Datsun 1200 Sedans were fitted with a stainless metal grille. 1200 Pickups from 1971-1977 use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Also see: Grille Overview
Original Grille
Emblems
Sedan grille "D" and "S" emblems (marks, Badges)
Fitting
Click for full size pictures of the grille mount points:
Fitting to Others
Fitting Sedan grille is done in Japan to nearly all Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit it to a Coupe.
- Fit one L-shaped bracket to center top of front body
- Drill four holes in radiator support
- Fit two thin brackets to back of sedan grille
- Screw grille with sheet loops to front of car
- Fit the headlight surrounds
I believe all core supports have the inner two eyebrow mount holes. But coupe and late ute are missing the outer bracket.
1972 Minor Facelift
The 1972 JDM facelift introduced a new grille for sedans.
