Cowl Top Grille
Revision as of 19:16, 11 September 2018; view current revision
Categories: Fibreglass | Body
The Cowl Top Grille is the vents just below the windshield. Their purpose is to prevent debris from entering the air intakes for the passenget compartment air flow. There are three styles: Coupe, Sedan Standard and Sedan Deluxe. They all have the same screw pattern so can be swapped for a custom look.
20367.jpgAlbum 20367
[hide]
Styles
Sedan (top) VS Coupe (bottom)
14593.jpgAlbum 14593
Coupe style (DX, GL, GX) and Sedan-GX
10071.jpgAlbum 10071 14594.jpgAlbum 14594
NOTE: The metal grile plate under the Coupe "scoop" vents are different to the STD metal vent covers -- they are flat, not raised 5mm like the Standard grille.
Sedan DX/GL style
STD style
1000 (notched) vs 1200 (six-screw type)
16902.jpgAlbum 16902
Colors
Coupe grilles at least were produced in body-matching colors. Sedan grilles appear to have been offered in gray or black. And Std style were painted black or body color.
1901.jpgAlbum 1901
Aftermarket
Bluemax is creating custom cowl top grilles in the coupe style.
120fly was making coupe-style grilles.
14044.jpgAlbum 14044
Bprojects has coupe-style FRP replicas.
13264.jpgAlbum 13264 16938.jpgAlbum 16938 14050.jpgAlbum 14050 14051.jpgAlbum 14051
PB110
Sunny Excellent 1400 (PB110)
174_580aeed364808.jpgPost 482037
85-30412-9 SCREW (fixing cowl top grille, mild steel) 12 per vehicle
Stainless screws look better than factory-spec screws
22480.jpgAlbum 22480
Sedan JDM
Except Sedan GX
85-30412-9 SCREW (fixing cowl top grille) 12 per vehicle
66802-H1001 GRILLE-cowl top (R.H.) S-Dx., S-GL
66803-H1001 GRILLE-cowl top (L.H.) S-Dx., S-GL
66802-H1002 GRILLE-cowl top (R.H.) S-Std
66803-H1002 GRILLE-cowl top (L.H.) S-Std
DX, GL
68803-H1001-2.jpg 2183.jpgAlbum 2183
STD
DX, GL appears to include STD units, but they are slightly different (totally flat)
Sedan USA
66802-H1001 GRILLE-COWL TOP RH $63.33
66802-H2314 GRILLE-COWL TOP RH ORANGE #006 Sedan DX
66802-H2313 GRILLE-COWL TOP RH TURKOIS #005 $58.83
66802-H2312 GRILLE-COWL TOP RH GREEN #004
66803-H1001 GRILLE-COWL TOP RH $60.70
66803-H2314 GRILLE-COWL TOP LH ORANGE #006
66803-H2313 GRILLE-COWL TOP LH TURKOIS #005 $58.83
66803-H2312 GRILLE-COWL TOP LH GREEN #004
Van
66802-H1002 GRILLE-cowl top grille (R.H.) VS, VP
66803-H1002 GRILLE-cowl top grille (L.H.) VS, VP
66802-H1001 GRILLE-cowl top grille (R.H.) V-Dx.
66803-H1001 GRILLE-cowl top grille (L.H.) V-Dx.
Coupe, Sedan GX
85-30412-9 SCREW (fix cowl top grille) 12 per vehicle
08530-41212 SCREW-TAPPING M4 FOR GRILLE FITTING 6 per side
08530-41612 SCREW-TAPPING M4 FOR GRILLE FITTING 6 per side
Coupe part includes the grille and a mesh plate which is flat
22583.jpgAlbum 22583
66802-H1800	GRILLE-COWL TOP RH WHITE #924
66802-H1801	GRILLE-COWL TOP RH YELLOW #926
66802-H1802	GRILLE-COWL TOP RH GRAY #928
66802-H1803	GRILLE-COWL TOP RH GREEN #930
66802-H1804	GRILLE-COWL TOP RH GOLD #931
66802-H1805	GRILLE-COWL TOP RH RED #932
66802-H1806	GRILLE-COWL TOP RH WHITE #821
66802-H1807	GRILLE-COWL TOP RH YELLOW #665
66802-H1809	GRILLE-COWL TOP RH BLUE #645
66802-H1810	GRILLE COWL TOP RH GREEN #940
66802-H2300	GRILLE-COWL TOP RH WHITE #924 (from '70-Nov)
66802-H2301	GRILLE-COWL TOP RH YELLOW #926
66802-H2302	GRILLE-COWL TOP RH GRAY #928
66802-H2303	GRILLE-COWL TOP RH GREEN #930
66802-H2304	GRILLE-COWL TOP RH GOLD #931
66802-H2305	GRILLE-COWL TOP RH RED #932
66802-H2306	GRILLE-COWL TOP RH WHITE #821
66802-H2307	GRILLE-COWL TOP RH YELLOW #665
66802-H2309	GRILLE-COWL TOP RH BLUE #645
66802-H2310	GRILLE COWL TOP RH GREEN #940
66802-H2311	GRILLE-COWL TOP,RH,GREEN #003
66802-H2314	GRILLE-COWL TOP,RH,ORANGE #006
66803-H1800	GRILLE-COWL TOP LH WHITE #924
66803-H1801	GRILLE-COWL TOP LH YELLOW #926
66803-H1802	GRILLE-COWL TOP LH GRAY #928
66803-H1803	GRILLE-COWL TOP LH GREEN #930
66803-H1804	GRILLE-COWL TOP LH GOLD #931
66803-H1805	GRILLE-COWL TOP LH RED #932
66803-H1806	GRILLE-COWL TOP LH WHITE #821
66803-H1807	GRILLE-COWL TOP LH YELLOW #665
66803-H1809	GRILLE-COWL TOP LH BLUE #645
66803-H1810	GRILLE-COWL TOP LH GREEN #940
66803-H2300	GRILLE-COWL TOP LH WHITE #924
66803-H2301	GRILLE-COWL TOP LH YELLOW #926
66803-H2302	GRILLE-COWL TOP LH GREEN #928
66803-H2303	GRILLE-COWL TOP LH GREEN #930
66803-H2304	GRILLE-COWL TOP LH GOLD #931
66803-H2305	GRILLE-COWL TOP LH RED #932
66803-H2306	GRILLE-COWL TOP LH WHITE #821
66803-H2307	GRILLE-COWL TOP LH YELLOW #665
66803-H2309	GRILLE-COWL TOP LH BLUE #645
66803-H2311	GRILLE-COWL TOP,LH,GREEN #003
66803-H2314	GRILLE-COWL TOP,LH,ORANGE #006
12.jpg 19133.jpgAlbum 19133 24193.jpgAlbum 24193
Pickup
66802-H1002 COWL TOP GRILLE, RH
66803-H1002 COWL TOP GRILLE, LH
08530-41212 SCREW-(fixing cowl top grille) (12)
Custom
Tops removed and vents blocked
15662.jpgAlbum 15662
