Bumpers are the same for USA and Japan markets, except for 1973 USA model bumper.
NOTE: 1973 parts fit older brackets, but older bumper doesn't fit newer brackets.
Front Bumper (Coupe & Sedan)
- 62651-H7000 ASSY-BUMPER,FRONT Sedan, Coupe from 0772 $178
- 62651-H1000, H1001, H1900 ASSY-BUMPER,FRONT Sedan, Coupe
Rear Bumper, sedan
- 85011-H7000 BUMPER-REAR CENTER Sedan from 0772
- 85011-H1900 BUMPER-REAR CENTER Sedan
- 85012-H1000 BUMPER-REAR RH Coupe, Sedan
- 85013-H1000 BUMPER-REAR LH Coupe, Sedan
62663-18000 BOLT-SPECIAL M6 FIX BUMPER CENTER TO SI 08915-13610 WASHER-LOCK FIX BUMPER CENTER TO SI 08911-10610 NUT-HEX M6X1.0 FIX BUMPER CENTER TO SI 08915-53610 WASHER-PLAIN FIX BUMPER CENTER TO SI 85204-H1000 STAY-BUMPER REAR 85204-H7000 STAY-BUMPER REAR 62663-18000 BOLT-SPECIAL M6 FIX STAY TO BUMPER 08114-01610 BOLT 08915-43610 WASHER-PLAIN M6 FIX STAY TO BUMPER 08915-44010 WASHER-PLAIN 08915-13610 WASHER-LOCK M6 FIX STAY TO BUMPER 08915-14010 WASHER-SPRING 08911-10610 NUT-HEX M6 FIX STAY TO BUMPER 85206-H7000 BRACKET-BUMPER REAR SIDE RH 85206-H1000 BRACKET-BUMPER REAR SIDE RH 85207-H1000 BRACKET-BUMPER REAR SIDE LH 85207-H7000 BRACKET-BUMPER REAR SIDE LH 62663-18000 BOLT-SPECIAL M6 FIX BRACKET TO BUMPER 08915-43610 WASHER-PLAIN M6 FIX BRACKET TO BUMPER 08915-13610 WASHER-LOCK FIX BRACKET TO BUMPER 08911-10610 NUT-HEX M6X1.0 FIX BRACKET TO BUMPER 08110-82062 BOLT-HEX WITH WASHER FIX STAY TO BODY 08915-53810 WASHER-PLAIN FIX STAY TO BODY 62685-73000 WASHER-RUBBER FIX STAY TO BODY 62678-21000 SHIM-BRACKET BUMPER SIDE FIX BRACKET TO 08110-61862 BOLT-HEX WITH WASHER FIX BRACKET TO B 08915-53610 WASHER-PLAIN FIX BRACKET TO BODY
Rear Bumper, Coupe
- 85011-H7100 BUMPER-REAR CENTER Coupe from 0772
- 85011-H1905 BUMPER-REAR CENTER Coupe
Overriders
85020-H1900 OVERRIDER-REAR BUMPER RH 85021-H1900 OVERRIDER-REAR BUMPER LH 85020-H7000 OVERRIDER-REAR BUMPER RH 1973 85021-H7000 OVERRIDER-REAR BUMPER LH 1973 62674-H1900 OVERRIDER-FRONT BUMPER RH 62675-H1900 OVERRIDER-FRONT BUMPER LH 62674-H7000 OVERRIDER-FRONT BUMPER RH 1973 62675-H7000 OVERRIDER-FRONT BUMPER LH 1973 85024-H1900 RUBBER-OVERRIDER (4)
Catalog
- 62651-H1000 ASSY-BUMPER,FRONT
- 62651-H1001 ASSY-BUMPER,FRONT from 0870 (interchanges with former)
- 85011-H1000 BUMPER-REAR CENTER Sedan
- 85011-H1800 BUMPER-REAR CENTER Coupe
- 85011-H1400 BUMPER-REAR CENTER Van
NOTE: PB110 front bumper is unique, but PB110 rear bumper is same as B110.
Sunny Truck
- 62651-H1025 ASSY-BUMPER,FRONT Truck 7510-7803 (one piece)
- 62650-G1060 ASSY-BUMPER,FRONT Truck 7804-8910 (three-piece)
- 62650-95W00 ASSY-BUMPER,FRONT Truck from 8910
- 62024-G1060 BUMPER-FRONT RH from 7804
- 62025-G1060 BUMPER-FRONT LH from 7804
- 85010-G1001 RUBBER-REAR BUMPER, SIDE RH 7510-7611
- 85010-G1002 RUBBER-REAR BUMPER, SIDE RH 7612-
- 85011-G1001 RUBBER-REAR BUMPER, SIDE LH 7510-7611
- 85011-G1002 RUBBER-REAR BUMPER, SIDE LH 7612-
