Also see: Part Numbers Index Main article for usage, photos, cross-reference Window Regulator for Window Winder/Regulator Handle Door Lock (door latch and door handle) Rear Door Glass
For rear door corner glass, see Rear Door Part Numbers
SEDAN REAR DOOR WINDOW 1 82310-H1000 GLASS-rear door (R.H.) STD 82310-H1100 GLASS-rear door (R.H.) DX,GL,GX 82311-H1000 GLASS-rear door (L.H.) STD 82311-H1100 GLASS-rear door (L.H.) DX,GL,GX 2 82302-H1000 ASS'Y-BOTTOM, channel (R.H.) 82303-H1000 ASS'Y-BOTTOM, channel (L.H.) 3 82316-H1000 RUBBER-glazing (2) 4 82335-H1000 RUBBER-glass run "C" (2) < 82335-H1001 82335-H1001 RUBBER-glass run "C" (2) (from '70-Oct)
VAN REAR DOOR WINDOW
1 82310-H1400 GLASS-rear door (R.H.) VS,VP
82310-H1500 GLASS-rear door (R.H.) V-DX
82311-H1400 GLASS-rear door (L.H.) VS,VP
82311-H1500 GLASS-rear door (L.H.) V-DX
4 82335-H1400 RUBBER-glass run "C" (2)
REAR DOOR LOCK & REMOTE CONTROL (4 DOOR SEDAN & VAN)
* 82500-H1001 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (R.H.) <> 82500-H1102
82500-H1002 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (R.H.) (from '71-Jan)
* 82501-H1001 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (L.H.) < 82501-H1102
82501-H1002 ASS'Y-DOOR LOCK & REMOTE CONTROL, rear (L.H.) (from '71-Jan)
5 82502-H1001 ASS'Y-DOOR LOCK, rear (R.H.) <> 82502-H1002
82502-H1002 ASS'Y-DOOR LOCK, rear (R.H.) (from '71-Jan) <> 82502-H3100
82502-H3100 DOOR LOCK ASS'Y, rear (R.H.) (from '72-8)
82503-H1001 ASS'Y-DOOR LOCK, rear (L.H.) <> 82503-H1002
82503-H1002 ASS'Y-DOOR LOCK, rear (L.H.) (from '71-Jan) <> 82503-H3100
82503-H3100 DOOR LOCK ASS'Y, rear (L.H.) (from '72-8)
6 80504-H1001 ASS'Y-REMOTE CONTROL, front door (R.H.)
80505-H1001 ASS'Y-REMOTE CONTROL, front door (L.H.)
7 80508-H1000 SPRING-door lock (R.H.)
80509-H1000 SPRING-door lock (L.H.)
fixing door lock
8 08320-61219 SCREW-with lock washer (6)
or, fixing door lock
8 08320-61012 SCREW (6)
9 08916-43610 WASHER-tooth lock (6)
fixing remote control
10 08310-61226 SCREW-with washer (6)
or, fixing remote control
10 08310-61214 SCREW-with washer (6)
11 08915-43610 WASHER-plain (6)
REAR DOOR HANDLE (4 DOOR SEDAN & VAN) 12 82605-H1000 ASS'Y-HANDLE, door outside (R.H.) 82606-H1000 ASS'Y-HANDLE, door outside (L.H.) 13 01221-00023 NUT (4)
REAR DOOR REGULATOR (4 DOOR SEDAN & VAN)
14 80760-H1000 ASS'Y-HANDLE, door window regulator (2)
15 80675-H1000 WASHER-handle, door regulator (2)
16 08330-51220 SCREW (2)
17 82700-H1000 ASS'Y-REGULATOR, rear door window (R.H.) <> 82700-H1001
82700-H1001 ASS'Y-REGULATOR, rear door window (R.H.)
82701-H1000 ASS'Y-REGULATOR, rear door window (L.H.) <> 82700-H1001
82701-H1001 ASS'Y-REGULATOR, rear door window (L.H.)
fixing regulator
18 08310-61014 SCREW-with lock washer (6)
Or, fixing regulator
18 08310-61012 SCREW (6)
19 08915-13610 WASHER-lock (6)
20 80570-21000 ASS'Y-STRIKER, door lock (R.H.)
80571-21000 ASS'Y-STRIKER, door lock (L.H.)
21 80571-24800 SHIM-striker (2)
fixing striker
22 08360-61614 SCREW-with lock washer
or, fixing striker
22 08440-61212 SCREW (6)
23 08916-33610 WASHER-tooth lock (6)
24 80510-H1000 ESCUTCHEON-remote control (R.H.)
80511-H1000 ESCUTCHEON-remote control (L.H.)
25 08330-50620 SCREW (fixing escutcheon) (2)
26 80595-21003 KNOB-door lock (2) <> 80595-N1600
80595-N1600 KNOB-door lock (from '71-Apr) (2)
27 80970-21000 GROMMET-knob (2)
28 80515-E0100 BUSH-bell crank (2)
fixing bell crank
29 08310-61414 SCREW-with washer (2)
30 08915-53610 WASHER-plain (2)
31 H0510-21001 HOLDER-rod (nylon) (2)
32 80517-H1000 SHIELD-inside handle (2)
