Prochem Performer 405 truckmount http://www.youtube.com/watch?v=jdyLKlyDV30 A15 engine carbureted 65 hp OR A12 Industrial Nissan Engine 32hp
A15 governer $1009 2002 PowerVac II (48hp) 2002 Performer (48hp) 2002 Performer 405 (48hp)
Everest truckmount A15 Zenith EFI fuel injection (ZEEMS)
Zenith Power Products
http://zenithpp.com/engines_a15.htm
Intermittent output (SAE Gross J1349) 46 HP/3,600 rpm Continuous output (SAE Gross J1349) 39 HP/3,600 rpm Peak torque (SAE Gross J1349) 11 kg-m (80 ft-lb)/2,200 rpm Minimum fuel consumption 225g/Hp-hr (0.496 lb/HP-hr)/3,200 rpm Fuel and type Gasoline, 4-cycle, O.H.V. Cylinder arrangement 4 in-line Combustion chamber Wedge shape Bore x stroke 76mm x 82mm (2.99 x 3.23 in) Total piston displacement 1,487 cc (90.74 cu in) Compression ratio 9.0 : 1 Length x width x height (standard model) 527.8 x 530.8 x 576.3mm (20.78 x 20.90 x 22.69 in) Dry weight (standard model)* 103kg (227 lb)
