Camshaft Timing
Revision as of 20:14, 8 August 2011; view current revision
Checking and adjusting the camshaft timing is an important part of a competition engine. You can also do the same for your street 1200 to ensure you are getting the expected performance.
Also see Camshaft Comparison
Find TDC
  • One dial indicator on piston head
    • Through spark plug hole
    • or, directly if head is removed
NOTE: You can also use a piston stop to find TDC
Advance crankshaft (turn clockwise) until lifter comes up 0.050":
  • Second dial indicator on pushrod, to measure cam lift
  • Timing wheel to have 360 degree measurement
Note the degree at which 0.050 lift occurs
Continue turning and note maximum lift.
Check each lobe the same way to see if any lobes are worn.
Fine Adjustments
Advance or retard the camshaft using:
  • offset key for cam pulley
  • or, adjustable cam pulley
Modified timing cover to suit adjustable cam gear
Retarding the cam moves the power band up in the RPM range
Advancing the cam lowers teh power band in the RPM range.
Of course using the right camshaft is even better, but this technique can be used to see the effects:
  • fine tune the cam to the engine
  • fine tune the cam/engine to each particular track
  • cover up a mis-matched cam
Slotted cam pulley for adjustment
Measuring lift
Factory Specifications
See Camshaft Comparison for more details.
240/240 duration (A10 Datsun 1000)
248/248 duration (standard small bore)
248/256 duration (standard large bore)
256/256 duration (performance engines)
244/248 duration (Late USA emission)
248/248 as used by standard A12
248/248/14/54/12/56
Late-model
B310 Australia?
A14: 256/248
A12: 248/248
