Competition Oil Pump
Revision as of 00:33, 14 October 2019; view current revision
Category: Engine Lubrication System
Nissan Competition Oil pump can in two varieties: 1) high pressure/high volume and 2) dry sump version.
[hide]
The Nismo Competition oil pump generates an oil pressure of over 100psi and does not self-prime. It has two gears instead of the standard pump's geroid type (trochoid pump).
5917.jpgAlbum 5917 5927.jpgAlbum 5927 8004.jpgAlbum 8004
standard trochoid 19.5 litre/minute @ 4000 rpm
M0821 gear pump   26.1 litre/minute @ 4000 rpm
Instead of a rotor with lobes on it there are two gears that pump the oil. It also has oil cooler connections on the exterior of the pump.
sany1150m.jpgPost click for topic 5226.jpgAlbum 5226
The Oil Filter points down, exactly like the stock pump
14742.jpgAlbum 14742 9528.jpgAlbum 9528
Dry Sump Type
Part number 15010-M0821 is an A-series competition oil pump with a second stage. Looks just like any dry sump pump driven off of the camshaft. Per Nissan, the dry sump lubrication system is especially effective in long distance races.
M0821 pump
305_4b0b78fa1185f.jpgPost 292450
The oil filter faces UP toward the cylinder head.
Oil Pump with upright filter boss was originally designed for Cherry FF (FWD) race car
21714.jpgAlbum 21714
Oil Cooler
High Volume Pump
Instead of purchasing the Competition high-pressure/high-volume pump, You can make a hybrid high volume oil pump, by using an L-series rotor, which (being thicker) results in extra volume.
From 1984 Nissan Competition Catalog
  • Lubrication (A-series)
    • Competition Oil Pump
High Pressure Pump
  • 15010-25720 COMPETITION OIL PUMP Generates an oil pressure of over 100psi and does not self prime
  • 15010-M0820 COMPETITION OIL PUMP (FWD) Similar to 15010-25720 except unit is designed for FWD Datsuns with A-series engines
  • 11710-H5720 ALTERNATOR BRACKET For use on B210 and 210 models when installing 15010-25720 oil pump
  • 15025-25720 GASKET FOR COMPETITION OIL PUMP T= 0.10mm (Yellow)
  • 15025-25721 GASKET FOR COMPETITION OIL PUMP T=0.12mm (Blue)
  • 15025-25722 GASKET FOR COMPETITION OIL PUMP T = 0. 1 4mm (Green)
Dry Sump Pump
Competition198438.jpg* 15010-M0821 DRY SUMP OIL PUMP Similar to 15010-25720 except has additional fittings for dry sump system
* 15025-H5720 GASKET FOR DRY SUMP OIL PUMP T = 0. 10mm (Yellow)
* 15025-H5721 GASKET FOR DRY SUMP OIL PUMP T = 0. 1 2mm (Blue)
* 15025-H5722 GASKET FOR DRY SUMP OIL PUMP T = 0. 14mm (Green)
Dry Sump Kit
From Datsun 120A Sports Option Parts model KPE10 Series (1 Nov 1974)
Dry Sump Parts
25427.jpgAlbum 25427
 1 15010-M0821 ASSY-PUMP Oil Dry Sump
 2 15208-H1010 ASSY-FILTER Oil
 3 08130-89010 BOLT-Hex M8x90
 4 08130-89510 BOLT-Hex M8x95
 5 08130-80010 BOLT-Hex M8x100
 6 15260-M0820 ASSY-TANK Oil Dry Sump 7 litre
 7 21305-M0820 ASSY-COOLER Oil
 8 21356-M0819 ASSY-HOSE Flexible L=320 mm
 9 21356-M0820 ASSY-HOSE Flexible L=390 mm (2)
10 21356-M0821 ASSY-HOSE Flexible L=275 mm
11 11125-14610 KIT-TANK Oil Catch 2 litre
Oil Catch Tank
From Nissan/Datsun Sports Option Parts model YN10,HN10 series (20 Aug 1982)
Oil Catch Tank
25428.jpgAlbum 25428
OIL CATCH TANK PARTS
1 11125-K0475 TANK KIT-Oil Catch 2 litre, Resin
2 11136-H2310 TANK ASSY-Breather Return
3 11131-H2310 HOSE-Breath L=1000, 9 (ID), 22 (OD)
4 11132-H2310 HOSE-Breath L=1000, 19 (ID), 27 (OD)
5 11133-H2310 HOSE-Breath L=1500, 25.4 (ID), 34 (OD)
