Valves
Revision as of 01:36, 2 July 2011; view current revision
Category: Valvetrain
Datsun 1200 uses traditional 8mm stem diameter poppet valves.
Stem Oil Seal
See main article: Valve Stem Seals
Retainers
Valve Spring Retainer Keeper (Valve lock)
  • Stem diameter 0.252
  • 7 degree angle
  • SEALED POWER Part # VK215
  • BECK/ARNLEY Part # 0230045
  • Intake valve head diameter: 35 mm
  • Exhaust valve head diameter: 29 mm
  • Stem diameter: 8 mm
  • Overall length: 103.80 mm
  • Seat angle: 45 degrees
  • Head style: standard
  • Stem end: NG
  • 13201-H1000 VALVE-INTAKE [35mm]
  • 13202-18000 VALVE-EXHAUST [29mm]
  • 13201-H2300 VALVE-INTAKE A12GX [35mm]
  • 13202-H2300 VALVE-EXHAUST A12GX [29mm]
Valve Guides
•13212-H0112 GUIDE-VALVE INTAKE $8.08 •13213-H0113 GUIDE-VALVE EXHAUST $8.25
They have a little snap ring to limit the depth inserted in into the head
Others
For other A-series valves (A14, etc) and for competition valves, see: A-series_Cylinder_Heads#Valve_sizes
