License Lamp
Revision as of 08:22, 18 December 2009; view current revision
Categories: Body | Body Electrical System
Sedan
Sedan light fits into the top of the bumper, and illuminates the plate from below.
Assembly
Cover and Lens
Frame is marked "IKI 6001 JAPAN"
Lens is marked "SAE 170 IKI 6001 JAPAN"
  • 26510-H1000 LAMP ASS'Y-licence
    • 10W bulb
  • 26511-H1000 LENS
  • 26512-H1000 COVER
    • 08310-41420 SCREW (2)
  • 26513-H1000 PACKING
Coupe
Two are used on each coupe, hidden under the bumper, one above each license plate bolt. You can see the holes in this photo:
Coupe lamps are not normally visible until turned on!
Lens needs cleaning?
Pickup
Datsun 1200 ute uses same license lamp as coupe:
Marked "SAE L 69", "IKI 6003" and "JAPAN" and "455"
Placement: Like the coupe they are hidden from normal view.
  • 26510-H1800 LAMP ASSY-LICENSE, RH
    • takes 7.5W bulb
  • 26511-H1800 LENS-LICENSE LAMP, RH
    • 08310-61412 SCREW
  • 26513-H1801 PACKING-LENS
Wagon
VB110 uses a single large chrome license lamp just above the number plate:
  • 26510-H1400 LAMP ASS'Y-license
    • 26517-H1400 PACKING
  • 26511-H1400 LENS (2)
    • 26513-H1400 PACKING (2)
    • 7.5W bulb (2)
ライセンス 灯 ナンバー
