Radio mounting
Revision as of 06:07, 26 March 2025; view current revision
Categories: Body Electrical System | Options
<-- Back to Radio
The radio mounts in the center of the dashboard, and is covered by the Dash Fascia.
Stock Location
The Datsun 1200 radio fits in the center of the dashboard above the ventilation controls.
5023.jpgAlbum 5023 2126.jpgAlbum 2126
Dash frame
The front is supported by the two shafts ("shaft mount") and secured by a 2nd set of shaft nuts, which clamp the shafts to the dash
28323.jpgAlbum 28323
The rear is hung from an intermediate bracket
30291.jpgAlbum 30291
Dash frame bracket
DIN Chassis
Most modern stereos are DIN-mounted, requiring you to use an alternate mounting location, or cut the metal dash to fit it.
#Console or #Glove Box
Dash
572.gifAlbum 572
DIN chassis mount will fit in the 1200 dash if the dash frame opening is cut out a bit
286.jpgAlbum 286 1411.jpgAlbum 1411 2192.jpgAlbum 2192 6655.jpgAlbum 6655 9979.jpgAlbum 9979 12633.jpgAlbum 12633
amplifiers mounted in rear-seat area
2250.jpgAlbum 2250
Fitting
Also See: Main Forum discussion
DIN-mount radios are the same size as the original, but do not have shafts in the front. Instead they attach at the sides of the radio.
24075.jpgAlbum 24075
First, cut out the facia. Cut out the metal around the radio to fit a modern DIN-chassis receiver:
23172.jpgAlbum 23172
Rectangle cut larger, radio shaft holes now missing
Compare to an uncut dash:
24074.jpgAlbum 24074
Fabricate a DIN adapter bracket (or modify a commercial one).
Create a bezel, by modifying the stock radio delete plamote:
5304.jpgAlbum 5304
Carefully cut the center out of the delete plate:
26882.jpgAlbum 26882
Fit the bezel to the radio:
26881.jpgAlbum 26881
Finished product:
26880.jpgAlbum 26880
Alternate Mounting Locations
In center Console
834.jpgAlbum 834 4823.jpgAlbum 4823
Receiver in glovebox door
6655.jpgAlbum 6655 12040.jpgAlbum 12040
Glove Box
If you prefer not to cut the sheet metal on the Instrument Panel, you can mount it in the Glove Box:
6655.jpgAlbum 6655 22386.jpgAlbum 22386 12040.jpgAlbum 12040 3976.jpgAlbum 3976 3977.jpgAlbum 3977
Console
Mounted in the console, some modification required:
4823.jpgAlbum 4823
amplifiers, equalizers, CD players, stereo, head unit
