Tower bar
Revision as of 10:54, 9 November 2015; view current revision
Category: Suspension Modifications
A strut tower bar is a cool-looking piece of hardware that ties the two strut towers together. Also known as strut bar, dampener, damper bar, strut brace, or Monte Carlo bar. The performance theory is that it reduces chassis deformation on hard cornering.
B110 strut-top bolt circle is the same as other Nissans: 122mm diameter
Nismo
Low and high versions
* Flat
* Round
* Round with taper ends
Cusco Type ST steel shaft クスコ タワーバー (part number 204 510 A) - clears A14/A15 engine
Mad Dat Strut Brace
Mad Dat Tri-bar Strut Brace
Dimensions
1200 strut-top bolt circle: 122mm diameter
B110/B120 strut width center-to-center
936 mm (36.85 inch)
Strut Top bar ends
1609.jpg 1653.jpg 1936.jpg 2000.jpg 2397.jpg 2398.jpg 2400.jpg 2443.jpg 2672.jpg 2812.jpg 2825.jpg 4011.jpg 4053.jpg 4064.jpg 4700.jpg 6718.jpg 9430.jpg 10079.jpg 10364.jpg 10365.jpg 10369.jpg 10957.jpg 10977.jpg 10978.jpg 10987.jpg 11586.jpg 12329.jpg 12888.jpg 12909.jpg 13492.jpg 13790.jpg 14223.jpg 15854.jpg 15859.jpg 15878.jpg 16217.jpg 16510.jpg 16511.jpg 16512.jpg 16854.jpg 16855.jpg 17177.jpg 17945.jpg 17946.jpg 19090.jpg 19126.jpg 19127.jpg 19397.jpg 19398.jpg 19399.jpg 19946.jpg 19947.jpg 20008.jpg 20810.jpg 21121.jpg 22268.jpg
strut_brace
Uploads
photo: photo: photo: photo: photo: photo:
tower bar,strut bar,dampener,damper bar,brace,Monte Carlo bar not steering
