Side Glass
Revision as of 06:34, 28 September 2017; view current revision
Category: Body
B110 2-door sedan has large popout side windows, B110 while 2-dr coupe has smaller popout glass. 2-dr Van has a rectangular popout.
Also see Glass#Door_Glass
[hide]
1972 USA Owners manual (Page 07 ... ):
fresh air in any weather
Also see: Ventilation
sedan | coupe
24623.jpgAlbum 24623 24624.jpgAlbum 24624
Van rear side window is fixed, while 2-dr Van middle side window is popout-type.
10903.jpgAlbum 10903 24635.jpgAlbum 24635
All popout-type windows use the same inside handle, but it bolts to the glass in different way on the Coupe.
23143.jpgAlbum 23143
Sedan & Van use seperate hinges bolted to the glass, while coupe has hinges welded to the glass frame.
Also see: Rear Window Part Numbers
Coupe
Swing-out glass
3252.jpgAlbum 3252
C-pillar trim off
14545.jpgAlbum 14545
Custom silver frames:
20056.jpgAlbum 20056
8652.jpgAlbum 8652
Rubber
On the B110 welt and seal are two different pieces. On the B310, it is one piece.
  • The B310 2-door sedan seal will probably work when cut to length
  • EDP used Trimlok 3/4" TrimSeal + 5/8 vinyl tube on his Coupe
  • Rockon used a similar pinch weld rubber from Clark rubber
TrimSeal with reinforcing tube fitted POST discussion
174_56ba74b1d3fff.jpgUpload click to view 174_56ba74b8a2bf4.jpgUpload click to view 174_56ba74c38560b.jpgUpload click to view 174_56ba74e60f4ab.jpgUpload click to view
Sedan
4-door
Sedan has fixed "quarter windows" in the rear doors.
See main article: Doors#Door_Glass
2-door
* Tinted
* Non-tinted
* Laminated or non-laminated
76822-H1301 GLASS-SIDE WINDOW RH TINTED & TEMPERD T=
Rubber
B110 has a window seal (weatherstrip) that's glued to the outside of the frame, and an inside cover (welt) for the frame.
76802-H1202 WEATHERSTRIP-SIDE WINDOW RH
76803-H1202 WEATHERSTRIP-SIDE WINDOW LH
76922-H1200 WELT-SIDE WINDOW BLACK #698 (2) COUPE, SEDAN 2-DOOR
generic aftermarket Welt can be used:
B310 weatherstrip fits with some trimming:
23617.jpgAlbum 23617
B310 83830-H8600 WEATHERSTRIP-SIDE WINDOW RH (BLACK 002G0 $84.53 USD
B310 83831-H8600 WEATHERSTRIP-SIDE WINDOW LH (BLACK 002G0 $84.53 USD
B310 uses a one-piece seal. B310 weatherstripping can be used for B110 2-dr sedan rear side window weatherstripping. It's almost perfect, but about 1 inch too short for the B110. Surprisingly, the B110 glass is actually larger! Just trim a bit of it off when fitting to the B110.
Reportedly, 1997-2003 F150 fits when cut to length
26325.jpgAlbum 26325
Hinges
The hinges are spring metal
24615.jpgAlbum 24615
Hinges - big washer goes under the hinge
24621.jpgAlbum 24621
76832-H1201 HINGE-SIDE WINDOW (4) SEDAN 2 DOOR
 24616.jpgAlbum 24616 24617.jpgAlbum 24617
76828-H1200 COVER-SIDE WINDOW HINGE
 9988.jpgAlbum 9988
B310 Hinges are identical except for additional tab for hinge cover
24619.jpgAlbum 24619
Hinge Comparo
24622.jpgAlbum 24622
Grommet (Finish Nut) Comparo. B310 units do not interchange
24620.jpgAlbum 24620
B310 grommets can be used if B110 rubber washers are employed
Do B210 hinge covers fit?
9990.jpgAlbum 9990 22110.jpgAlbum 22110
Latches
76870-H1200 ASSY-HANDLE SIDE WINDOW LH COUPE,SEDAN 2-DR
76872-18000 PIN-HANDLE SIDE WINDOW
B310 Handle comparo (does not interchange):
B210 latches are same Right/Left. Do they fit B110?
76860-H5300 HANDLE ASS'Y-side window COUPE, VAN-2DR, SEDAN-2DR
Van
2-door Van
Datsun 1200 2-dr wagon has popout side glass in the spot where the rear passenger doors are on the 4-dr van.
753.jpgAlbum 753 421.jpgAlbum 421 24635.jpgAlbum 24635
Same handle as the others
Same hinges and grommets as Sedan
2-door wagon also has a fixed rear side window. A bar runs across the inside to guard it. It is identical to the 4-door except for the weatherstripping and Guard Bar.
4-door Van
Wagon has fixed "quarter windows" in the rear doors.
Wagon also has a fixed rear side window. A bar runs across the inside to guard it.
620 Pickup
Datsun U620 ute uses same Hinges as B110 Van/Sedan
24634.jpgAlbum 24634
76846-H1201 WASHER [window glass]
