The Nissan PB110 model line was named the Nissan Sunny Excellent 1400. It featured a larger overhead-cam engine and modified front sheet metal styling. It is also called the "Sunny Long-nose" (????????????). The engine bay seems to be the same size as a B110, but the guards and bonnet of the PB110 are longer in the front to make the car feel bigger. The wheelbase is 40mm longer (less than 2 inches) but the PB110 overall is more than 5 inches longer.
Our beloved "Datsun 1200" is Nissan body code B110, equipped with the 1200cc A12 pushrod engine. This is also known as the Datsun Sunny 1200. In Japan however, there was an upscale derivative of the B110, the Sunny Excellent -- body code PB110. The P apparently stands for "bigger engine". Yes, the Excellent was fitted with the L-series Overhead Cam (OHC) engine, the same type of engine fitted to the bigger Datsun vehicles.
Description
This factory brochure shows both vehicles (Comparo):
Sunny 1200 and Sunny Excellent 1400
- On the right: 1400 Excellent (PB110)
 - On the left: 1200 GX (B110). Note the hood blister and the grille of 1972 models. All models from STD to GX had this kind of grille in 1972 models. (GX is a more powerful Twin Carb version of A12)
Sunny Excellent 1400 4-dr sedan
- aftermarket minilite-style wheels * custom silver paint
Notice the unique grille. The hood and fenders are also slightly modified in the front area. For more details on this, see discussion PB110 (Sunny Excellent) vs. B110 (Sunny).
Features:
- L14 Engine, 1400cc
 - Single-carb engine: 85hp, 11.8kgm/3 torque @3,600 rpm
 - Twin-carb engine (GX): 95hp, 12.2kgm/3 torque @4,000 rpm
 - Top Speed (both engines): 155km/h
 - 4-speed floor shift (or optional Nissan Full Automatic 3-speed floor shift, not available for GX models)
 - Nissan Guarantee: 2 year and 50,000 kilometers (1971 brochure)
- The writing before 1400 says "Coupe" (Kuupe, a germanic spelling)
 - Notice the unique taillights and 'blackout' rear panel.
- Closeup of grille. The extended forward "peak" of the Excellent grille is evident here, compared to the more flat grille of the 1200.
The Excellent was also available as a 4-dr sedan. There were no 2-dr sedans, wagons or truck versions.
Notice the unique GL and DX hubcaps, which are different from the B110 wheel covers of the same trim level.
Trim Levels: DX, GL and GX
 1200 and 1400 trim levels
This outlines the various trim levels the Coupe was available in: GX, GL and DX. The writing above '1400' phonetical spells out "Excellent". The same trim levels were offered for the 4-Excellent door Sedan:
From left to right: 1200GX, 1200GL, 1200DX, 1200 Semi-DX & 1200 STD, 1400GX, 1400GL, 1400DX. Compare to Australia and USA, where only one trim level was offered: a customized version of the 1200 DX.
- 3-spoke standard GX steering wheel
 - wood grain on lower half of dash
 - dash has hooded gauges. The hood reduces glare.
 - console with optional clock
 - extended color choices for carpeting
GX Steering Wheel, Dash with hooded guages, and console w/clock. Also notice upgraded cloth-insert seats.
Wheel and Tire
The PB110 Excellent used 12" tires.
- blackwall
 - dual-stripe whitewall
 - wide-stripe whitewall with optional hubcap
Engine
The Sunny Excellent PB110 was fitted with 1400cc L14 engine, a smaller-displacement version of the L16 fitted to the Datsun 1600. This is an wikipedia:Overhead Cam engine. Both a single carb and dual-carb engine was available. Top speed was 155kmh, up 5km from the Datsun 1200.
Sunny Excellent 1400 engine compartment 85 hp single carb (non-GX) L14 engine
http://datsun1200.com/modules/myalbum/photos/thumbs/6380.2bg
Sunny Excellent GX (twin-carb) L14 engine with original Twin Hitachi (SU type) carburetors.
Sunny Excellent GX (twin-carb) L14 engine. With aftermarket dual sidedraft carburetors.
DX and GL models had a single-carb engine, while the GX had dual sidedraft carburetors (GX means GL with Twin Carbs).
Nissan Rotary Engine
Under the bonnet of this Excellent is the rotary engine used to advance the development of NISSAN's new rotary. For more information, see Rotary engine.
Interior
- Notice the upmarket seats, the (aftermarket?) steering wheel, and unique dashboard.
 - 1971 Excellent GX has standard B110 dashboard, but with woodgrain trim
-  GX:
- black striped cloth (available with exterior Colors #008 Blue, #005 Blue, #931 Gold, #930 Green, #665 Yellow)
 - brown striped cloth (for #009 Orange, #004 Green, #821 White)
 -  GL:
- black tricot (for #009 Orange, #005 Blue, #004 Green, #931 Gold, #930 Green (Coupe only), #665 Yellow)
 - blue tricot (for #008 Blue, #821 White)
 -  Deluxe:
- black vinyl leather (for #008 Blue, #930 Green (Coupe only))
 - yellow vinyl leather (for #931 Gold, #821 White, #665 Yellow)
Consoles
- Console could be had without any gauges (just a Sunny plate)
 - Clock with cubbyhole below was optional
 - Clock with two small gauges was optional
 - Has heater vent extender with directional (!) vents
- With option Large Clock
 -  With option auxliary gauges
- Oil P (oil pressure) measured from 0-6 kg/cm3
 - AMP (ammeter) from -30 to +30
Seats
- Deluxe: Vinyl seats like B110, but fancier form fitted stitching
 - GL: ?
 - GX: Cloth-insert vinyl seats
Notice the GX engine (sidedraft carbs), deluxe seats, and the DX dashboard (same as the B110 dashboard - which may have been a first-year only Excellent).
Dashboard And Steering Wheel
- Later 'hooded' dash. Picture clearly shows the concave profile of the dash. (aftermarket seat color, shift knob, equalizer)
- Early GX dash (same style as B110, but with woodgrain accents)
 - Three-spoke GX wheel, spokes have single slots
- Deluxe uses same steering wheel as Standard B110
 - GL uses 3-spoke steering wheel
 - GX has standard 3-spoke 'large-horn button' wheel with "GX" emblem in center. Each spoke has two long slots.
Badges
Coupe
- Front: 'S' pentagon-shaped grille ornament
 -  Side Rear quarter: 'Sunny' then 'Excellent' followed by: ** 'GX'
- 'GL'
 - 'Deluxe'
 -  Trunk lid fitting
- '1400 GX'
 - '1400 GL'
 - '1400 Deluxe'
 - Rear: 'Excellent' on black-out panel between taillights
Also see badges on Coupe:
[1]
Sedan
- Front:
 -  C-pillar:
- 'Excellent GX'
 - 'Excellent GL'
 - 'Excellent Deluxe'
 -  Trunk lid fitting:
- (left) '1400'
 -  (right):
- 'Excellent GX'
 - 'Excellent GL'
 - Rear: 'Nissan Full Auto Matic'
Optional Equipment
1971 Options:
- LH side mirror
 - Vinyl top
 - Console Clock
 - Console Clock with auxiliary gauges
 - High-back bucket seats (standard fitting is seats with detacable headrests)
 - Coupe trunk-lid mounted air spoiler
 - Rear-window defrost glass
 - Fibre-optic Illuminated dash switches (like 1973 USA B110s)
 - Air conditioning
 - Assistant driver's seat headrest
Excellent interior trim (some are standard, others optional):
- GX Mirrors: Fender-mounted black with chrome ring
 - 'Datsun' Clarion AM radio
 - GL three spoke steering wheel. Later style 'hooded' dash
 - Driving lamps (fog lights) built into the grille
 - Clock in dash
 - Steering lock with ACC position (what you can't see is the special 3-switch Hazard lights (regular, left lights, right lights)
 - tilt wheel(?)
 - sun visors
 - 8000 RPM tachometer (redline: ~6400)
 - Optional wood shift lever knob
 - Rear window defrost control (?)
 - Rear seat shoulder belts
 - Cigarette lighter (?)
 - Center console (with no clock or tach)
 - Larger disc brakes than Datsun 1200 models
Advertising
Innovate marketing? Featuring Alan Merril, a rock star in Japan.
Yes Sunny! advertisement with red Excellent coupe
Racing
The racing PB110s included this Coupe (KPB110) with the Nissan works competition LZ14 twin-cam engine:
- LZ14 May 3, 1973 introdction for TS-A Class japan Grand Prix racing
 - 16 Valve Twin-cam head on L-series block, 1600cc
 - 200 HP @ 9,400 RPM
Sunny Excellent 1400 Coupe race car at Advan Historics
Brochures
Tri-fold: 1971 Sunny Excellent 1400 (6 pages)
More Excellent Photos
Click each photo to view it full-size in the Photo Album, and read any comments which may be posted.
Blue Excellent coupe with aftermarket wheels
- Coupe-like taillights with license plate in between
Coupe with incorrect Mirrors
A very popular photo -- it's been posted three times!
discussion:
