Accelerator Pedal
Revision as of 03:02, 3 December 2025; view current revision
Categories: Engine Control | Fuel System
The Datsun 1200 Accelerator Pedal (gas pedal, fuel pedal) on mounted to the floor on RHD models, and suspended on LHD models.
Also see:
* Throttle Cable
* Pedal Box
RHD pedal bolts to the floor, whereas LHD pedal hangs free.
5026.jpgAlbum 5026 14333_5aa387126c32d.jpgUpload click to view
Throttle Cable ball-end fits into slot on end of Accelerator Pedal. Usually a clip goes over the cable ball-end. But as long as the cable is properly adjusted you can drive it for years without the clip.
25874.jpgAlbum 25874
Right-Hand Drive
5227.jpgAlbum 5227
31437.jpgAlbum 31437 31438.jpgAlbum 31438
The Arm is similar to LHD, but has no pedal welded on, and the spring is in a different spot.
25880.jpgAlbum 25880 174_508e0003f17c0.jpgUpload click to view 25881.jpgAlbum 25881
POST Vanilla Ice ute build USA
18010-H1010 ARM-COMP,accelerator pedal AUTOMATIC
* includes:
  18100-H1010 ARM ASS'Y,accelerator pedal AUTO
  18021-H1000 BRACKET-ACCELERATOR PEDAL
  SNAP RING
 18010-H1000 LEVER ASSY-PEDAL [MANUAL]
 * includes
   18215-27700 SPRING-PEDAL ROD
   18135-14800 BUMPER-ACCELERATOR
   18021-H1000 BRACKET-PEDAL LEVER
   08310-51014 SCREW
   18137-10600 RING-SNAP
18110-H1000 PEDAL-ACCELERATOR [foot rest]
* 08310-51214 SCREW (2)
* fixing pedal stopper
  08360-63512 SCREW
  08911-30610 NUT
08360-63512 SCREW
  36 Machine screw, Hexagon head
    06 size M6
       35 mm long
21944.jpgAlbum 21944
Left-Hand Drive
LHD 1200s use the modern-style suspended throttle pedal. B210 RHD looks similar but is straight (B110 has a dogleg bend above the pivot).
Center-hung pedal assembly
25879.jpgAlbum 25879 25875.jpgAlbum 25875 8197.jpgAlbum 8197
Pedal stopper
25876.jpgAlbum 25876 25877.jpgAlbum 25877
Pedal bumper (just below Throttle Cable clip)
25878.jpgAlbum 25878
18010-H1902 COMP-ARM ACCELERATOR PEDAL AUTOMATIC
18100-H1602 ASSY-ARM ACCELERATOR PEDAL AUTO
18010-H1602 COMP-ARM ACCELERATOR PEDAL MANUAL
18100-H1902 ASSY-ARM ACCELERATOR PEDAL MANUAL
Above assemblies include:
* 18017-H1600 PAD-ACCELERATOR PEDAL
* 18021-H1600 BRACKET-ACCELERATOR PEDAL
* 18215-H1601 SPRING-RETURN ACCELERATOR
* 18137-10600 RING-SNAP E TYPE
* 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX
* 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER
* 18056-H1600 BOLT-PEDAL STOPPER
Automatic Transmission
21635.jpgAlbum 21635
See Engine Control Part Numbers
