Rear Brake Part Numbers
Revision as of 02:17, 15 December 2014; view current revision
Categories: Brake System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Rear Brake
Late Truck
From 1989 October - Self-adjusting type
Fastening to axle housing flange
 08915-23810 WASHER (8)
 08912-43810 NUT (8)
 44000A BOLT
  44005-U1400 (8)
44000M BRAKE ASSY-DRUM,REAR RH
 44000-G1210
44010M BRAKE ASSY-DRUM,REAR LH
 44010-G1210
 44020 PLATE ASSY-BACK,REAR BRAKE RH
  44020-G1210
 44020G PLUG
  41098-70A10
 44030 PLATE ASSY-BACK,REAR BRAKE LH
  44030-G1210
 44060K SHOE SET-REAR BRAKE
  44060-G1225
 44081-M4901 PIN-ANTI SHOE RATTLE 4
 44083-W5200 SPRING-ANTI SHOE RATTLE 4
 44090-M4900 SPRING-RETURN,REAR BRAKE SHOE 2
 44091-M4900 SPRING-RETURN,REAR BRAKE SHOE (2)
 44100B
  01436-00052 BOLT (4)
 44100K CUP KIT-BRAKE WHEEL CYLINDER,REAR
  D4100-D5590 NABCO 3/4 (1)
  D4100-G2893 TOKICO 3/4 (1)
   44100P CYLINDER ASSY-REAR WHEEL
    44100-D5510 (2)
   44108 PISTON-CYLINDER (4)
    44108-D0101 NABCO
    44108-G2810 TOKICO
   44112 CUP-PISTON (4)
    44112-PO201 NABCO
    44112-P0211 TOKICO
   44124 COVER-DUST (4)
    44124-D5500 NABCO
    44124-17C10 TOKICO
   44125 SPRING (2)
    44125-M7010 TOKICO
    44125-U9200 NABCO
   44127 BOOT
    44095-M4910 (2)
   44128-U5200 SCREW-BLEEDER NABCO
   44129-A2410 CAP-BLEEDER SCREW TOKICO
44200N ADJUSTER ASSY-REAR BRAKE
 44200-W5211 RH
 44201-W5211 LH
44211-H8300 STOPPER-ADJUSTER LEVER
44212-H8300 FASTENER-ADJUSTER
Disc/Drum Setup
1 44000-H3300 ASSY-BRAKE REAR RH FOR FR DISC OP 0273- 2 44000-H0500
1 44000-H0500 ASSY-BRAKE REAR RH FOR FR DISC OP -173 3
2 44010-H0500 ASSY-BRAKE REAR LH FOR FR DISC OP -173 3
2 44010-H3300 ASSY-BRAKE REAR LH FOR FR DISC OP 0273- 2 44010-H0500
3 44020-27700 ASSY-DISC REAR BRAKE RH OP
4 44030-27700 ASSY-DISC REAR BRAKE LH OP
5 44060-18000 ASSY-SHOE REAR BRAKE FORE (2) OP
6 44070-18000 ASSY-SHOE REAR BRAKE AFTER (2) OP
7 41066-18000 LINNING-BRAKE (4) OP
8 44081-18000 PIN-ANTI SHOE RATTLE (4) OP
9 44082-32200 SEAT-SPRING ANTI SHOE RATTLE (4) OP
10 44083-32200 SPRING ANTI SHOE RATTLE (4) OP
11 44084-32201 RETAINER-SHOE RATTLE (4) OP
12 44090-18000 SPRING-RETURN RR BRAKE SHOE CYLINDER (2) OP
13 44091-18000 SPRING-RETURN RR BRAKE SHOE ADJUST (4) OP
14 44100-H3300 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP 0273- 2 44100-H0500
14 44100-H0500 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP -172 2
15 44112-18800 CUP-PISTON(NABCO) (2) OP
15 44112-H3300 CUP-PISTON (NABCO) (2) OP 2 44112-18800
15 44112-16510 CUP-PISTON (TOKIKO) (2) OP 0273-
16 44108-18800 PISTON-CYLINDER(NABCO) (2) OP
16 44108-H0510 PISTON-CYLINDER (TOKIKO) (2) OP 0273-0173 3
17 44113-31700 RING-SNAP(NABCO) (2) OP -173 3
17 44113-U4000 RING-SNAP (NABCO) (2) OP 0273- 0 44113-31700
17 44113-U4010 RING-SNAP (TOKIKO) (2) OP 0273-
18 44118-18000 ASSY-LEVER(NABCO) (2) OP
18 44118-21910 ASSY-LEVER (TOKIKO) (2) OP 0273-
19 44124-U4000 COVER-DUST'A' (NABCO) (2) OP 0273-
19 44124-U4010 COVER-DUST'A' (TOKIKO) (2) OP 0273-
19 44124-31700 COVER-DUST'A'(NABCO) (2) OP -173 3
20 41128-21900 SCREW-BLEEDER(NABCO) (2) OP -173 3
20 41128-U0201 SCREW-BLEEDER (NABCO) (2) OP 0273- 0 41128-21900
20 41128-U0512 SCREW-BLEEDER (TOKIKO) (2) OP 0273-
21 41129-A2410 CAP-BLEEDER(NABCO) (2) OP -173 3
21 41129-U0201 CAP-BLEEDER (NABCO) (2) OP 0273- 0 41129-A2410
21 41129-30001 CAP-BLEEDER (TOKIKO) (2) OP 0273-
21 41129-40F00 CAP-BLEEDER (TOKIKO) (2) OP 0273- 41129-30001
22 44141-31700 PLATE-LOCK(NABCO) (2) OP -173 3
22 44141-U4000 PLATE-LOCK (NABCO) (2) OP 0273- 0 44141-31700
22 44141-U4010 SHIM-ADJUSTING'A' (TOKIKO) (2) OP 0273-
23 44142-31700 PLATE BACK UP(NABCO) (2) OP -173 3
23 44142-U4000 PLATE-BACK UP (NABCO) (2) OP 0273- 0 44142-31700
23 44142-31710 SHIM-ADJUSTING'B' (TOKIKO) (2) OP 0273-
24 44149-31700 SHIM ADJUSTING'A'(NABCO) (2) OP -173 3
24 44149-H3300 SHIM-ADJUSTING'A' (NABCO) (2) OP 0273- 0 44149-31700
24 44149-U4010 PLATE-LOCK (TOKIKO) (2) OP 0273-
25 44150-31700 SHIM ADJUSTING'B'(NABCO) (2) OP
26 44144-18000 COVER-DUST'B'(NABCO) (2) OP -173 3
26 44144-U4000 COVER-DUST'B' (NABCO) (2) OP 0273- 0 44144-18000
26 44144-U4010 COVER-DUST'B' (TOKIKO) (2) OP 0273-
27 44100-H0525 KIT-REPAIR WHEEL CYLINDER"A"(NABCO) (2) OP -173 3
27 44100-H3325 KIT-REPAIR WHEEL CYLINDER (NABCO) (2) OP 0273- 0 44100-H0525
27 44100-H3327 KIT-REPAIR WHEEL CYLINDER (TOKIKO) (2) OP 0273-
28 44100-H0526 KIT-REPAIR WHEEL CYLINDER"B"(NABCO) (2) OP -173 3
29 44200-18000 ASSY-ADJUSTER REAR BRAKE (2) OP
30 44204-18000 WEADGE-ADJUSTER (2) OP
31 44205-18000 TAPPET-ADJUSTER (4) OP
32 08915-13610 WASHER-LOCK M6 (4) OP
33 08911-10610 NUT-HEX M6X1.0-2 (4) OP
