Datsun 1200 side lamps are used either as running lamps (USA) or indicators/blinkers (Australia). Because USA purpose is for visibily (instead of turn signals) they are made larger to be more visible.
Variations
- USA: large lenses for running lights/reflectors
- front and rear
- All other countries: long thin ORANGE lenses for turn signal (blinkers)
- front only
- 26161-H1001 LENS
- 26162-H1001 RIM
- Two wire harness (bulb 12V + earth/ground)
- 2-wire (12V + Ground)
- right and left differ
- front and back differ
- sedan and coupe differ
COMMON
- 26182-H1900 RIM
- 26715-89902 BULB 12V-8W(ICHIKHO)
- 08964-10410 NUT-SPRING(ICHIKHO)
ORANGE, FRONT
- 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO)
- 26181-H1900 LENS
- 01451-00041 SCREW (2 per lens)
- 26184-H1900 PACKING RH
OKINAWA FRONT FROM 0772
- 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH FROM 0772
RED, REAR
COMMON
- 26191-H1900 LENS
COUPE
- 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE
- 26194-H1910 PACKING RH(ICHIKHO) COUPE
- 01451-00061 SCREW(ICHIKHO) COUPE
SEDAN
- 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN
- 26194-H1900 PACKING RH(ICHIKHO) SEDAN
- 01451-00041 SCREW(ICHIKHO) SEDAN [same as front]
B210 side lamp is totally different from B110 lamp.
Remember, B110 is rectangular, while B210 is slightly pointed rectangular, or a totally angular lense.
Datsun 1000
See main article: Datsun 1000
Clear Lense
Custom
Search terms: lens, blinker, marker, side light, side lamp, running light ウインカ ランプ レンズ
