Block Heater
Revision as of 19:36, 14 March 2025; view current revision
Category: Cooling System
Keep Sunny happy on cold nights with a Genuine Datsun Accessory Part. Granted it is a rare thing which most cold Americans have never seen. It is really only needed when temps are far far far below 0 Celcius. Even so I reckon it'd be nice to jump in the ol 1200 and floor it without having to wait for a brief warmup period.
15220.jpgAlbum 15220
Yes it ran on 110v US.
Yes it is still available, at about $20.00 USD
Part # 99998-10242. This part # applies to US model (just about everything) B210 '74 to '78. It wi\l actually fit most Nissan blocks except some L-series 4-cylinder motors for some reason.
15221.jpgAlbum 15221
Obviously you fit it into one of the welch plugs so it sits in the coolant, & when it's below freezing, you turn it on to heat the coolant before starting. Or maybe you keep it turned on all night so the coolant doesnt freeze & split the block.
They are mostly used in extreme cold climates, e.g. Alaska and Minnesota where temps can reach -40 F (below freezing temperature of anti-freeze). Although in mountain areas everywhere they are well known.
99990-00032
Fits A10 and A12 and B210 with A13 or A14, so it should them all. All A12A/A14/A15 use the same frost plugs
with square connector. Genuine Datsun Accessory Part No. 9999000032 (99990-00032) MADE IN CANADA
99990-00032a.thumb.jpg.77cd00438d023dc442d115bc9ec8afbc.jpg 99990-00032d.thumb.jpg.b1afd6ad20f3ee322c3243a92aa65078.jpg 99990-00032b.thumb.jpg.703ed6abe5d6c060c0a7705d5ee557b9.jpg 99990-00032c.thumb.jpg.da09b32454b3c9ab3374ee1ad6da874a.jpg
WARNING! Before connecting heater to power source, make sure that the element is immersed in coolant
IN. LBS. TORQUE 20
Model      Location Point element
1000   1969-70 LEFT FRONT UP
LB110  1971-73
KLB110
B210   1974-75
1600   1966-71 OHV [Roadster & 411]
240Z   1970-73 3rd. HOLE RIGHT SIDE UP
260Z   1974    RIGHT FRONT UP
280Z   1975-77 3rd. HOLE RIGHT SIDE UP
F10    1976-77 LEFT FRONT UP
NISSAN AUTOMOBILE CO. (CANADA) LTD.
VANCOUVER BRITISH COLUMBIA
478C 28-6.77
99990-00033
For L-series four-cylinder engines L13/L14/L16/L18/L20B
