Front
Bearings for drum hub and disc hub are the same.
Outer
42mm O.D.
- 40215-H1000 ASS'Y-BEARING-front wheel, outer
- 40215-H1000 ASSY-BEARING FRONT WHEEL OUTER from 0570
- 40215-18000 ASSY-BEARING FRONT WHEEL OUTER to 0470
- BCA/Timken/National 30302
- Taper Bearing Assembly
- Bore=0.5906"
- Outer Diameter=1.6535"
- Width=0.561"
- Cone Length=0.5118"
- Cup Length=0.4331"
- Cone Radius=0.06"
Inner
52 mm O.D.
- 32351-M5100 ASS'Y-BEARING-front wheel, inner
- Part 40210-H1000 is superseded by 32351-M5100
- 40210-H1000 ASSY-BEARING FRONT WHEEL INNER from 0570
- 40210-18000 ASSY-BEARING FRONT WHEEL INNER to 0470
Aftermarket
- SKF BR30205
- Beck/Arnley 051-3809 0513809
- Timken 30205M
- BCA/NATIONAL 30205
- 000720030205, 0009813705, 0059819105, 0059819205, 0069813605, 025933047, 0259330470, 0857591700, 11040, 1450481, 1522731, 183682, 18524, 26799930, 290062202, 31422345289, 33121451188, 40210H1000, 6601141, 7703090268, 7730205, 89459, 90005900200, 906100005, 9760030205, 9760930205, 9985014, A710X1200ABA, AK2508906, C5NN7N044A, C5NN7N047A, C5NN7N048A, E5TZ7065A, N035160, S08333075, T3090268, T7730205
- Datsun B10, B110
- 1971-1993 Mazda, various models
- 1971-1983 Renault, various models
- 1971-1972 Peugeot 304
- 1987-1994 Subaru Justy
- N10 transmission bearing MT.F5 A-series
- Cone radius=0.0394"
- Standout=0.1280"
- Outside diameter=2.0470"
- Inside diameter=0.9840"
- Cup radius=0.0394"
- Cup length=0.5118"
- Cone length=0.5906";
- Bore=0.9843"
- Outer Diameter=2.0472"
- Width=0.6398"
