PB110 Steering Gearbox
Revision as of 06:39, 29 August 2010; view current revision
Category: PB110
The PB110 Sunny 1400 gearbox looks similar to the regular 1200, and may even bolts in its place. However all the parts are different. The internal parts are from Datsun 510.
  • 3-bolt frame-to-gearbox mounting looks same as B110
  • But uses Datsun 510 gearbox arm, probably requires use of larger B210/B310 cross rod
  • The ratio may be different than B110
  • PB110: 3-bolt housing cover, 3-bolt column/worm shaft flange
  • B110: 4-bolt housing cover, 4-bolt column/worm shaft flange
The GL and GX models were fitted with collapsible column and separate gearbox.
NOTE:
collapsible column
with separate gearbox
Part Number Overview
Applied Model Codes use by the gearbox parts:
  • H25 part number are generally unique to PB110
  • 041: Datsun 310
  • 165: Datsun P411
  • 322: Nissan 30 [Cedric, circa 1960]
  • 712: Nissan H31 ('65) [Cedric 1900]
  • A06: Datsun 510S ('69)
  • 210: Datsun 510-S [Standard trim]
  • 220: Datsun P510-TK [4-speed, Twin Carb]
  • 261: Datsun D510-T
Rigid Steering Gearbox & Column
  • 48010-H2551 GEAR ASS'Y-steering DX [rigid, with integral column]
    • 48150-H2500 WORM ASS'Y-steering DX
    • 48103-21000 SHAFT-sector, steering ALL [Datsun 510 USA OP] $182.95 USD
      • 89-11250-1 NUT
      • 89-15150-1 WASHER-lock
PB110 gearbox parts all virtually all different from B110
48011-21000	HOUSING COMP.-steering
48127-16500	BEARING COMP.-needle (2)
9-33330	PLUG-expansion
48137-16500	SEAL-oil, sector shaft
48201-16500	COVER-sector shaft
48204-16500	GASKET-sector shaft cover
48064-16500	PLUG
81-20818-1	BOLT (3) [fixing cover]
89-15138-1	WASHER-lock (3) [fixing cover]
48029-71200	SHIM-worm bearing (0.762t)
48030-71200	SHIM-worm bearing (0.254t)
48031-71200	SHIM-worm bearing (0.127t)
48032-71200	SHIM-worm bearing (0.050t)
48035-71200	"O" RING
48250-H2500	JACKET COMP.-steering
48054-32200	BEARING ASS'Y-steering column
81-20820-1	BOLT (3) [fixing column to gearbox housing]
89-15138-1	WASHER-lock (3) [fixing column to gearbox housing]
48190-21000	BEARING ASS'Y-warm gear (2)
48135-32200	SCREW-adjusting, sector shaft
48233-21000	NUT-lock, adjusting, screw
48129-71200	SHIM-adjusing, sector shaft (1.600t)
48130-71200	SHIM-adjusing, sector shaft (1.575t)
48131-71200	SHIM-adjusing, sector shaft (1.550t)
48132-71200	SHIM-adjusing, sector shaft (1.525t)
89-11342-1	NUT (fixing steering wheel)
89-16242-1	WASHER-tooth lock (fixing steering wheel)
48502-A0600	ARM-steering gear
89-11250-1	NUT (fixing gear arm)
89-15150-1	WASHER-lock (fixing gear arm)
48058-16500	LID-jacket tube (rubber)
81-12642-1	BOLT (fixing steering gear) (3)
89-12642-1	NUT (fixing steering gear) (3)
89-15442-1	WASHER-plain (fixing steering gear) (3)
48324-H2500	CLAMP-steering, upper
48326-H2500	CLAMP-steering, lower
48325-04100	PACKING-steering post
01121-00051	BOLT (2) [fixing steering post]
Collapsible Steering Gearbox
  • 48011-21000 HOUSING COMP.-steering ALL [RHD]
    • compare to Datsun 510 USA 48011-21400 OPTION [LHD]
  • 48010-26150 GEAR ASS'Y-steering GL,GX [collapsible with U-joint]
    • 48150-26100 WORM ASS'Y-steering GL,GX $212.82 USD
Collapsible Steering Column
