6-speed transmission gives you two (count 'em 2) overdrive gears. Or some have a close ratio direct-5th with overdrive, which is better for performance. 6-speeds can be modified to fit Datsun 1200. Just cut the bellhousing and weld on a fragment of A-series bell housing, then machine the input shaft smaller.
S15 6-speed
The Nissan Silvia S15 transmission is a close-ratio 5-speed + overdrive (6 forward speeds total).
S15 modified; A-series bell grafted on
- 71-Series Transmission
- only 16kg heavier than a standard 1200 4spd
- 1st: 3.630
- 2nd: 2.200
- 3rd: 1.543
- 4th: 1.210
- 5th: 1.000
- 6th: 0.767
