my locks are a single-key system
- VH: for older (pre-Datsun 1200) WASO KEY00-0028
- Eng*/DOOR: 4-digit key code
Codes
- In the range of (M)5001-(M)6000 (or N) for reversible KEY00-00035/KEY00-00055
- range 4001-5000 is for mirror image keys (non-Datsun 1200)
Non-1200 Keys
WASO Oval Keys
Use only VOSS type for Datsun 1200
Single-Cut Keys
Do not confuse Datsun 1200 keys with these single-sided VOSS keys. They also had "Nissan Motor" text and "N" symbol, but were used by earlier models e.g. Datsun Roadster.
From http://www5.plala.or.jp/power_planning/key.html:
- KEY00-00201 non-centered grooves
- Mirror of 00202
- KEY00-00202 non-centered grooves
- KEY00-00203 centered groove
- KEY00-00204 centered groove
- Mirror of 00204
Lock Set
B120 late 99810-G1500A 48700-M1060 Ignition Switch for Steering Lock B 80600-H1001 RH Door Lock C 80601-H1001 LH Door Lock D 76960-H7400 Fuel Lid Lock
Tawain made the Yulon 303T (Sunny Truck), so they have plenty of parts.
Yue Loong 301 (B210) Key Set SUNNY B110/B210/120Y 1971-1979 80010-H5000 KEY SET Four pieces/set * DOOR KEY DK-301R 80600-H5000 * DOOR KEY DK-301L 80601-H5000 * TRUNK LID TK-301 84460-H5000 (sedan) * FUEL LID KEY FK-301 78840-H5000 76960-H5005 76960-H1001
B210 Japan 80010 CYLINDER LOCK & KEY SET 80690-E6000 HOLDER ASS'Y-key 25150-H5001 SWITCH COMP.-ignition & starter V (exc. SP-DX) -7412 > 25150-H5000 48700-H5000 LOCK ASS'Y-steering 48700-H5010 LOCK ASS'Y-steering 80600-H5000 CYLINDER ASS'Y-lock door (R.H.) 80601-H5000 CYLINDER ASS'Y-lock door (L.H.) 84460-H5500 LOCK ASS'Y-trunk lid K 84460-H5000 LOCK ASS'Y-trunk lid S 90600-H6600 CYLINDER LOCK ASS'Y-back door V <?> 90600-H6601 76960-H1001 LOCK ASS'Y-gas filler lid 76960-H7400 LOCK ASS'Y-gas filler lid (late)
Ignition Lock
See main article: Ignition Switch
For Steering Lock OR w/o Steering Lock![]()
Door Locks
Door locks differ Right and Left side.
Aside from the plastic clip, the door locks fit:
B110 B120 B210 620 E20![]()
Fuel Door Lock
B110 B210 B120 B140 76960-H7400 > 84660-H5000 > 76960-H1001![]()
Trunk Lock
Sunny Keys
Outback Lock
Electric Locks
Central locking kit
