Manifold Part Numbers
Revision as of 05:40, 4 September 2017; view current revision
Categories: Engine Mechanical | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Manifold
 1 14003-H1900 MANIFOLD-INTAKE A12 EXHAUST -571
 1 14003-H1901 MANIFOLD-INTAKE A12,CALIFORNIA 0671-0771 0 14003-H1900
 1 14003-H3900 MANIFOLD-INTAKE A12,MANUAL 0771- 5 14003-H1900
 1 14003-H3901 MANIFOLD-INTAKE A12,AUTO 0771- 5 14003-H1901
 1 14003-H1000 MANIFOLD-INTAKE A12 CRANK
 2 08216-62210 STUD FIXING CARBURETOR (4) A12
 3 14004-H1930 MANIFOLD-EXHAUST A12 EXHAUST
 3 14004-H3931 MANIFOLD-EXHAUST A12 0373- 4 14004-H3930
 3 14004-H3950 MANIFOLD-EXHAUST A12 0671-
 3 14004-H1030 MANIFOLD-EXHAUST A12 CRANK -273
 3 14004-H3930 MANIFOLD-EXHAUST A12 -273 2 14004-H3950
 4 08213-82810 STUD FIXING EXHAUST MANIFOLD TO EXHAUST (2) A12
   14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD A12 14005-18000
 5 14005-18000 GASKET-INTAKE TO EXHAUT MANIFOLD A12
 6 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD (2) A12
 7 01111-00032 BOLT A12
 8 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD (3) A12
 9 08911-10810 NUT CYLINDER HEAD TO MANIFOLD (9) A12
10 08915-13810 WASHER-LOCK (5) A12
11 14037-32200 YOKE-MANIFOLD (4) A12
   14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD A12 14035-18000
12 14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD A12
13 14022-18000 SPRING-HEAT CONTROL THERMS A12
14 14025-85061 KEY-HEAT CONTROL VALVE A12
15 14026-18001 WEIGHT-COUNTER VALVE A12
16 14027-36700 WASHER-HEAT CONTROL A12
17 14047-36700 SPRING-STOPPER HEAT CONTROL A12
   00933-1101A PLUG-WELCH A12 00933-11000
18 00933-11000 PLUG-WELCH A12
19 08310-51610 SCREW-SET A12
20 14006-18000 PIN-SPRING HEAT CONTROL TO INTAKE MANIF A12
21 16174-H1000 INSULATOR-CARBURETOR A12
21 16177-H1000 KIT-JOINT SEAT A12
21 16174-H3900 INSULATOR-CARBURETOR A12 0671-
21 16177-H3900 KIT-JOINT SEAT A12 0671-
22 08915-13610 WASHER-SPRING (4) A12
23 08911-10610 NUT-HEX M6 (4) A12
1973 LB110 USA Parts Catalog
