Here is a list of Nissan Part Numbers that are No Longer Available from Nissan.
Still Available
Summary of major suprises, not an exhaustive list
Nissan USA
- Engine short block
- Engine gasket kit
- Cylinder Head
- Pistons
- Crankshaft
- Connecting Rods
- Oil Pump
- Flywheel
- Exhaust manifold
- Carburetor, and Carburetor Kit
- Mufflers
- Emission Control parts, including flow control valve
- Air Cleaner
- Fuel tank and Fuel sender
- Radiator Shrouds
Nissan Australia
- 74965-H1000 handbrake cover B110
- 74965-H7300 handbrake cover B210 (fits B110, available from Nissan USA)
Nissan Japan
- 11828-H2300 HOSE-air cleaner to pipe connector
- 20603-H2300 GASKET-exhaust tube - GX and GX-5 (B0603-H2300)
- 16546-H2300 ELEMENT ASS'Y-paper (air filter, instead use Unifilter * 16546-H2300 ELEMENT ASS'Y-paper
- 18410-H2301,H2302 WIRE COMP,-choke control GX
- 66802-H1001 GRILLE-COWL TOP RH S-std
- 66803-H1001 GRILLE-COWL TOP LH S-std
- 62330-H3325 EMBLEM SET-radiator grille "GL"
- 62330-H3425 EMBLEM SET-radiator grille "GX"
- 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
- 76854-H1050 EMBLEM-body side "Sunny" S-DX, S-GL,4GX
- 76852-H2001 BADGE-"GL" S-GL
- 76852-H2300 BADGE-"GX" (R.H.) 4-GX
- 76853-H2300 BADGE-"GX" (L.H.) 4-GX
- 84822-H1000 EMBLEM-trunk lid "Sunny 1200" Sedan
- 84823-H3300 MARK-"GL" S-GL
- 84823-H2300 MARK-"GX" 4-GX (exc.5speed)
- 84823-H7200 EMBLEM-"GX-5 SPEED" 5 speed
- C10 GTR emblems
- 96800-H1001 PACKAGE TRAY
- 74980-H3320 CONSOLE BOX ASS'Y-with bracket
- 74982-H1801 FINISHER-console box
- 88320-H1000 TRIM ASS'Y-rear seat cushion - STD 2 Std
- 88620-H3201 TRIM ASS'Y-rear seat cushion (Black) DX S-DX
- 88620-H1000 TRIM ASS'Y-rear seat back STD 2 Std
- 88620-H3201 TRIM ASS'Y-rear seat back (Black) DX S-DX
- 24855-H3100 TACHOMETER ASS'Y (op.) ALL (exc. GX)
- 24855-H3400 TACHOMETER ASS'Y GX
- 24855-H1800 ASS'Y-TACHOMETER 1 (op.) ALL (exc. GX)
- 17229-H1900 HOSE-filler Sedan EVAPO (can use straight hose 17229-H1000, which is available)
- 17230-H1901 HOSE-filler inner Sedan EVAPO
Nissan North America
- 36518-H1001 WASHER-HAND BRAKE CABLE STRAP (to clamp the flexi to the bracket)
- Radiator
- Engine long block
- Camshaft
- Intake manifold
- 76852-H1000 BADGE-"Deluxe"
- 17229-H1900 HOSE-filler Sedan EVAPO (can use straight hose 17229-H1000, which is available ex-Japan)
