Datsun 1200 uses a common wheel bolt-pattern: 4 bolt holes on 4-1/2 inch circle (aka 4-on-4.5). Nissan engineers measured this in inches. In metric, this is equivalent to a 4 x 114.3 PCD (Positive Coefficient of Distance)
Stock Datsun 1200 wheels are 12 inch diameter, 4J (4 inches wide). All models, even GX models, used the same wheels.
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13). Pefect for the front, but The may need a 1/4 inch spacer to clear the brake caliper brackets in the front
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Hyundai Excel
- Ford Laser (KA to KH)
- Rear-wheel-drive Mitsubishi
Anything that is 4-bolt on 4.5 inch circle fits (depending on tire size), although the offset on many front-wheel drive wheels is too much.
What WONT work:
- Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
Wheel Offset
The stock wheel is 4 inches wide with 15mm backspace.
wheel offset and backspace diagram
Front-wheel-drive cars use negative-offset wheels. Often they will fit the 1200 if wheel spacers are used.
Largest Sizes to Fit 1200
17-inch diameter wheels easily fit the 1200. The key is: width and overall height.
See: Tires for a discussion of the largest tires that will fit and which wheels are needed for those tires.
Wheel Adapters
Wheel adapters can be used. These bolt to the hub, then you can fit other wheels.
