Z18ET turbo, Z20, Z22. These crossflow-headed engines are based on the L-series. All install into a 1200 more or less the same way.
Z20 NAPS-Z engine in Datsun 1200
Z18 Turbo
Turbo Power! right from the factory.
The nice thing about the Z18ET is its a factory setup, legal in most Australia states for a 1200. The downside is how available is it, including the wiring harness?
Z18T Turbo Engine Swaps
See main article: Z-series Engine Swap
Sources
Z-series was a common engine in the larger Datsuns, as it replaced the L-series engine starting in 1979.
Australia
910 Bluebird (Japan import) Z18ET (Z18T) 720 Z20 D21 Navara Z20 Urvan Z20 Vanette Z20
Z18ET came in Japan-import cars. Australia models didn't have Z-turbo engines.
Bluebird Series I Z18ET (Japan-spec)![]()
Z16S Z18E/Z18S/Z18T Z20D/Z20S/Z20E Z22S
VEHICLE APPLICATION A10 Z16E/Z16S/Z18E/Z18S 720 Z16S/Z18S 910 Z16S/Z18S/Z18E/Z18T/Z18P/Z20S/Z20E C120 Z20S C210 Z18S/Z18E C230 Z20S C231 Z18S C31 Z18P/Z18S/Z20S D21 Z16S/Z18S/Z20S E23 Z18S/Z20S E24 Z20S F22 Z16S/Z20S F30 Z18S H40 Z20D (LPG/Dual), Z20S (Nissan Atlas/UD Condor) R30 Z18S/Z20E S110 Z18E/Z18S/Z18T/Z20E TC22 Z20S W40 Z22S WE24 Z20S
8-plug (twin-plug head) E24 Z20 WE24 Z20S 910 Z16S/Z18S/Z18P/Z18E/Z18ET/Z20S/Z20E C120 Z20 C31 Z18S/Z18P/Z20S E23 Z20 F30 Z18S R30 Z18S/Z20E S110 Z18S/Z18E/Z18ET/Z20E
4-plug (single-plug head) 720 Z16/Z18 D21 Z16S/Z18S/Z20S TC22 Z20S W40 Z22S 910 Z16S E23 Z18/Z20 E24 Z20 F22 Z16/Z20 H40 Z20D/Z20S R30 Z18S
North America
Z20S/Z20E Z22S/Z22E Z24S/Z24E/Z24I S = single carburetor E = multi-point injection I = throttle body injection
VEHICLE APPLICATION A10 Z20S 720 Z20S/Z22S/Z24S/Z24I D21 Z24S WD21 Z24I GC22 Z24I S110 Z20E/Z22E
4-PLUG (SINGLE-PLUG HEAD) S110 Z20E FED (CAL used 8-plug) A10 Z20S FED 1980
720 0179-1285 * L20B 1980 model year (0679-) * Z22E 1981-1984 * Z20E 1983-1986 (0183-) * Z24 1983-1986 (1182-) * VG30 1986
S110 0179-0783 "200SX" * Z20E -0681 * Z22E 0781-
A10 0177- "510" * L20B 1978-1979 model years (from 1177-) * Z20S 4-plug FED.-0680 uses 22162-U6001 DISTRIBUTOR CAP (1980 only) * Z20S 8-plug uses 22162-W0561/22162-W0562 DISTRIBUTOR CAP
Engine Swaps
Heads North America
11041 HEAD ASSY-CYLINDER 720 11041-04W80 L20B 0679-0680 <> 11041-W0381 11041-07W80 Z22 0679-0681 11041-07W03 Z22 0781-1282 11041-10w00 Z24 11041-W7080 Z20 -0784 11041-W0481 Z20 0784- S110 11041-N8580 Z20E 0179-0780 FED 11041-N8780 Z20E 0179-0780 CAL 11041-N8561 Z20E 0880-0681 11041-07W03 Z22E 0781-0783 A10 11041-N8580 Z20S(FED) -0680 11041-N8780 Z20S(CAL) -0680 11041-N8580 Z20S 0780-
Head Bolts
BOLT-CYLINDER HEAD * Z-series uses A-series Head Bolts 11056-H2301 Z20/Z22 (10) 11057-H5700 Z24 (10)
Head Gasket
11044 GASKET-CYLINDER HEAD 11044-W0400 Z20 (-0880) <> 11044-W0402 (0980-0681) 11044-W4000 720.Z20 <> 11044-W4001 <> 11044-W4002 0784- 11044-06W00 Z22 <?> 11044-06W01/11044-06W02 11044-06W03 Z22 (720.0582-, S110.0482) <> 11044-06W04 (0782-) <> 11044-06W05 11044-10W01 Z24 (-0983) <> 11044-10W02 (1083-)
Valve Cover Gasket
13270 GASKET-ROCKER COVER 13270-G2500 720.Z20, Z24 13270-W0401 S110.Z20E, A10.Z20S, Z22 <> 13270-17C10 REINZ
13272M LABEL-ROCKER COVER 720.1184-
Camshaft
13001 CAMSHAFT ASSY
13001-W0480 Z20/Z22/Z24 S110/A10/720/D21 <> 13001-W0483 13001-W0402 720.Z20 <> 13001-W0483 13001-17C80 All Models from 11/85 Z24I/Z20/Z24 D21/WD21/CG22
Z20/Z22/Z24 720/D21/WD21/GC22 SEALED POWER CS755 * Hydraulic * (050) Duration at .050 Lobe Lift: 227 Exh. 227 Int.
Head Types
11041-N8580 [late Z20S/Z20E] 13201-N8501 VALVE-INTAKE late Z20 [42x8x124.4 mm] 13202-N8500 VALVE-EXHAUST [38x8x125.4 mm] 14035-W7061 GASKET-INTAKE MANIFOLD 14036-W7060 GASKET-EXHAUST MANIFOLD
11041-N8580 Z20S(FED) -0680 [4-plug] 13201-N8500 VALVE-INTAKE early Z20 13202-N8500 VALVE-EXHAUST Z20 14035-W8800 GASKET-INTAKE MANIFOLD WITH BLADE FED [3-piece] * <?> 14035-W8805 <?> 14035-W8810 <?> 14035-W8815 14036-W0401 GASKET-EXHAUST MANIFOLD
11041-N8780 Z20S(CAL) -0680 [8-plug] 13201-N8500 VALVE-INTAKE early Z20 13202-N8500 VALVE-EXHAUST Z20 14035-W7061 GASKET-INTAKE MANIFOLD CAL [1-piece] 14036-W0401 GASKET-EXHAUST MANIFOLD [2-piece]
