<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Radiator
1 21400-H1900 ASSY-RADIATOR 2 21400-H1002
21400-H1003 ASSY-RADIATOR A12 0871- 2 21400-H1900
21400-H1002 ASSY-RADIATOR
21400-H2300 ASSY-RADIATOR GX
21400-H5050 7510-7907 B517 <6,0> 21400-G1660
21400-H9415 *7804-7907 F/OKINAWA <6,0> 21400-G1665
21400-G1600 7908-8910 ELBOW OUTLET B517
21400-G1665 7908-8910 ELBOW OUTLET B517 F/OKINAWA
21400-G1661 8910- ELBOW OUTLET B517
2 21430-10600 ASSY-CAP
21430-89902 ASSY-CAP PADIATOR A12 1272- 21430-U0100
21430-U0100 ASSY-CAP PADIATOR A12 1272-8503 2 21430-10600
21430-89901 8504-8910
21430-89902 8910-
21431-10600 ASS'Y-cap, sub. [without seal]
3 21480-18000 HANDLE-DRAIN COCK -8109 <2,0> 21480-R0100
21480-R0100 COCK-WATER DRAIN 8110-
4 21481-18000 PACKING-DRAIN COCK
21482-18000 SEAT-DRAIN B120 7510-
5 08110-61662 BOLT-HEX,WITH WASHER (4) fixing radiator
6 21501-H1000 HOSE-RADIATOR,UPPER
21501-G1600 HOSE-RADIATOR,UPPER B517 7510-
7 21503-H1000 HOSE-RADIATOR,LOWER [STD, without heater]
8 21506-H1101 ASSY-HOSE,RADIATOR,LOWER,FOR HEATER DX,GL 0970- 21503-H1000,21503-H1100,21504-H1100
21506-H2301 ASS'Y-HOSE, radiator, lower (from '70 Sept.) GX
9 21503-H1100 HOSE-RADIATOR,LOWER,FRONT FOR HEATER DX,GL -0870
21503-H2300 HOSE-RADIATOR,LOWER,FRONT FOR HEATER GX -0870
21503-G1600 7510-7907 B517 <6,0> 21503-G1601
21503-G1601 7908-8910 B517
21503-95W00 8910- B517
10 21504-H1100 HOSE-RADIATOR,LOWER,REAR FOR HEATER DX,GL -0870
21504-H2300 HOSE-RADIATOR,LOWER,REAR FOR HEATER GX -0870
11 08723-13600 CLAMP-HOSE (4)
08723-13800 CLAMP (4) 7510-8504
01555-00033 CLAMP-HOSE (4) 8504- > 08723-13800
12 27075-H1000 CONNECTOR-HEATER OP. 27075-27700
27075-27700 CONNECTOR-HEATER OP.
13 21475-H2300 SHROUD-RADIATOR UPPER AUTOMATIC & JAPAN COOLER
21475-H2300 SHROUD-RADIATOR,UPPER FOR HEAVY DUTY S OP.N USA
21475-G1660 * F/COOLER 7804-7907 <x> 21475-H2300
14 21476-H2300 SHROUD-RADIATOR,LOWER AUTOMATIC
21476-H2300 SHROUD-RADIATOR,LOWER JAPAN COOLER <9,0> 21476-G1660
21476-H2300 SHROUD-RADIATOR,FOR HEAVY DUTY SPEC OP. USA
21476-G1660 * F/COOLER 7804-7907 <x> 21476-H2300
fixing shroud to radiator
15 08513-51612 SCREW-TAPPING M5 (6)
08360-5165C SCREW 7510-
16 08915-43510 WASHER-PLAIN (6)
17 08963-10510 NUT-SPRING M5 (2) USA
21477-C0500 NUT-spring (2) JAPAN
08911-1052A NUT 7510-
1971 B110 Parts Catalog C-173, page 29-1 1973 LB110 USA Parts Catalog 1997 B120 Parts Catalog C-415
