The Datsun 1200 cylinder head gasket fit A12 and A10 engines. Aftermarket gaskets vary in material and size of cooling holes.
Also See: * Changing Head Gasket * Tune-upNissan recommends re-torquing the head gasket bolts ever twenty-four months (every two years):
1972 USA Owners manual (Page 34 ... ):
Retighten cylinder head bolts, manifold nuts & carburetor securing nuts.
Blown Gasket
When a head gasket is blown out (partly missing) between cylinders it is obvious, and the engine will run on "two cylinders" (barely run, if at all).
But head gaskets more often fail in a less obvious manner -- they lift up enough to allow compression to leak past, causing low compression. An Engine compression test will find this.
A more rare failure is of the oil or water passage. The engine will still run perfectly, but oil will leak or coolant will be lost. A Cooling System Pressure Test can often pinpoint the diagnosis.
Coolant leaking into the oil pan, causing "milkshake" to be visible on the oil cap and dipstick
11044-18004 GASKET-CYLINDER HEAD A12 superceeded![]()
11044-H1000 GASKET-CYLINDER HEAD A12 11044-H1000 GASKET-cylinder head B110, B210 to '75-4 11044-H1025 B210 from '75-5 11044-H1026 11044-H1027 11044-H3900 GASKET-CYLINDER HEAD A12 0671-
fits: A10 PULSAR 1000 BN10 988cc 1978-ON A10 SUNNY 1000 B10,B20 1000 1966-1970 A12 SUNNY 1200 B110,B210,C20 1171cc 1970-73.3 A12 SUNNY 1200 B210 1973.4-75 A10 CHERRY 1000 E10, F10 988 1970.10-73.9 A12 CHERRY 1200 PE10, F10 1171cc 1972-78
11044-H2300 A12GX, A12T 11044-H2301 [thinner?] A12GX, A12T 11044-H2325 A12GX from '72-6![]()
Head Set
11044-H3926 KIT-GASKET,CYLINDER HEAD 11042-H3927 KIT-GASKET,CYLINDER HEAD
Head Set gasket includes all you need to change the head:
Cylinder head gasket Valve stem seals Rocker cover gasket Gasket-manifold to cylinder head
it may include the following:
thermostat gasket intake-to-exhaust manifold gasket (heat riser gasket) oil cap packing (gasket) fuel pump gaskets
Gasket Head Set * Victor HS3602 * FEL-Pro HS21181PT * ROL HS32060
GX Metal
Nissan Competition
11044-M0821 COMPETITION HEAD GASKET
Gasket has a bore diameter of 79mm/3.11", an uncrushed thickness of 0.8mm/0.032" and displaces 3.9cc's.
Nismo head gaskets for Nissan A series motor A12,A13,A14,A15 Engine
11044-M0822 t=0.8 79.0 mm bore diameter 11044-M0823 t=0.6 80.0 mm bore![]()
Spacer Gasket
シリンダーヘッドガスケット
