Also see:
Part Numbers Index Main article for usage, photos, cross-reference Brake Piping
1971
BRAKE PIPING 1 46223-H1000 ASS'Y-TUBE, brake master cylinder to connector STD,V-Dx 46223-H1001 ASS'Y-TUBE, brake master cylinder to connector <> 46223-H1000 46223-H1100 ASS'Y-TUBE, brake master cylinder to connector DX,GL,GX 46223-H1101 ASS'Y-TUBE, brake master cylinder to connector <> 46223-H1100 46223-H3200 ASS'Y-TUBE, brake master cylinder to connector (from '71-Sep) DX,GL,GX 2 46234-H1000 CONNECTOR-brake tube (4 way) STD,V-DX 46234-H1100 CONNECTOR-brake tube (3 way) DX,GL,GX 3 83-60630-14 BOLT 4 46240-H1000 ASS'Y-TUBE, front brake (R.H.) 5 46242-H1001 ASS'Y-TUBE, front brake (L.H.) 6 46202-89913 ASS'Y-HOSE, brake front (l=280) 2 7 46205-61000 PLATE-lock, front hose 4 8 46206-18000 SPRING-lock, front hose 4 9 46245-H1001 ASS'Y-TUBE, wheel cylinder, front (R.H.) (exc. GL,GX) 10 46246-H1001 ASS'Y-TUBE, wheel cylinder, front (L.H.) (exc. GL,GX) 46245-H1006 ASS'Y-TUBE, wheel cylinder, front disc brake (R.H.) GL,GX 46246-H1006 ASS'Y-TUBE, wheel cylinder, front disc brake (L.H.) GL,GX
REAR BRAKES 11 46313-18000 CONNECTOR-3 way brake tube 12 46290-H1000 ASS'Y-TUBE, rear brake (R.H.) Sedan 46290-H1400 ASS'Y-TUBE, rear brake (R.H.) Van, Coupe 13 46310-H1000 ASS'Y-TUBE, rear brake (L.H.) Sedan 46310-H1400 ASS'Y-TUBE, rear brake (L.H.) Van, Coupe 14 46201-89918 ASS'Y-HOSE, brake rear (l=330) 15 46237-18000 GASKET-brake hose to cylinder 16 46205-61000 PLATE-lock, brake hose 17 40206-18000 SPRING-lock, brake hose 18 46280-H1001 ASS'Y-TUBE, brake master cylinder to rear brake hose STD,V-Dx 46280-H1101 ASS'Y-TUBE, brake master cylinder to rear brake hose DX <x> 46280-H3200 46280-H3200 ASS'Y-TUBE, brake master cylinder to rear brake hose DX (from '71-Sep) 46280-H1105 ASS'Y-TUBE, brake master cylinder to rear brake hose GL,GX <x> 46280-H3210 46280-H3210 ASS'Y-TUBE, brake master cylinder to rear brake hose GL,GX (from '71-Sep) 19 9-51206 GROMMET-rubber 2
1972
BRAKE PIPING 1 46223-H1001 TUBE-ASS'Y-brake master cylinder to connector (up to '72-7) (Single M/C) STD,V-Dx 46223-H3200 TUBE-ASS'Y-brake master cylinder to connector (Tandem M/C) DX,GL,GX 46223-H3201 TUBE-ASS'Y-brake master cylinder to connector (from '72-8) (Tandem M/C) DX,GL,GX > 46223-H3200 2 46234-H1000 CONNECTOR-brake tube (4 way) (up to '72-7) (Single M/C) STD,V-DX 46234-H1100 CONNECTOR-brake tube (3 way) (Tandem M/C) 3 08360-63014 BOLT 4 46240-H1000 TUBE ASS'Y-front brake (R.H.) 46240-H1001 TUBE ASS'Y-front brake (R.H.) (from '73-3) > 46240-H1000 5 46242-H1001 TUBE ASS'Y-front brake (L.H.) 46242-H1002 TUBE ASS'Y-front brake (L.H.) (from '73-3) > 46242-H1001 6 46202-89913 HOSE ASS'Y-brake front (l=280) 2 7 46205-61000 PLATE-lock, front hose 4 8 46206-18000 SPRING-lock, front hose 4 9 46245-H1001 TUBE ASS'Y-wheel cylinder, front (R.H.) STD,DX <> 46245-H5000 46245-H5000 TUBE ASS'Y-wheel cylinder, front (R.H.) (from '73-3) STD,DX 10 46246-H1001 TUBE ASS'Y-wheel cylinder, front (L.H.) STD,DX <> 46246-H5000 46246-H5000 TUBE ASS'Y-wheel cylinder, front (L.H.) (from '73-3) STD,DX 46245-H1006 TUBE ASS'Y-wheel cylinder, front disc brake (R.H.) GL,GX <> 46245-H5100 46245-H5100 TUBE ASS'Y-wheel cylinder, front disc brake (R.H.)(from '73-3) GL,GX 11 46313-18000 CONNECTOR-3 way brake tube 12 08110-82562 BOLT 13 46290-H1000 TUBE ASS'Y-rear brake (R.H.) Sedan <> 46290-H5001 46290-H5001 TUBE ASS'Y-rear brake (R.H.) (from '73-3) Sedan 46290-H1400 ASS'Y-TUBE, rear brake (R.H.) Van, Coupe < 46290-H1401 46290-H1401 ASS'Y-TUBE, rear brake (R.H.) Van, Coupe <x> 46290-H5501 46290-H5501 ASS'Y-TUBE, rear brake (R.H.) (from '73-3) Van, Coupe 14 46310-H1000 TUBE ASS'Y-rear brake (L.H.) Sedan <> 46310-H5001 46310-H5001 TUBE ASS'Y-rear brake (L.H.) (from '73-3) Sedan 46310-H1400 ASS'Y-TUBE, rear brake (L.H.) Van, Coupe < 46310-H1401 46310-H1401 ASS'Y-TUBE, rear brake (L.H.) Van, Coupe <x> 46310-H5501 46310-H5501 ASS'Y-TUBE, rear brake (L.H.) (from '73-3) Van, Coupe 15 46201-89918 ASS'Y-HOSE, brake rear (l=330) 16 46237-18000 GASKET-brake hose to cylinder <x> 42637-A4600 46237-A4600 GASKET-brake hose to cylinder (from '73-3) 17 46205-61000 PLATE-lock, brake hose 18 40206-18000 SPRING-lock, brake hose 19 46280-H1001 TUBE ASS'Y-brake master cylinder to rear brake hose (up to '72-7) (Single M/C) STD,V-Dx 46280-H1001 TUBE ASS'Y-brake master cylinder to rear brake hose (up to '72-8) STD,V-Dx <x> 46280-H1001 46280-H3200 TUBE ASS'Y-brake master cylinder to rear brake hose DX,GL,GX (exc. Auto,5-speed) 46280-H3201 TUBE ASS'Y-brake master cylinder to rear brake hose DX,GL,GX (exc. Auto,5-speed) (from 72-8) (Tandem M/C) > 46280-H3200 46280-H3210 TUBE ASS'Y-brake master cylinder to rear brake hose Automatic 46280-H3211 TUBE ASS'Y-brake master cylinder to rear brake hose Automatic (from '72-5) > 46280-H3210 46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose 5 speed 46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose 5 speed (from '72-5) > 46280-H7201
1 46223-H1901 ASSY-TUBE BRAKE MASTER CYL. FR(TANDEM)TO OP 2 46223-H1900 1 46223-H3900 ASSY-TUBE,B/MASTER CYL.FR (TANDEM) TO 1071-0473 30 46223-H1901 1 46223-H3901 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 2 46223-H3900 1 46223-G1300 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 46223-H3901 1 46223-H1900 ASSY-TUBE BRAKE MASTER CYL FR(TANDEM)TO 2 46224-H3901 ASSY-TUBE,B/MASTER CYL. RR (TANDEM) TO 0573- 2 46224-H3900 2 46224-H1900 ASSY-TUBE BRAKE MASTER CYL RR(TANDEM)TO 2 46224-H1901 ASSY-TUBE BRAKE MASTER CYL. RR(TANDEM)TO OP 1170- 2 46224-H1900 2 46224-H3900 ASSY-TUBE,B/MASTER CYL.RR (TANDEM) TO 1071-0473 30 46224-H1901 3 46100-26100 ASSY-SWITCH BRAKE INDICATOR 3 46100-U5200 ASSY-SWITCH BRAKE INDICATOR 1071-0473 32 46100-26100 4 08360-63514 SCREW-MACHINE WITH WASHER 5 46240-H1900 ASSY-TUBE BRAKE FRONT RH FOR TANDEM B -473 3 5 46240-H1901 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1900 5 46240-G1300 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1901 6 46242-H1900 ASSY-TUBE BRAKE FRONT LH FOR TANDEM B -473 3 6 46242-H1901 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1900 6 46242-G1300 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1901 7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL 0573- 2 46280-H1901 7 46280-H1905 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC 7 46280-H1906 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC 46280-H1905 7 46280-H1901 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3 7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3 46280-H1901 8 46313-18000 CONNECTOR-3WAY REAR 8 02463-13200 CONNECTOR-3WAY REAR 46313-18000 9 08110-82562 BOLT-HEX WITH WASHER M8 10 46290-H5501 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H1001 10 46290-H7301 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H5501 10 46290-H1000 ASSY-TUBE REAR BRAKE RH SEDAN COUPE -473 3 10 46290-H1001 ASSY-TUBE REAR BRAKE RH SEDAN COUPE 0573- 2 46290-H1000 10 46290-H5001 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H1001 10 46290-H7201 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H5001 11 46310-H5501 ASSY-TUBE REAR BRAKE LH COUPE 0673- 5 46310-H1001 11 46310-H5001 ASSY-TUBE REAR BRAKE LH SEDAN 0673-0672 25 46290-H1001 11 46310-H1000 ASSY-TUBE REAR BRAKE LH SEDAN COUPE -473 3 11 46310-H1001 ASSY-TUBE REAR BRAKE LH SEDAN COUPE 0573- 2 46310-H1000 12 46201-89918 ASSY-HOSE BRAKE REAR L=330 12 46201-H7200 ASSY-HOSE BRAKE REAR L=330 46201-89918 13 46237-18000 GASKET-BRAKE HOSE TO TUBE 14 46205-61000 PLATE-LOCK BRAKE HOSE 15 46206-18000 SPRING-LOCK BRAKE HOSE
