Kicking plate (キッキング プレート) is the door jamb. Also known as 'scuff plate' or threshold plate. The door sill is the exterior panel, while the kicking plate is the interior trim.
| Contents |
Kicking plate is made of aluminum. Early and late differ.
4-door sedan set (long pieces are same as Truck)
Notches fit over the floor stringer and seat bracket.
Custom
Sources
Early
Early plates have no screw holes on the top surface.
Short Doors
74951-H1000 PLATE-kicking, front (R.H.) 4-dr (Sedan/Van), Truck 74952-H1000 PLATE-kicking, front (L.H.) 4-dr (Sedan/Van), Truck 74953-H1000 PLATE-kicking, rear (R.H.) 4-dr (Sedan/Van) 74954-H1000 PLATE-kicking, rear (L.H.) 4-dr (Sedan/Van) 74955-H1000 PLATE-kicking, center (2) 4-dr (Sedan/Van) 85-40412-12 SCREW (8)
Long Doors
74951-H1200 JDM PLATE-kicking, front (R.H.) 2-dr (Sedan/Coupe) 74952-H1200 JDM PLATE-kicking, front (L.H.) 2-dr (Sedan/Coupe) 85-40412-12 SCREW (fixing kicking plate) (8)
Late
From Dec 1971, uses more screws than early plates.
Short Doors
74951-H3100 1972 PLATE-kicking, front (R.H.) 4-dr (Sedan/Van), Truck 74952-H3100 1972 PLATE-kicking, front (L.H.) 4-dr (Sedan/Van), Truck 74953-H3100 1972 PLATE-kicking, rear (R.H.) 4-dr (Sedan/Van) 74954-H3100 1972 PLATE-kicking, rear (L.H.) 4-dr (Sedan/Van) 74955-H3100 PLATE-kicking, center (2) 4-dr (Sedan/Van) 08540-41212 SCREW (24) 4-dr 08540-41212 SCREW (14) Truck (pickup/ute)
Ute sills: 4 side screws, 3 top screws per side (7 per side, 14 per truck)
Long Doors
74951-H3600 1972 PLATE-kicking, front (R.H.) 2-dr (Sedan/Coupe/Van) 74952-H3600 1972 PLATE-kicking, front (L.H.) 2-dr (Sedan/Coupe/Van) 08540-41212 SCREW (fixing kicking plate) (16)
Early to Nov 1971 - 4 screws per side 74951-H1200 74952-H1200 08540-41242 SCREW-TAPPING M4 (4)
Late from Dec 1971 - 8 screws per side 74951-H3600 PLATE-KICKING FRONT RH SEDAN 2DR, COUPE $27.67 USD 74952-H3600 PLATE-KICKING FRONT LH SEDAN 2DR, COUPE $25.17 USD 08540-14242 SCREW-TAPPING M4 (8)
