Rear Axle Swaps
Revision as of 15:24, 11 December 2006; view current revision
Categories: Rear Axle And Rear Suspension | Drivetrain Modifications | Brake Modifications
What Diff and LSD should I use?
[hide]
Definitions
Differential: The word "differential" refers to
  • The small gears in the rear end that control the left-to-right wheel speeds
  • By popular usage it also refers to either a) the center gear assembly, including Ring and Pinion and the carrier these bolt to, or b) the entire axle assembly including the housing, gears, axles etc.
Ring and Pinion (R&P) are the large final-drive gears e.g. the "ratio" gears. Known as "Crown Wheel and Pinion" (CWP) in British English.
Spider gears: The other smaller side gears are known as the "spider gears". These are the ones that actually allow a differential speed.
Strength of Differential -- Torque Rating
Horsepower is irrelevent for the differential. What matters is the torque:
Engine Torque x gearbox multiplication = twisting force applied to differential
For example:
  • A 400HP engine with 275 lb ft torque could get by with a much smaller diff than a blown 400HP engine with 500 lb ft torque. Yet both are 400 horsepower. Why does the second engine need a differential that's twice as strong? Because torque matters, HP is not directly related to the strength needed.
    • A 'built' 125 hp A12 will versus a stock 125 hp 3-liter V6. You need a bigger diff for the latter since it has more torque.
    • Lower first-gears in the transmission mean more torque gets to the differential. For example, the stock B110 4-speed first gear (3.757) will multiply torque more than the B310 5-speed first gear (3.513 in the 60a transmission).
    The Datsun 1200's H145 differential is only safe for as much torque as an A12 puts out, or maybe as much as 100 lb. ft. of torque. Datsun used the larger H150 for all A14-powered cars, this was good for maybe 125 lb. ft. of torque. The much larger H165 was good for maybe 225 lb. ft. of torque. Finally, the H190 was the big gun (approx. 7 1/2 inch ring gear) and good for maybe 285 lb. ft. of torque.
    diffmax. torque capacity
    H145~100 lb. ft.
    H150~125 lb. ft.
    H165~225 lb. ft.
    H190~285 lb. ft.
    Stock Datsun 1200 Rear Axle
    Coupes, Wagons and Sedan use the small H145 differential. 1975 and up Datsun 1200 Trucks use the stronger H165 differential.
    Car Rear Axle
    The stock rear-end assembly works great for the A12 or the A14 engine. This is the H145 (145mm diameter ring gear). The diff is open (non-limited-slip) and the diff assembly unbolts from the front of the axle assembly (like Ford 9", but much smaller). All 1200's (except newer utes) had the H145. Sedan and coupe had a 3.900 and the wagons had 4.10 ratio. Wagons and vans have alloy center.
    Datsun Competition (later Nismo) used to sell various ratios: 3.9, 4.111, 4.375, 4.625 LSD (Limited-Slip Differential) units were also available from Datsun Competition. Axle baffles and Oil Coolers were available from Nissan Competition Good for maybe 100 lb. ft. of torque
    A15 Diffs If you have swapped an A15 into your 1200, the stock H145 differential isn't strong enough except maybe for use with an automatic transmission. Instead, use an H150 (as fitted to B210s and B310s) or larger differential.
    1200 Late Truck Rear Axle
    Newer Ute Differential Newer 1200 Utes (1974 and up) have a much bigger and stronger diff, the H165 (165mm diameter ring gear). This has stronger axles too.
    560.jpg H165
    Good for maybe 225 lb. ft. of torque ??? Axle baffles and Oil Coolers were available from Nissan Competition There is one LSD for Type I, and another for Type II
    Easy Swaps
    B110/B120 axle
    Coupe into Sedan into Wagon into Ute: All B110/B120 H145 rear-axle assemblies (housing, etc) generally interchange but may be small difference in the brake line routing, handbrake cable location etc. Also use the shock-mounting plates from the right vehicle:
    1200 Shock Absorbers
    TIP: Wagons had a alloy carrier.
    B210 Japan (Hitachi) axle
    The easiest swap is to get the entire rear-axle assembly from a 1975 or newer B210 (120Y) -- this is the H150 (150mm diameter ring gear). The main spring is 55mm longer, but the others can be used on the 1200. See Bolts right in!
    Japan diff
    NOTE: The 1974 B210 uses an H145, although the housing is the new stronger design. H145 can be distinguished by studs, whereas H150 uses bolts to fast the diff to the case.
    Datsun Competition (later Nismo) used to sell various ratios: 3.545, 3.7, 3.9, 4.111 for the H150.
    LSD (Limited-Slip Differential), Axles baffles and Oil Coolers were not available from Nissan for the H150.
    Good for maybe 125 lb. ft. of torque
    B310 Rear Axle
    The assembly from a B310 (Datsun 210/Sunny) uses coil springs and is wider, so it's not as good a choice (need modifications).
    B210 Borg Warner axle: 120Y 4-dr sedans and wagons were Australian assembled and had a Borg Warner diff (BW model 68). All were 3.89 ratio, although the 120Y wagon and panelvan might have had a different ratio. [Thanks L18_B110 for this info]
    This can be detected as there is a rear cover (the diff [center] doesn't unbolt from the front of the axle housing - like a GM differential only smaller).
    These are the same width as a 1200 H145 diff, but have a different input flange, so you will also need the matching 120Y-BW tailshaft.
    641.JPG 640.JPG640 1202.jpg1202
    Borg-Warner diff
    Late B120 Ute, B140 & B122: The next best swap (at least in countries that got 1200 utes) is to get a 1974-and-newer 1200 ute H165 assembly, although it may cost a bit if you can find one.
    In North America, Nissan Motorsports use to sell the empty axle housing, axles and other parts. rear disc brakes are available for this axle housing.
    The late 1200 ute (1974-up) uses the H165 differential, which is strong enough for a stock CA18DET engine. It bolts right into a coupe or sedan, with this exception
    • handbrake adapter fits in a slightly different in position
    • make sure you get the ute rear brake fluid splitter
    • the driveshaft is 25mm longer (than a B110 shaft) and has a different yoke
    discussion: ute difference and ute history
    == Toyota == Corolla KE25 or KE30 will increase the track about 3", but is a bolt in.
    An option for the Aussies out there is the Australian Toyota Corolla diff. KE25 and KE30 models used the same Borg Warner diff as the 120Y, but with longer axles & tubes. Approx 3" wider in total. this is useful if you have Stanza or similar front brakes, as those struts increase track by about the same amount. So you can use the same offset (fwd) wheels front and rear without looking kinda silly and undertyred at the back if you know what I mean. Using rwd offsets will require a little gaurd work depending on the width and tyre size used. The biggest reason for using the Corolla Borg Warner is the available ratios - 3.89 (manual), 4.1 or 4.3 (auto). A tag on the rear cover has the ratio stamped on it. The Corolla diffs have a different input flange, so you need a 120Y BorgWarner flange which is interchangeable with the Corolla's. You also need a 120Y Borg Warner tailshaft (for the matching flange)
    Other Strong Diffs and Choices
    Rear-axle assemblies from many different cars be be swapped in the 1200 with minor or major modifications. Advantages are strength, LSD and gear ratio choices. Oh, and if you do the work yourself, swapping in a unit could be cheaper than buying just a new ring & pinion.
    Bolt-Ins
    Some reported non-narrowed rears are (with possibly the assembly a little wider) are:
      <li>Ford Falcon ute complete rear which gave you LSD, a live rear, and discs <li>Datsun 620 (pickup) front axle assembly with LSD <li>510, 610,710 station wagon (Davo_1200's 1200 used this diff). Note that 510 sedans use IRS, a very long-snouted Subaru diff and LSD centre will fit found here in the US on the XT models. It is an 3.70:1 R160 by Fuji Heavy Industries (Subaru) and is the same as the OEM diff in the datsun 510 (1600) also made by Fuji. ( not sure about this, no subaru i ever had had a stock LSD... ) <li>US Postal Service Jeep (8 3/4" Chevy rear end with 4.11 gears)
    Shortened
    Just about any rear axle assembly can be narrowed to fit a 1200, with the right spring perches welded on. For example:
      <li>Custom-built Ford 9" (kits are about $500-$700 USD from Currie Enterprises or Moser Engineering - includes housing and two axles, you add brakes and center section from any old Ford sedan) <li>Toyota Hilux Pickup <li>Nissan Bluebird TRX <li>Skyline Borg Warner LSD <li>Datsun 520 pickup/ute with H190 diff <li>H190 from Series 1 & 2 Bluebird wagons that came with the 4 speed trans H190 info and discussion Width unknown, but these solid axles have the H165 center: S110 Sylvia (1980-1984 200SX) 82s and 83s had optional disk brakes S10 Sylvia (200SX, note 85-up S12 uses H190, R190 or R200 diff). reference: site For more information on vehicles with H190, see the "[#ratios ratios]" section below. <li>Mitsubishi Scorpion diff 903.jpg 919.JPG920.JPG2143.jpg
    Differential Gear Ratios
    H145
    B10 - Datsun 1000 1967-1970 4.11 4.375 - wagon (VB10) with alloy carrier
    B110 - Datsun 1200 1971-1973 3.90 B120 - Datsun 1200 ute 1971-1973 4.11
    B210 - 1974 3.90 (north american)
    Datsun Competition (later Nismo) used to sell various ratios: 3.9, 4.111, 4.375, 4.625 for the H145.
    H150
    B210 and B310 - Nissan North America <li>1975-1979 4sp and auto: 3.889</li> <li>1975-1979 5sp: 3.70 <li>B310 1980: 3.889 (Auto & all A12A) <li>B310 1980: 3.70 (A14 manual) <li>B310 1980: 3.545 (A15 manual)
    Datsun Competition (later Nismo) used to sell various ratios: 3.545, 3.7, 3.9, 4.111.
    H165
      <li>H165B Type I (to 6/79): 3.545, 3.7, 3.9, 4.111, 4.375, 4.625, 4.875 <li>H165B Type II (from 7/79): 3.364, 3.545, 3.7, 3.9, 4.111, 4.375, 4.625, 4.875
    Available from production vehicles: 3.7, 3.9, 4.111 & 4.875 reference: diff ratios
    1240.jpgC120 van ratios
    You can get 4.1:1 and 4.875:1 ratios quite easy, it is the same diff that Bluebirds (rwd Maxima) and C20 (Datsun Vanette) -- some with aluminum centers -- and some 4wd Datsun Pickup (non-1200 ute) front diffs (those are wider assemblies, though, so just use the center section). For example: A10 Stanza/HL510 (1978-1982): 3.7:1 180B (610) wagon: 3.89:1 Series 1 Bluebirds (810): 3.89:1 Series 3 Bluebird wagon (910): 3.89:1
    Pit Road carries the H165 part (LSD Nismo P/N 38420-RS110). [www.datrats.com.au DatRats] also has been known to carry the 1200 ute stuff.
    H190
    How to Identify Datsun Diffs
    Here are some features to note to tell the difference:
    • does center section bolt in?
    • count bolt holes
    • Measure distance across
    H145 vs H165 size comparison
    • Does center bolt in, or fit onto studs with nuts?
    No back cover
    To check a Vanette diff,count the bolts holding the housing to the centre. if it's got 8, it's a H165, & the motor will be a a12. If however it's got 10, it's a H190 & the motor should be an a15. discussion: Vanette diff
    H145 or H165?
    http://datsun1200.com/modules/myalbum/photos/thumbs /3338.jpg
    H145 or H165?
    H190 versus H165
    Axle comparison: H190 versus H165
    H190 was used in most of the Datsun pickups, the 1960's Datsun Roadsters and other Datsuns.
    To install a 4.375, 4.625 or 5.125 ring and pinion into a third member equipped with a 3.700, 3.889 or 4.111 ring and pinion a 4.0mm/.157" ring gear spacer must be fabricated. Due to a smaller pinion shaft, the 4.875 and 5.874 ring an [sic] and pinion sets are interchangeable, but cannot be installed into third members equipped with other ratios. Nissan Competition part catalog, 1984 edition pg 58
    Datsun Competition used to sell various ratios: 3.36, 3.545, 3.7, 3.9, 4.111, 4.375, 4.625, 4.875, 5.143, 5.429.
    There is one LSD for ratios up to 4.111, and another for the larger ratios
    3485.jpg Alloy Carrier
    3486.jpg3486 3487.jpg3487
    H190 vs H165
    R160, R180 and R190 These were IRS (Independent Rear Suspension) differentials with long snouts. Used in the Datsun 510, 610 and other IRS Datsuns. The "R" stands for Fuji Heavy Industries. The R180 was used in the front axle of Datsun 4x4 trucks (720, etc).
    R31 Skyline Diff
    Propeller Shafts
    Automatic and manual cars use different propeller shafts (aka driveshaft or tailshaft). Automatic transmissions are 15mm shorter than a standard transmission, so the auto propeller shaft is 15mm longer.
    53-series transmissions and 60-series transmissions are the same length, and use the same shaft. It doesn't matter if you get the transmission from a B110, B210 or B310.
    63A and 63l use the same input yoke as the AT, rumor has it all you need is the AT prop shaft to hook the 63a to the H150&H150A. The 63A should be the same as the L series ones as far as the shafts and splines ( needs to be verified )
    You may need to remove the dust cover (cup on front yoke that fits over end of gearbox) for some swaps. The cup sometimes looks like its purpose is a stopper, to stop the yoke from sliding in too far (see B310 Manual Conversion, tailshaft doesn't match?).
    Can you use a B210 driveshaft in a B110? I think so IF you get the 1974 B210 driveshaft. Here are some driveshaft (tailshaft) considerations
      <li>The 56 and 60 transmissions are the same length <li>The automatic and standard cars use the same differential, so the back flange is the same <li>Automatic and Manual Transmission cars use different shafts, presumably the shaft's slipyoke is different <li>1974 B210s (and perhaps any 12" wheeled A12-powered B210) uses the H145 diff. Other B210 models used the H150 diff which has a larger flange <li>Aussie-assembled B210s used a Borg-Warner diff, so that shaft is totally different
    Note that all models in a family use the same shafts -- there is no difference between coupe, sedans or wagons.
    The 1971-1973 Datsun 1200 manual tailshaft is the same overall length as the B310 manual but with different flange bolt pattern at rear. 7474.jpg
    B110 and B310 both use the "Japanese" differential (H145 or H150). So do most B210s, except Aussie-built B210 sedans which use a Borg-Warner differential.
    B110 Propeller Shaft Specs
    • Same for all 1971-1973 models (including ute)
    • End-to-end length nearly same as B310 (though diff flange differs)
    • 1189 mm (u-joint to u-joint)
    • 68.9 mm Tube diameter. 1.6 mm thick
    • 20 mm Sleeve yoke (slip yoke) diameter. 1.6 mm thick. 3.150 mm pitch splines
    B110 Propeller Shaft - Nissan Part Numbers
    • 37000-H3100 SHAFT COMP, propeller with joint (manual)
    • 37000-H5100 SHAFT COMP, propeller with joint (auto)
    B210 Propeller Shaft Specs
    one-piece shaft Length measurements
    • 1182 mm (u-joint to u-joint)
    • 1330 mm manual (end-to-end)
    • 1345 mm auto (end-to-end)
    • 33 mm (rear u-joint to flange face)
    • 115 mm manual (front u-joint to tip of slip yoke)
    • 130 mm auto (front u-joint to tip of slip yoke)
    Nissan Part Numbers
    • 37000-H7200 SHAFT ASSY-PROPELLER manual 4-speed
    • 37000-H7300 SHAFT ASSY-PROPELLER automatic Auto
    • 37000-H7500 SHAFT ASSY-PROPELLER (3-joint) 5-speed
    • 37000-H7900 SHAFT ASSY-PROPELLER (3-joint) 4-speed
    These last two (2-piece shaft, 3-joints) are JDM models with a small 63.5mm diameter shaft. These were used in the L-engine powered cars.
    B310 Propeller Shaft Specs
    Length
    • End-to-end length nearly same as B110 (though diff flange differs)
    • 49 inches from rear flange face to beginning of yoke slip surface
    • 1045 mm manual (u-joint to u-joint)
    • 1177 mm auto (u-joint to u-joint)
    Nissan Part Numbers
    • 37000-H8500 SHAFT ASSY-PROPELLER manual
    • 37000-H8900 SHAFT ASSY-PROPELLER automatic
    • 37000-H9200 SHAFT ASSY-PROPELLER A14E up to 7909
    • 37000-H9201 SHAFT ASSY-PROPELLER A14E from 7910-8010 A15E from 8011
    These last two "E" models (EGI aka EFI) used a two-piece shaft with center bearing, similar to the longbed GB122 truck.
    Limited-Slip and Locking Differentials
    A differential is inside the "final drive" (ring & pinion) gears and allows the left and right wheels to turn at different speeds. This is important of course for going around corners. The downside is that if one wheel is on slippery ground (ice, gravel, mud, etc) the car doesn't go at all, as one wheel is turning but slipping and the other not turning at all. Hence the usefulness of LSD or locking diffentials, which are typically used on high-performance cars. Locking is typically used on off-road vehicles, LSD for road vehicles, including racecars. Most productions cars did not and still do not come equipped with LSD. Less expensive cars (like the 1200) did not even have it as an option.
    Limited Slip Differential (LSD)
    Limited Slip Differentials come in many different types, but the main thing is they limit wheelspin. This is useful in racing and in low-traction surfaces (rain, snow, etc). Different types of LSD are cone-clutch, spring-loaded, clutch-pack, hydrodynamic (viscous), etc. Some trademarks are "Posi-Traction" (GM), "Traction-Lok" (Ford), Torsen.
    Nissan Performance racing parts used to sell an LSD for the 1200.
    1652.jpg H145 LSD
    Spring-loaded LSD vs. conventional
    Reportedly, the easy LSD upgrade for a 1200 is to use a Datsun 720 (pickup) front axle assembly.
    Locking Diffs
    A "locking" differential is another animal. When locked there is no slip -- not just limited slip, but none at all. When unlocked, it's the same as an open differential. These are used for racing or for seriously slow off-road work.
    Locked diffs are also useful for circuit racing. Many race cars from all sorts of categories use locked diffs. The understeer that is apparent on street/drag cars with locked diffs can easily be eliminated with proper (race) suspension geometry. These settings (camber, castor, and toe) will not be practical for street use though.
    L18_B110
    Examples of different types of locking diffs:
      <li>The ARB air-locker is popular with Jeeps and other off-roaders. When the dash-mounted switch is flipped, air pressure locks the diff gears together <li>The "Detroit Locker" was used by some high-performance Ford vehicles in the 60s and 70s. The Locker may be the only modern road-going locking differential, as it can automatically lock and unlock
      Spools
      <li>For drag racing, the spider gears can be replaced with a sold unit so that both axles are always locked together. This is called a "spool"
      1467.jpg spool (right center)
      <li>The "poor man's" locking diff is to have the spider gears welded together so that it works like a spool, but is obviously cheaper. The danger is of a bad weld and having it explode on the race track
    Using a spool or welded diff gears on the street is illegal in most countries, and can be dangerous, especially in the wet. The danger is of spinning out.
    Miscellaneous
    race car mounting
    4-link
    See also:
    Brakes: for information on brakes, see tech section article Suspension & Brakes
