Lancer strut swap
Revision as of 03:21, 10 June 2025; view current revision
Categories: Suspension Modifications | Brake Modifications
<-- back to Strut swaps
Mitsubishi Lancer struts into Datsun 1200. With the largest brakes that will fit under a 15" wheel.
HYP014 developed this big-brake swap.
  • Lancer LA or Lancer LB struts
  • Lancer control arms, caster rods and lower ball joints
  • DBA brake rotors 300x28 mm vented discs
  • Z32 300ZX calipers
  • custom-made 60601 hubs to suit the offset
  • Coilover threaded sleeves of 316 stainless with 6061 alloy nuts
  • 200 pound king springs
  • The thrust bearing on top of the springs are genuine Holden items
  • The camber adjusting top plates are all titanium
  • Koni adjustable strut inserts
All this just fits in a 15" rim with 2mm clearance
14800.jpgAlbum 14800 14795.jpgAlbum 14795 14799.jpgAlbum 14799 14798.jpgAlbum 14798 14797.jpgAlbum 14797 14794.jpgAlbum 14794 14793.jpgAlbum 14793 14792.jpgAlbum 14792 14791.jpgAlbum 14791
camber tops
14796.jpgAlbum 14796 14629.jpgAlbum 14629
