This page is for factory specifications. For modified settings, see Category:Suspension Modifications.
Wheel Alignment
Camber, Caster and Toe-in
See main article: Wheel alignment
Factory Front Suspsension Specifications
Coil Spring Specifications
'NA means North America
| data | B110 | B210 1977 NA | B210 1977 NA w/AC | B310 1980/82 NA | B310 1980/82 NA w/AC | B310 1980 w/AC USA A12A rectangular headlight |
| Coil spring wire diameter | 10mm | 10.5mm | 10.8mm | 10.5mm | 10.8mm | 10.5mm |
| coil outer diameter | 110mm (4.33 in) | 100mm (3.94 in) | 100mm (3.94 in) | 100mm (3.94 in) | 100mm (3.94 in) | 100mm (3.94 in) |
| Free length | 338mm +- 10 | 1977:
375mm 1974: 352.5mm | 388mm | 375mm 357.5mm Canada A12A 366mm USA A12A rec. headlight model) | 381mm 375mm Canada | 375mm |
| Spring constant | 1.6kg/mm (89.6 lb/in) | ? | ? | 1.62kg/mm (90.7 lb/in) | 1.65kg/mm (92.4 lb/in) | 1.62kg/mm (90.7 lb/in) |
Kingpin Inclination (non-adjustable)
- B110: 7
1974-up B120
B120 pickup:
Coil Spring
- Wire diameter: 10mm (0.39 in)
- Coil diameter: 100mm (3.94 in)
- Loaded (normal load) length: 326mm (12.83 in)
- Effective turn: 6.2
- Spring constant: 1.6 kg/mm (90.0 lb/in)
Strut damper
- Piston Rod diameter: 18mm (0.71 in)
- Piston diameter: 25mm (0.98 in)
- Stroke: 164mm (6.46 in)
Damping Force at 0.3m/sec (1.0 ft/sec)
- Expansion/Rebound: 38-58kg (84-128 lb)
- Compression: 17-27 kb (37-60 lb)
