Engine Part Numbers
Revision as of 11:36, 29 January 2008; view current revision
Category: Engine Mechanical
Nissan USA
  • 10100-H3957 ASSY-ENGINE WITH DRIVE PLATEFOR TROPICAL 1 OP A12 AUTOMATIC 1171- NLA
  • 10001-H1951 ASSY-ENGINE WITH CLUTCH 1 A12 MANUAL EVAPO - NLA
  • 10001-H3950 ASSY-ENGINE WITH CLUTCH 1 A12,MANUAL 0671- NLA
  • 10001-H7050 ASSY-ENGINE WITH CLUTCH 1 A12,(MANUAL) 0772- 0 10001-H3950 NLA
  • 10001-H1653 ASSY-ENGINE WITH CLUTCH (COLD AREA) 1 OP 0370- NLA
  • 10001-H1953 ASSY-ENGINE WITH CLUTCH 1 A12 MANUAL ONTARIO 0570- NLA
  • 10001-H3951 ASSY-ENGINE WITH CLUTCH FOR COLD REGION 1 OP A12 MANUAL 0671- 0 10001-H1953 NLA
  • 10001-H7051 ASSY-ENGINE WITH CLUTCH FOR COLD REGION 1 OP A12 MANUAL 0772- 0 10001-H3951 NLA
  • 10001-H3952 ASSY-ENGINE WITH CLUTCH FOR TROPICAL REG 1 OP A12 MANUAL 1171- NLA
  • 10001-H7052 ASSY-ENGINE WITH CLUTCH FOR TROPICAL REG 1 OP A12 MANUAL 0772- 0 10001-H3952 NLA
  • 10100-H1958 ASSY-ENGINE WITH DRIVE PLATE 1 A12 AUTOMATIC ONTARIO 0570- NLA
  • 10001-H1952 ASSY-ENGINE WITH CLUTCH 1 A12 MANUAL CRANK -968 8 NLA
  • 10100-H7151 ASSY-ENGINE WITH DRIVE PLATEFOR COLD REG 1 OP A12 AUTOMATIC 0772- 0 10100-H3956 NLA
  • 10103-H7000 ASSY-ENGINE SHORT 1 A12 EVAPO 0772- 0 10103-H3900 NLA
  • 10100-H7152 ASSY-ENGINE WITH DRIVE PLATEFOR TROPICAL 1 OP A12 AUTOMATIC 0772- 0 10100-H3957 NLA
  • 10100-H3955 ASSY-ENGINE WITH DRIVE PLATE 1 A12,AUTO 0671- NLA
  • 10100-H7150 ASSY-ENGINE WITH DRIVE PLATE 1 A12,(AUTO) 0772- 0 10100-H3955 NLA
  • 10102-H1001 ASSY-ENGINE BARE 1 A12 CRANK - NLA
  • 10102-H1900 ASSY-ENGINE BARE 1 A12 EVAPO - NLA
  • 10102-H3900 ASSY-ENGINE BARE 1 A12 EVAPO 0671- 0 10102-H1900 NLA
  • 10102-H7000 ASSY-ENGINE BARE 1 A12 EVAPO 0772- 0 10102-H3900 NLA
  • 10103-H1001 ASSY-ENGINE SHORT 1 A12 CRANK - NLA
  • 10103-H1900 ASSY-ENGINE SHORT 1 A12 EVAPO - NLA
  • 10103-H3900 ASSY-ENGINE SHORT 1 A12 EVAPO 0671- 2 10103-H1900 NLA
  • 10100-H3956 ASSY-ENGINE WITH DRIVE PLATEFOR COLD REG 1 OP A12 AUTOMATIC 0671- 0 10100-H1958 NLA
  • 10101-H3927 KIT-GASKET ENGINE 1 A12 0673- 2 10101-H3926 $45.23
  • 10101-H3926 KIT-GASKET ENGINE 1 A12 0672- 2 10101-H3925 superceded
  • 10101-H3925 KIT-GASKET ENGINE 1 A12 0671- 0 10101-H1025 superceded
  • 10101-H1025 KIT-GASKET ENGINE 1 A12 - 2 10101-18027 superceded
  • 10101-18027 KIT-GASKET ENGINE 1 A12 - superceded
  • 11042-H3927 KIT-GASKET VALVE REGRINED 1 A12 0673- 2 11042-H3926 $104.02
  • 11042-H3926 KIT-GASKET VALVE REGRINED 1 A12 0672- 2 11042-H3925 superceded
  • 11042-H3925 KIT-GASKET VALVE REGRINED 1 A12 0671- 0 11042-H1025 superceded
  • 11042-H1025 KIT-GASKET VALVE REGRINED 1 A12 - 2 11042-18026 superceded
  • 11042-18026 KIT-GASKET VALVE REGRINED 1 A12 - superceded
  • 11010-H2300 ASSY-BLOCK,CYLINDER 1 A12 0570- 2 11010-H1000 $1,386.17
  • 11010-H1000 ASSY-BLOCK CYLINDER 1 A12 - superceded
  • 12293-18001 BOLT FIXING BEARING CAP 1 10 A12 - $1.16
  • 11019-32200 PLUG-WELCH 44 CAM BEARING 1 A12 - $1.52
  • 00933-13500 PLUG-WELCH 35 CORE HOLE 3 A12 - $2.90
  • 01648-00084 PLUG-WELCH 35 CORE HOLE 3 A12 - 2 00933-13500 $2.90
  • 00933-15000 PLUG-WELCH 50 CORE HOLE 1 A12 - superceded
  • 11021-13200 PLUG-TAPER 12.7 OIL GALLERY 2 A12 - superceded
  • 11024-K0100 PLUG-TAPER 12.7 OIL GALLERY 2 A12 - 2 11021-13200 $0.80
  • 00933-20650 PLUG-TAPER 6 OIL GALLERY 5 A12 - superceded
  • 01647-00011 PLUG-TAPER 6 OIL GALLERY 5 A12 - 2 00933-20650 $0.74
  • 11046-73402 DOWEL-TIMING 5 FRONT COVER 2 A12 - $0.76
  • 11023-32200 DOWEL-TIMING 5 FRONT COVER 2 A12 - 2 11046-73402 NLA
  • 30412-21000 DOWEL-TIMING 9.5 CASE LOCATING 2 A12 - $0.75
  • 08213-82810 STUD-FIXING FUEL PUMP 2 A12 - $0.68
  • 08213-84810 STUD FIXING WATER PUMP 3 A12 1172- 2 08213-84510 $0.98
  • 08213-84510 STUD FIXING WATER PUMP 3 A12 - superceded
  • 08223-81610 STUD FIXING ENGINE MOUNTING BRACKET 4 A12 - $0.74
  • 12279-18000 SEAL-OIL CRANKSHAFT REAR 1 A12 - $81.18
  • 12279-18010 SEAL-OIL CRANKSHAFT REAR (NDK) 1 A12 0271- 2 12279-18000 NLA
  • 12279-H1000 SEAL-OIL CRANKSHAFT REAR (NOK) 1 A12 0271- $81.18
  • 21045-18000 PIPE-SUCTION WATER PUMP 1 A12 - $8.20
  • 08931-30410 PLUG-TAPER THRED WATER DRAIN 1 A12 - $1.26
  • 11037-H1000 NET-STEEL CRANK CASE 1 A12 - $4.82
  • 11038-H1000 PLATE-BAFFLE CRANK CASE 1 A12 - NLA
  • 08310-61214 SCREW-MACHINE 2 A12 - $0.74
  • 11110-H1001 ASSY-PAN OIL 1 A12 - NLA
  • 11119-61000 SEAT-DRAIN PLUG 1 A12 - $1.67
  • 11128-69200 PLUG-DRAIN 1 A12 - $3.57
  • 11026-61000 GASKET-DRAIN PLUG 1 A12 - $1.60
  • 11130-18002 SEAL-OIL OIL PAN FRONT 1 A12 - $1.29
  • 11131-18002 SEAL-OIL OIL PAN REAR 1 A12 - NLA
  • 11132-18001 GASKET-OIL PAN RH 1 A12 - $4.42
  • 11133-18001 GASKET-OIL PAN LH 1 A12 - $4.08
  • 08110-61410 BOLT M6 FIXING OIL PAN 1 12 A12 - $0.32
  • 11025-18000 STUD-LOCATING OIL PAN GASKET 4 A12 - $0.58
  • 08915-13610 WASHER-LOCK FIXING OIL PAN 1 16 A12 - $0.72
08911-1062A NUT M6 FIXING OIL PAN 4 A12 08911-10610 $0.10
  • 08911-10610 NUT M6 FIXING OIL PAN 4 A12 - superceded
  • 11140-H1002 GAUGE-OIL LEVEL 1 A12 - superceded
  • 11140-H1003 GAUGE-OIL LEVEL (dipstick) 1 A12 0271- 2 11140-H1002 $7.82
  • 13035-H1000 ASSY-COVER TIMING CHAIN 1 A12 0570- 2 13035-18001 $92.69
  • 13035-18001 ASSY-COVER TIMING CHAIN 1 A12 -470 0 superceded
  • 13042-18000 SEAL-OIL CRANKSHAFT FRONT 1 A12 - superceded
  • 13510-H1000 SEAL-OIL CRANKSHAFT FRONT (NOK) 1 A12 0271- 2 13042-18000 $7.24
  • 13083-18001 TENSIONER-CHAIN TENSION SIDE 1 A12 -470 0 NLA
  • 13084-18000 SUPPORT-TENSIONER TENSION SIDE 1 A12 -470 0 NLA
  • 08110-62010 BOLT M6 FIXING TENSIONER 1 A12 -470 0 $0.14
  • 11046-73402 DOWEL-WATER PUMP 2 A12 - superceded
  • 11023-32200 DOWEL-WATER PUMP 2 A12 - 2 11046-73402 $0.76
  • 08110-64010 BOLT-HEX 6 A12 - $0.13
08915-1361A WASHER-LOCK 6 A12 08915-13610 $0.55
  • 08915-13610 WASHER-LOCK 6 A12 - superceded
  • 13044-18001 GASKET-TIMING CHAIN COVER 1 A12 - $6.05
  • 10005-H1000 SLINGER-ENGINE FRONT 1 A12 - NLA
08110-8161B BOLT-HEX M8 1 A12 - 08110-81611 $0.58
  • 08110-81611 BOLT-HEX M8 1 A12 - superceded
  • 13002-18020 SET-BUSHING CAMSHAFT STD SIZE 1 A12 - superceded
  • 13005-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.75MM 1 A12 - NLA
  • 13004-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.50MM 1 A12 - NLA
  • 13003-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.25MM 1 A12 - 2 13003-18020 NLA
  • 13002-H1020 SET-BUSHING CAMSHAFT STD SIZE 1 A12 - 2 13002-18020 $25.89
  • 13003-18020 SET-BUSHING CAMSHAFT UNDER SIZE 0.25MM 1 A12 - superceded
  • 11014-H1000 LINER-CYLINDER 500 1 A12 - NLA
  • 11012-H1000 LINER-CYLINDER 400 1 A12 - NLA
  • 11013-H1000 LINER-CYLINDER 450 1 A12 - NLA
  • 11041-H3900 ASSY-HEAD,CYLINDER 1 A12 0671-1272 22 11041-H1001 superceded
  • 11041-H3901 ASSY-HEAD CYLINDER 1 A12 0173-0273 32 11041-H3900 NLA
  • 11041-H3902 ASSY-HEAD CYLINDER 1 A12 0373- 2 11041-H3901 superceded
11041-H3903 ASSY-HEAD CYLINDER 1 A12 0373- 2 11041-H3902 $586.44
  • 11041-H1001 ASSY-HEAD CYLINDER 1 A12 -571 1 superceded
  • 13212-H0110 GUIDE-VALVE INTAKE 4 A12 - superceded
  • 13212-H0111 GUIDE-VALVE INTAKE 4 A12 - 2 13212-H0110 $7.68
  • 13213-H0110 GUIDE-VALVE EXHAUST 4 A12 - superceded
  • 13213-H0111 GUIDE-VALVE EXHAUST 4 A12 - 2 13213-H0110 $7.68
  • 11098-18011 INSERT-VALVE SEAT INTAKE 4 A12 - $15.19
  • 11098-18012 INSERT-VALVE SEAT INTAKE 4 A12 - 11098-18011 NLA
  • 11099-18010 INSERT-VALVE SEAT EXHAUST 4 A12 - NLA
  • 11099-H1010 INSERT-VALVE SEAT,EXHAUST 4 A12 -273 32 11099-18010 $14.65
  • 00933-20650 PLUG-TAPER 2 A12 - superceded
  • 01647-00011 PLUG-TAPER 2 A12 - 2 00933-20650 $0.74
00933-1401A PLUG-WELCH 1 A12 - 00933-14000 $0.96
  • 00933-14000 PLUG-WELCH 1 A12 - superceded
14065-B8600 STUD-MANIFOLD M8 4 A12 - 08213-82510 $1.05
  • 08213-82510 STUD-MANIFOLD M8 4 A12 - superceded
  • 08213-82810 STUD-MANIFOLD M8 5 A12 - $0.55
  • 11051-73403 PLUG-BLIND CYLINDER HEAD 4 A12 - $1.99
  • 13214-73400 RING-SNAP VALVE GUIDE 8 A12 - $0.32
  • 00931-30610 PLUG-HEATER OUTLET HOLE 1 A12 - $1.06
  • 11044-18004 GASKET-CYLINDER HEAD 1 A12 - superceded
  • 11044-H1000 GASKET-CYLINDER HEAD 1 A12 - 2 11044-18004 superceded
  • 11044-H3900 GASKET-CYLINDER HEAD 1 A12 0671- 0 11044-H1000 superceded
  • 11044-H3925 KIT-GASKET,CYLINDER HEAD 1 A12 0672- 2 11044-H3900 $21.36
  • 11045-H1000 RING-OIL,OIL GALLERY 1 A12 0672- $4.08
  • 11056-H1000 BOLT-FIXING CYLINDER HEAD 9 A12 1272- 2 11056-18001 $2.36
  • 11056-18001 BOLT-FIXING CYLINDER HEAD 9 A12 - superceded
  • 11057-18000 BOLT-FIXING CYLINDER HEAD 1 A12 - superceded
  • 11057-H1000 BOLT-FIXING CYLINDER HEAD 1 A12 1272- 2 11057-18000 $2.51
  • 11058-18000 WASHER-LOCK FIXING CYLINDER HEAD 1 10 A12 - superceded
  • 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD 1 10 A12 0172- 2 11058-18000 $2.28
  • 13264-H1000 ASSY-COVER VALVE ROCKER 1 A12 - NLA
  • 13264-H7000 ASSY-COVER,VALVE ROCKER 1 A12 0772- 0 13264-H1000 NLA
  • 08915-13610 WASHER-LOCK FIXING ROCKER COVER 6 A12 - $1.06
08360-61612 SCREW-MACHINE FIXING ROCKER COVER 6 A12 - 08310-61612 $0.65
  • 08310-61612 SCREW-MACHINE FIXING ROCKER COVER 6 A12 - superceded
15255-B3430 CAP-OIL FILLER 1 A12 - 15255-15953 $12.12
  • 15255-15953 CAP-OIL FILLER 1 A12 - superceded
  • 15270-B3400 PACKING-OIL FILLER CAP 1 A12 - 2 15270-11200 $1.40
  • 15270-11200 PACKING-OIL FILLER CAP 1 A12 - superceded
  • 13270-18001 PACKING-ROCKER COVER 1 A12 - NLA
  • 21200-A3001 ASSY-THERMOSTAT 82C 1 A12 EXHAUST & EVAPO - $11.62
  • 21200-A3005 ASSY-THERMOSTAT 88C FOR WINTER 1 OP A12 - $17.18
  • 21200-78502 ASSY-THERMOSTAT 76.5C FOR TROPICAL USE 1 OP A12 - NLA
  • 21200-78500 ASSY-THERMOSTAT 82C 1 A12 CRANK - NLA
  • 11060-G0300 OUTLET-WATER 1 A12 AUTOMATIC - $11.99
  • 11060-G0300 OUTLET-WATER 1 A12 MANUAL -273 3 superceded
  • 11060-H7000 OUTLET-WATER 1 A12 MANUAL 0373- 0 11060-G0300 $15.97
11062-58000 WASHER-JOINT WATER OUTLET [gasket] 1 A12 - 11062-18000 $0.59
  • 11062-18000 WASHER-JOINT WATER OUTLET [gasket] 1 A12 - superceded
  • 31139-49006 BOLT-HEX M8 2 A12 - $2.06
08915-1381A WASHER-SPRING 2 A12 - 08915-13810 $0.06
  • 08915-13810 WASHER-SPRING 2 A12 - superceded
  • 22120-U2001 ASSY-SWITCH WATER TEMP 1 A12 MANUAL 0373- $74.48
  • 24200-H7000 CLIP-SWITCH HARNESS 1 A12 MANUAL 0373- NLA
  • 11810-A3500 ASSY-CONTROL VALVE CRANK CASE EMISSIO 1 A12 - $9.97
  • 11826-H1000 HOSE-ROCKER COVER TO AIR CLEANER 1 A12 - superceded
  • 11826-H1900 HOSE-ROCKER COVER TO AIR CLEANER 1 A12 1070- 2 11826-H1000 superceded
  • 11826-H3900 HOSE-ROCKER COVER TO AIR CLEANER 1 A12 0771- 0 11826-H1900 $11.93
  • 11828-H1001 HOSE-PIPE CONNECTOR TO CONTROL VALV [PCV] 1 A12 - $19.45
16439-10802 CLAMP-HOSE 3 A12 - 16572-10801 $1.12
  • 16572-10801 CLAMP-HOSE 3 A12 - superceded
16572-H7260 CLAMP-HOSE 1 A12 - 16572-H1000 $1.60
  • 16572-H1000 CLAMP-HOSE 1 A12 - superceded
  • 11830-H1001 CONNECTOR-PIPE 1 A12 CRANK - NLA
  • 11830-H1900 CONNECTOR-PIPE 1 A12 EVAPO - superceded
  • 11830-H1901 CONNECTOR-PIPE 1 A12 EVAPO 0570- 0 11830-H1900 $16.41
  • 14920-H1906 ASSY-VALVE CONTROL 1 A12 EVAPO - 2 14920-H1905 NLA
  • 14920-H1902 ASSY-VALVE CONTROL 1 A12 MANUAL 0870- 2 14920-H1901 $119.38
  • 14920-H7101 ASSY-VALVE CONTROL 1 A12 AUTOMATIC 0873- 2 14820-H7100 NLA
  • 14920-H7100 ASSY-VALVE CONTROL 1 A12 AUTOMATIC 0772- 2 14920-H1907 NLA
  • 14920-H7001 ASSY-VALVE CONTROL 1 A12 MANUAL 0873- 2 14920-H7000 $256.31
  • 14920-H7000 ASSY-VALVE CONTROL 1 A12 MANUAL 0772- 2 14920-H1902 superceded
  • 14920-H1903 ASSY-VALVE CONTROL 1 A12 MANUAL 0873- 2 14920-H1902 superceded
  • 14920-H1901 ASSY-VALVE CONTROL 1 A12 0670- 2 14920-H1900 superceded
  • 14920-H1908 ASSY-VALVE,CONTROL 1 A12 AUTOMATIC - NLA
  • 14920-H1907 ASSY-VALVE,CONTROL 1 A12 AUTOMATIC - 2 14920-H1906 $119.38
  • 14920-H1900 ASSY-VALVE CONTROL 1 A12 - superceded
  • 14920-H1905 ASSY-VALVE CONTROL 1 A12 EVAPO - $119.38
  • 08120-61210 BOLT-HEX M6 2 A12 - $0.29
08915-1361A WASHER-LOCK M6 2 A12 - 08915-13610 $0.55
  • 08915-13610 WASHER-LOCK M6 2 A12 - superceded
  • B2318-N3300 TUBE-VACUUM L=150 IN TAKE MANIFOLD TO [?] 1 A12 - 14917-E4600 $90.06
  • 14917-E4600 TUBE-VACUUM L=150 IN TAKE MANIFOLD TO 1 A12 - superceded
  • 14918-H1900 TUBE-VACUUM L=105 IN TAKE MANIFOLD TO 1 A12 EVAPO - 4 14917-E4600 NLA
  • 14917-H1901 TUBE-VACUUM L=170 CONTROL VALVE TO CAR 1 A12 EVAPO - 4 14917-H1900 $1.05
  • 02141-319W0 TUBE-VACUUM L=5000 CONTROL VALVE TO CAR 1 A12 - 4 B2318-73002 $1.19
  • B2318-73002 TUBE-VACUUM L=5000 CONTROL VALVE TO CAR 1 A12 - 4 14917-H1901 superceded
14917-H1901 TUBE-VACUUM L=260 CONTROL VALVE TO CAR 1 A12 - 14917-H1900 $1.05
  • 14917-H1900 TUBE-VACUUM L=260 CONTROL VALVE TO CAR 1 A12 - superceded
02141-319W0 TUBE-VACUUM L=155 CONTROL VALVE TO AIR 1 A12 0772- B2318-73002 $1.19
  • B2318-73002 TUBE-VACUUM L=155 CONTROL VALVE TO AIR 1 A12 0772- superceded
  • 14875-A3000 CONNECTOR-VACUUM TO IN TAKE MANIFOLD 1 A12 - $4.10
  • 14875-H1900 CONNECTOR 1 A12 EVAPO - 4 14875-A3000 $8.39
  • 24220-B0100 CLIP-CABLE 1 A12 EVAPO - $0.70
  • 14910-A5500 ASSY-VALVE FLOW GUIDE 1 A12 EVAPO - NLA
  • 14910-A5501 ASSY-VALVE FLOW GUIDE 1 A12 EVAPO - NLA
  • 14910-A5502 ASSY-VALVE FLOW GUIDE 1 A12 EVAPO - 2 14910-A5501 superceded
  • 14910-H3900 ASSY-VALVE FLOW GUIDE 1 A12 EVAPO 1071- 2 14910-A5502 superceded
  • 14910-H3901 ASSY-VALVE FLOW GUIDE 1 A12 - 2 14910-H3900 superceded
  • 14910-H3902 ASSY-VALVE FLOW GUIDE 1 A12 0972- 2 14910-H3901 superceded
  • 14910-N2203 ASSY-VALVE FLOW GUID 1 A12 EVAPO - 2 14910-N2202 $25.22
  • 14913-A5500 TUBE-EVAPO CONTROL L=200 2 A12 EVAPO - superceded
  • 14913-A5501 TUBE-EVAPO CONTROL L=200 1 A12 EVAPO - 2 14913-A5500 NLA
  • 14910-N2200 ASSY-VALVE FLOW GUIDE 1 A12 EVAPO - superceded
  • 14910-N2202 ASSY-VALVE FLOW GUIDE 1 A12 EVAPO - 2 14910-N2200 superceded
  • 16439-A0602 CLAMP-HOSE 4 A12 EVAPO - NLA
  • 08120-61210 BOLT-HEX M6 1 A12 EVAPO -
  • 08915-13610 WASHER-SPRING 1 A12 EVAPO -
  • 14911-A5500 TUBE-EVAPO CONTROL(L=80) 2 A12,MANUAL 0671- NLA
  • 14915-H3900 CONNECTOR-3 WAY 1 A12,MANUAL 0671- NLA
  • 16439-A0602 CLAMP-HOSE 6 A12,MANUAL 0671- NLA
  • 22318-C0601 TUBE-VACUUM CONTROL(L=135) 2 A12,MANUAL 0671- NLA
  • 14955-H3900 ASSY-VALVE,VACUUM CUTTING 1 A12,MANUAL 0671- $86.39
  • 08120-62010 BOLT 2 A12,MANUAL 0671-
  • 08915-13610 WASHER-LOCK 2 A12,MANUAL 0671-
  • 14956-H3900 ASSY-TUBE,RUBBER,WITH ORIFICE (L=5 1 A12,MANUAL 0671- $37.52
  • 14956-H3901 ASSY-TUBE,RUBBER,WITH ORIFICE (L=6 1 A12,MANUAL 1171- superceded
  • 14956-H3900 ASSY-TUBE,RUBBER,WITH ORIFICE (L=5 1 A12,MANUAL 0872- 2 14956-H3901 $37.52
  • 14960-H3900 CONNECTOR-3 WAY 1 A12,MANUAL 0671- $1.91
  • 24220-B0100 CLIP-TUBE 1 A12,MANUAL 0671-0771 1 $0.70
  • 12010-H1011 SET-PISTON WITH PIN STD 4 A12 0672- 2 12010-H1001 $51.07
  • 12010-H1003 SET-PISTON WITH PIN 0.25 OVER SIZE 4 A12 - NLA
  • 12010-H1004 SET-PISTON WITH PIN 0.50 OVER SIZE 4 A12 - NLA
12010-H1065 SET-PISTON WITH PIN 0.50 OVER SIZE 4 A12 0672- 2 12010-H1014 $53.60
  • 12010-H1014 SET-PISTON WITH PIN 0.50 OVER SIZE 4 A12 0672- 2 12010-H1004 superceded
  • 12010-H1005 SET-PISTON WITH PIN 0.75 OVER SIZE 4 A12 - NLA
  • 12010-H1006 SET-PISTON WITH PIN 1.00 OVER SIZE 4 A12 - NLA
12010-H1066 SET-PISTON WITH PIN 1.00 OVER SIZE [-0.40] 4 A12 0672- 2 12010-H1016 $53.55
  • 12010-H1016 SET-PISTON WITH PIN 1.00 OVER SIZE 4 A12 0672- 2 12010-H1006 superceded
  • 12010-H1007 SET-PISTON WITH PIN 1.25 OVER SIZE 4 A12 - NLA
  • 12010-H1008 SET-PISTON WITH PIN 1.50 OVER SIZE 4 A12 - NLA
12010-H1061 SET-PISTON WITH PIN STD 4 A12 - 12010-H1001 $53.55
  • 12010-H1001 SET-PISTON WITH PIN STD 4 A12 - superceded
12035-H6201 SET-RING PISTON 0.50 OVER SIZE 4 A12 - 2 12035-B3040 $110.98
  • 12035-B3040 SET-RING PISTON 0.50 OVER SIZE 4 A12 - 2 12035-H1002 superceded
12039-H6200 SET-RING PISTON 1.50 OVER SIZE 4 A12 - 2 12039-B3040 $115.00
  • 12039-B3040 SET-RING PISTON 1.50 OVER SIZE 4 A12 - 2 12039-H1002 superceded
  • 12039-H1002 SET-RING PISTON 1.50 OVER SIZE 4 A12 -
  • 12038-H1002 SET-RING PISTON 1.25 OVER SIZE 4 A12 -
  • 12037-B3040 SET-RING PISTON 1.00 OVER SIZE 4 A12 - 2 12037-H1002
  • 12033-H1002 SET-RING PISTON STD 4 A12 -
  • 12037-H1002 SET-RING PISTON 1.00 OVER SIZE 4 A12 -
  • 12035-H1002 SET-RING PISTON 0.50 OVER SIZE 4 A12 -
  • 12034-H1002 SET-RING PISTON 0.25 OVER SIZE 4 A12 -
  • 12033-H6201 SET-RING PISTON STD 4 A12 - 2 12033-B3040
  • 12033-B3040 SET-RING PISTON STD 4 A12 - 2 12033-H1002
  • 12036-H1002 SET-RING PISTON 0.75 OVER SIZE 4 A12 -
  • 12100-H1000 ASSY-CONNECTING ROD 4 A12 - $68.64
  • 12109-H1001 BOLT-CONNECTING ROD (TOKYO RASI) 8 A12 - $2.59
  • 12109-H1011 BOLT-CONNECTING ROD (TOKAI SEIAT 8 A12 - NLA
  • 12112-18000 NUT-HEX CONNECTING ROD 8 A12 - NLA
  • 12111-20906 BUSHING-CONNECTING ROD UNDERSIZE 100 8 A12 - NLA
  • 12111-20910 BEARING-CONNECTING ROD STD 8 A12 - 12111-20900 $6.66
  • 12111-20900 BEARING-CONNECTING ROD STD 8 A12 - superceded
  • 12111-20901 BUSHING-CONNECTING ROD UNDERSIZE 8 8 A12 -
  • 12111-20902 BUSHING-CONNECTING ROD UNDERSIZE 12 8 A12 -
  • 12111-20903 BUSHING-CONNECTING ROD UNDERSIZE 25 8 A12 -
  • 12111-20905 BUSHING-CONNECTING ROD UNDERSIZE 75 8 A12 -
  • 12111-20904 BUSHING-CONNECTING ROD UNDERSIZE 50 8 A12 -
  • 12200-H1000 ASSY-CRANKSHAFT 1 A12 MANUAL - $624.02
  • 12200-H1001 CRANKSHAFT 1 A12 -671 12 12200-H1000 superceded
  • 12200-H1000 CRANKSHAFT 1 A12 0671- 2 12200-H1001 superceded
  • 12200-H5000 CRANKSHAFT 1 A12 0572- 2 12200-H1000 $624.02
  • 00933-20650 PLUG-TAPER 4 A12 - superceded
  • 01647-00011 PLUG-TAPER 4 A12 - 2 00933-20650 $0.60
  • 32202-18000 BUSHING-PILOT 1 A12 MANUAL - $3.98
  • 12316-30000 KEY-WOODLUF 5X16 2 A12 - $1.13
  • 13021-H1000 SPROCKET-CRANK 1 A12 - $24.34
  • 12301-30000 WASHER-PACKING CRANKSHAFT 0 A12 - $0.53
  • 12299-18000 SHIM-CRANK SPROCKET 0 A12 - $0.73
  • 12302-18000 THROWER-OIL CRANKSHAFT 1 A12 - $1.57
  • 12303-H1001 PULLEY-CRANKSHAFT 1 A12 0272- 0 12303-18002 $37.66
  • 12303-18002 PULLEY-CRANKSHAFT 1 A12 - superceded
  • 12308-H1000 WASHER-PULLEY BOLT 1 A12 - $1.29
  • 12309-78200 BOLT-CRANK PULLEY 1 A12 - $5.73
  • 12310-H1000 ASSY-FLY WHEEL 1 A12 MANUAL - $267.18
  • 12312-18000 GEAR-RING FLY WHEEL 1 A12 MANUAL - $96.65
  • 12313-10600 DOWL 3 A12 MANUAL - $0.25
  • 12315-H1001 BOLT-FLY WHEEL 6 A12 MANUAL - $4.38
  • 12331-20300 ASSY-DRIVE PLATE & GEAR 1 A12 AUTOMATIC - $322.28
  • 12330-20300 PILOT-CONVERTER 1 A12 AUTOMATIC - $18.66
  • 12333-20300 PLATE-CRANK CONVERTER 1 A12 AUTOMATIC - $9.44
  • 12315-H1000 BOLT-FLY WHEEL 6 A12 AUTOMATIC - $3.51
  • 12212-H1000 SET-BEARING US 1.00MM 1 A12 -
  • 12207-M7201 SET-BEARING STD 1 A12 - 12207-H1000 $71.58
  • 12207-H1000 SET-BEARING STD 1 A12 -
  • 12208-H1000 SET-BEARING US 0.20MM 1 A12 -
  • 12209-H1000 SET-BEARING US 0.25MM 1 A12 -
  • 12210-H1000 SET-BEARING US 0.50MM 1 A12 -
  • 12211-H1000 SET-BEARING US 0.75MM 1 A12 -
  • 13001-H7000 ASSY-CAMSHAFT 1 A12 0772- 0 13001-H2300 NLA
  • 13001-H1000 CAMSHAFT 1 A12 - NLA
  • 11023-78200 PLUG-TAPER 1 A12 - $0.45
  • 13032-18000 DOWEL-CAMSHAFT GEAR 1 A12 - $0.55
  • 13010-18001 PLATE-CAMSHAFT 1 A12 - $5.94
08110-6161A BOLT-FIXING CAMSHAFT PLATE 2 A12 - 01111-00022 $0.57
  • 01111-00022 BOLT-FIXING CAMSHAFT PLATE 2 A12 - superceded
08915-1361A WASHER-LOCK FIXING CAMSHAFT PLATE 2 A12 - 08915-13610 $0.54
  • 08915-13610 WASHER-LOCK FIXING CAMSHAFT PLATE 2 A12 - superceded
13024-H8500 SPROCKET-CAMSHAFT 1 A12 - 13024-18001 $44.64
  • 13024-18001 SPROCKET-CAMSHAFT 1 A12 - superceded
  • 13082-18000 BOLT-CAMSHAFT SPROCKET 1 A12 - $1.24
  • 13030-18000 WASHER-CAMSHAFT 1 A12 - $1.45
08915-2401A WASHER-LOCK 1 A12 - 08915-14010 $0.09
  • 08915-14010 WASHER-LOCK 1 A12 - superceded
  • 13028-18001 CHAIN-CAMSHAFT 1 A12 - $51.70
  • 13070-18001 ASSY-TENSIONER CHAIN 1 A12 - $66.53
  • 08120-63510 BOLT-FIXING CHAIN TENSIONER 2 A12 - $0.28
  • 08915-13610 WASHER-LOCK FIXING CHAIN TENSIONER 2 A12 - superceded
  • 13201-H1000 VALVE-INTAKE 4 A12 - $7.01
  • 13202-H1000 VALVE-EXHAUST 4 A12 - $14.98
  • 13203-H1000 SPRING-VALVE OUTER 8 A12 - $3.57
  • 13205-18000 SEAT-VALVE SPRING 8 A12 - $0.90
  • 13209-H2302 RETAINER-VALVE SPRING 8 A12 0772- 0 13209-H2301 $2.07
  • 13209-18000 RETAINER-VALVE SPRING 8 A12 - superceded
  • 13209-H2300 RETAINER-VALVE SPRING 8 A12 - 2 13209-18000 superceded
  • 13209-H2301 RETAINER-VALVE SPRING 8 A12 0670-0672 22 13209-H2300 superceded
  • 13210-73400 COLLET-VALVE 1 16 A12 - superceded
  • 13210-H1000 COLLET-VALVE 1 16 A12 0272- 0 superceded
  • 13210-U0100 COLLET-VALVE 1 16 A12 1072- 2 13210-H1000 $1.06
  • 13207-18000 SEAL-OIL VALVE (INTAKE ONLY) 8 A12 -672 2 $1.11
  • 13207-H2301 SEAL-LIP VALVE OIL (INTAKE ONLY,KEEPER) 4 OP A12 - 2 13207-H2300 $4.62
  • 13207-H2310 SEAL-LIP,VALVE,OIL (INTAKE ONLY,NOK) 4 OP A12 - $4.62
  • 13219-H1000 SHROUD-VALVE INNER 8 A12 0772- 2 13207-18000 $2.12
  • 13219-H1000 SHROUD-VALVE INNER,FOR TROPICAL REG 8 OP A12 - $2.12
  • 13252-18000 ASSY-SHAFT & VALVE ROCKER 1 A12 - $37.57
  • 13254-58000 PLUG-EXPANSHION ROCKER SHAFT 2 A12 - $0.40
  • 13256-18000 SPRING-INSIDE ROCKER SHAFT 4 A12 - $0.57
  • 13222-18001 BRACKET-ROCKER SHAFT 5 A12 - $7.71
  • 13224-18000 BOLT-ROCKER SHAFT 5 A12 - $1.26
  • 08915-43810 WASHER-PLAIN 5 A12 -
  • 13257-18003 ROCKER-VALVE NO.1 4 A12 - 13257-18001 $11.94
  • 13257-18001 ROCKER-VALVE NO.1 4 A12 - superceded
  • 13258-18003 ROCKER-VALVE NO.2 4 A12 - 13258-18001 $12.19
  • 13258-18001 ROCKER-VALVE NO.2 4 A12 - superceded
  • 13234-18000 SCREW-ADJUSTING ROCKER VALVE 8 A12 -
  • 13288-18001 NUT-ADJUSTING ROCKER VALVE 8 A12 -
  • 13231-H1000 LIFTER-VALVE 8 A12 - superceded
  • 13231-H1001 LIFTER-VALVE 8 A12 - 13231-H1000 $15.64
  • 13238-H1001 ROD-PUSH 8 A12 1070- 2 13238-H1000 $4.24
  • 13238-H1000 ROD-PUSH 8 A12 - superceded
  • 14003-H1900 MANIFOLD-INTAKE 1 A12 EXHAUST -571 1 superceded
  • 14003-H1901 MANIFOLD-INTAKE 1 A12,CALIFORNIA 0671-0771 10 14003-H1900 superceded
  • 14003-H3900 MANIFOLD-INTAKE 1 A12,MANUAL 0771- 5 14003-H1900 NLA
  • 14003-H3901 MANIFOLD-INTAKE 1 A12,AUTO 0771- 5 14003-H1901 NLA
  • 14003-H1000 MANIFOLD-INTAKE 1 A12 CRANK - NLA
  • 08216-62210 STUD FIXING CARBURETOR 4 A12 -
  • 14004-H1930 MANIFOLD-EXHAUST 1 A12 EXHAUST - superceded
  • 14004-H3931 MANIFOLD-EXHAUST 1 A12 0373- 4 14004-H3930 $203.14
  • 14004-H3950 MANIFOLD-EXHAUST 1 A12 0671- superceded
  • 14004-H1030 MANIFOLD-EXHAUST 1 A12 CRANK -273 3 NLA
  • 14004-H3930 MANIFOLD-EXHAUST 1 A12 -273 32 14004-H3950 superceded
  • 08213-82810 STUD FIXING EXHAUST MANIFOLD TO EXHAUST 2 A12 -
14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD 1 A12 - 14005-18000 $3.41
  • 14005-18000 GASKET-INTAKE TO EXHAUT MANIFOLD 1 A12 - superceded
  • 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD 2 A12 -
  • 01111-00032 BOLT 1 A12 -
  • 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD 3 A12 -
  • 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 9 A12 -
  • 08915-13810 WASHER-LOCK 5 A12 -
  • 14037-32200 YOKE-MANIFOLD 4 A12 - NLA
14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD 1 A12 - 14035-18000 $9.26
  • 14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD 1 A12 - superceded
  • 14022-18000 SPRING-HEAT CONTROL THERMS 1 A12 - $7.24
  • 14025-85061 KEY-HEAT CONTROL VALVE 1 A12 - NLA
  • 14026-18001 WEIGHT-COUNTER VALVE 1 A12 - NLA
  • 14027-36700 WASHER-HEAT CONTROL 1 A12 - $0.30
  • 14047-36700 SPRING-STOPPER HEAT CONTROL 1 A12 - NLA
00933-1101A PLUG-WELCH 1 A12 - 00933-11000 $0.38
  • 00933-11000 PLUG-WELCH 1 A12 - superceded
  • 08310-51610 SCREW-SET 1 A12 -
  • 14006-18000 PIN-SPRING HEAT CONTROL TO INTAKE MANIF 1 A12 -
  • 16174-H1000 INSULATOR-CARBURETOR 1 A12 -
  • 16177-H1000 KIT-JOINT SEAT 1 A12 -
  • 16174-H3900 INSULATOR-CARBURETOR 1 A12 0671-
  • 16177-H3900 KIT-JOINT SEAT 1 A12 0671-
  • 08915-13610 WASHER-SPRING 4 A12 -
  • 08911-10610 NUT-HEX M6 4 A12 -
  • 20010-H3100 ASSY-TUBE EXHAUST FRONT 1 MANUAL 1072- 5 20010-H1000 $26.19
  • 20010-H1020 ASSY-TUBE,EXHAUST,FRONT 1 AUTOMATIC -972 2 superceded
  • 20010-H3200 ASSY-TUBE EXHAUST FRONT 1 AUTOMATIC 1072- 5 20010-H1020 $29.09
  • 20010-H1000 ASSY-TUBE EXHAUST FRONT 1 MANUAL -972 2 superceded
  • 20602-27700 NUT-FIXING TUBE END 2 - superceded
  • 14011-29901 NUT-FIXING TUBE END 2 - 2 20602-27700 $1.99
  • 20635-18000 STOPPER-MUFFLER BOUND 1 - NLA
  • 20100-H1000 ASSY-MUFFLER WITH REAR TUBE 1 SEDAN -972 2 superceded
  • 20100-H7001 ASSY-MUFFLER WITH REAR TUBE 1 SEDAN 1072- 5 20100-H1000 $63.54
  • 20100-H1800 ASSY-MUFFLER WITH REAR TUBE 1 COUPE - superceded
  • 20100-H2500 ASSY-MUFFLER WITH REAR TUBE 1 COUPE -972 22 20100-H1800 superceded
  • 20100-H7101 ASSY-MUFFLER WITH REAR TUBE 1 COUPE 1072- 5 20100-H2500 $48.34
20630-V0100 RING-RUBBER MUFFLER CLAMP 2 A12,GX - 2 20630-P4400 $2.40
  • 20630-P4400 RING-RUBBER MUFFLER CLAMP 2 A12,GX - 2 20630-18000 superceded
  • 20630-18000 RING-RUBBER MUFFLER CLAMP 2 - superceded
20643-B5000 CLIP-TUBE EXHAUST 1 - 20620-H1000 $2.83
  • 20620-H1000 CLIP-TUBE EXHAUST 1 - superceded
  • 08915-43810 WASHER-PLAIN M8 2 -
  • 08915-13810 WASHER-SPRING M8 1 -
  • 08110-86010 BOLT-HEX M8 1 -
  • 08911-10810 NUT-HEX M8 1 -
  • 20640-18000 STRAP-EXHAUST HANGER 1 - superceded
  • 42013-0101P STRAP-EXHAUST HANGER 1 - 2 20640-18000 $5.82
  • 20641-18000 WASHER-PLAIN EXHAUST 2 -
  • 08911-10810 NUT-HEX M8 2 -
  • 08915-13810 WASHER-SPRING M8 2 -
  • 08110-82210 BOLT-HEX M8 2 -
  • 20321-H2000 FINISHER-EXHAUST 1 OP - NLA
  • 20321-H2500 FINISHER-EXHAUST 1 OP - $13.74
20720-N2226 KIT-SEALANT,EXH TUBE JOINT 1 FOR REPAIR 0972- 20720-N2225 $21.03
  • 20720-N2225 KIT-SEALANT,EXH TUBE JOINT 1 FOR REPAIR 0972- superceded
  • 15010-H9701 ASSY-PUMP OIL WITH OUT OIL FILTER 1 A12 0473- 2 15010-H6200 $83.75
  • 15010-H6200 ASSY-PUMP OIL WITH OUT OIL FILTER 1 A12 0473- 2 15010-H1000 superceded
  • 15010-H1000 ASSY-PUMP OIL WITH OUT OIL FILTER 1 A12 -373 3 superceded
  • 15020-H1025 ASSY-SHAFT DRIVE OIL PUMP 1 A12 - superceded
  • 15020-H1005 ASSY-SHAFT DRIVE OIL PUMP 1 A12 - 2 15020-H1025 $24.58
  • 15025-18003 GASKET-OIL PUMP 1 A12 -
  • 15132-H1000 ASSY-VALVE OIL REGULATOR 1 A12 -
  • 08310-53010 SET-BOLT BODY TO COVER 1 A12 -
  • 08915-13510 WASHER-SPRING 1 A12 -
  • 15066-18000 GASKET-OIL PUMP TO CYLINDER BLOCK 1 A12 -
  • 08915-13810 WASHER-LOCK 3 A12 -
  • 15036-18000 BOLT-OIL PUMP 2 A12 -
  • 08110-85510 BOLT 1 A12 -
  • 15050-H1000 ASSY-STRAINER OIL 1 A12 - $14.41
  • 15053-18000 GASKET-OIL STRAINER 1 A12 -
  • 08110-82010 BOLT 2 A12 -
  • 08915-13810 WASHER-LOCK 2 A12 -
15208-55Y00 ASSY-OIL FILTER CARTRIDGE 1 A12 0272- 15208-H1010 $5.31
  • 15208-H1010 ASSY-OIL FILTER CARTRIDGE 1 A12 0272- 2 15208-13212 superceded
  • 15208-13211 ASSY-OIL FILTER CARTRIDGE 1 A12 - superceded
  • 15208-13212 ASSY-OIL FILTER CARTRIDGE 1 A12 - 2 15208-13211 superceded
  • 16010-H1601 ASSY-CARBURETOR (HITACHI DCG 1 A12 CRANK 1070- 2 16010-H1600 superceded
  • 16010-H1602 ASSY-CARBURETOR (HITACHI DCG 1 A12 CRANK 0771- 2 16010-H1601 $243.83
  • 16010-H1600 ASSY-CARBURETOR (HITACHI) 1 A12 CRANK - superceded
  • 16118-H1000 ASSY-CHAMBER THROTTLE 1 A12 CRANK - superceded
  • 16145-91460 SPRING IDLER ADJUST SCREW 1 A12 CRANK -
  • 16145-50000 SPRING THROTTLE ADJUST SCREW 1 A12 CRANK -
  • 16129-14811 SCREW-THROTTLE ADJUST 1 A12 CRANK - 2 16129-25715
  • 16129-25715 SCREW THROTTLE ADJUST 1 A12 CRANK -
  • 16144-B0815 SCREW IDLE ADJUST 1 A12 CRANK -
  • 16082-18010 PLATE-ADJUST 1 A12 CRANK -
  • 16065-10620 SCREW 6D 1 A12 CRANK -
  • 16065-H1010 SCREW 6D 1 A12 CRANK - 2 16065-H1010
  • 16029-18010 WASHER 6D 1 A12 CRANK -
  • 16061-18010 FLOAT 1 A12 CRANK -
  • 16066-18010 SHAFT FLOAT 1 A12 CRANK -
  • 16101-H1000 VALVE NEEDLE 1 A12 CRANK -
  • 16094-10400 WASHER 10D 2 A12 CRANK -
  • 16098-25710 FILTER 1 A12 CRANK -
  • 16025-H1000 TUBE EMULSION (P) 1 A12 CRANK -
  • 16026-25710 TUBE EMULSION (S) 1 A12 CRANK -
  • 16026-B0810 TUBE EMULSION (S) 1 A12 CRANK - 2 16026-25710
  • 16171-25710 WEIGHT INJECTOR 1 A12 CRANK -
  • 16033-18017 JET-MAIN #92(2000M) 1 OP A12 -
  • 16034-18016 JET-MAIN #86(4000M) 1 OP A12 -
  • 16034-19915 JET MAIN #98 1 A12 CRANK -
  • 16135-33815 JET MAIN #135 1 A12 CRANK -
  • 16050-18010 BLEED MAIN AIR #80 2 A12 CRANK -
  • 16204-08000 BLEED MAIN AIR #100 1 A12 CRANK -
  • 16213-08000 BLEED MAIN AIR #220 1 A12 CRANK -
  • 16052-85060 BLEED MAIN AIR #200 1 A12 CRANK - 2 16213-08000
  • 16055-14811 JET SLOW #43 1 A12 CRANK -1173 3
  • 16054-B0810 JET SLOW #50 1 A12 CRANK -
  • 16059-14810 VALVE POWER #60 1 A12 CRANK -
  • 16455-H1000 KIT-GASKET 1 A12 CRANK -
  • 16455-H6200 KIT-GASKET 1 A12 CRANK - 2 16455-H1000
  • 16465-H1000 SCREW & WASHER ETE KIT (A) 1 A12 CRANK -
  • 16475-H1000 SCREW & WASHER ETE KIT (B) 1 A12 CRANK -
  • 16134-18010 LEVER THROTTLE 1 A12 CRANK -
  • 16116-18010 SLEEVE 1 A12 CRANK -
  • 16133-H1000 LEVER STARTING 1 A12 CRANK -
  • 16084-58000 WASHER 1 A12 CRANK -
  • 16084-22010 WASHER 1 A12 CRANK - 2 16084-58000
  • 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H 1 A12 CRANK - 2 16160-H1000
  • 16160-H1000 SPRING THROTTLE RETURN 1 A12 CRANK -
  • 16141-18010 ROD CONNECTING 1 A12 CRANK -
  • 16272-36710 PLATE DRAIN 2 A12 CRANK -
  • 16151-H1000 PISTON 1 A12 CRANK -
  • 16148-H1000 SPRING PISTON RETURN 1 A12 CRANK -
  • 16307-04000 COVER PUMP 1 A12 CRANK -
  • 16302-18010 LEVER PUMP 1 A12 CRANK -
  • 16305-19915 SHAFT PUMP LEVER 1 A12 CRANK -
  • 16143-18010 ROD PUMP 1 A12 CRANK -
  • 16011-H1600 ASSY-CHOKE CHAMBER 1 A12 CRANK - superceded
  • 16011-H1601 ASSY-CHOKE CHAMBER 1 A12 CRANK - 2 16011-H1600 $311.81
  • 16248-H1000 ROD CHOKE CONNECTING 1 A12 CRANK -
  • 16161-H1000 HANGER SPRING 1 A12 CRANK -
  • 16161-H1001 HANGER-SPRING 1 A12 CRANK 0970- 2 16161-H1000
  • 16155-B0815 ARM THROTTLE WIRE 1 A12 CRANK -
  • 16165-H1600 ARM CHOKE WIRE 1 A12 CRANK -
  • XX010-H1925 KIT-REPAIR A 1 A12 CRANK - 2 X6010-H1925 superceded
  • 16009-H1910 KIT-REPAIR A CARBURETOR 1 A12 CRANK - 2 XX010-H1925 superceded
  • 16009-H7000 KIT-REPAIR A CARBURETOR 1 A12 CRANK - 2 16009-H1910 superceded
  • 16009-H6200 KIT-REPAIR A CARBURETOR 1 A12 CRANK - 2 16009-H7000 $4.85
  • X6010-H1925 KIT-REPAIR A 1 A12 CRANK - superceded
  • 16009-H1911 KIT-REPAIR B CARBURETOR 1 A12 CRANK - 2 XX010-H1926 $38.34
  • X6010-H1926 KIT-REPAIR B 1 A12 CRANK - superceded
  • XX010-H1926 KIT-REPAIR B 1 A12 CRANK - 2 X6010-H1926 superceded
  • 16500-H1005 ASSY-AIR CLEANER 1 A12 CRANK - 2 16500-H1001 NLA
  • 16500-H1901 ASSY-AIR CLEANER 1 A12 EVAPO - superceded
  • 16500-H1905 ASSY-AIR CLEANER 1 A12 EVAPO - 2 16500-H1901 $108.14
  • 16500-H1001 ASSY-AIR CLEANER 1 A12 CRANK - superceded
  • 16500-H1010 ASSY-AIR CLEANER,FOR COLD REGION 1 A12 CRANK - superceded
  • 16500-H1015 ASSY-AIR CLEANER,FOR COLD REGION 1 A12 CRANK - 2 16500-H1010 NLA
  • 16500-H1910 ASSY-AIR CLEANER,FOR COLD REGION 1 A12 EVAPO - superceded
  • 16500-H1915 ASSY-AIR CLEANER,FOR COLD REGION 1 A12 EVAPO - 2 16500-H1910 NLA
16547-52A00 PACKING 1 A12 - 16547-H1000 $4.11
  • 16547-H1000 PACKING 1 A12 - superceded
A6548-M5600 PACKING 1 A12 - 16548-18000 $3.25
  • 16548-18000 PACKING 1 A12 - superceded
  • 16568-H1000 ASSY-PACKING 1 A12 - NLA
  • 16546-18000 ASSY-ELEMENT,PAPER(VISCOUS) 1 A12 - $5.99
  • 16523-H1000 INSULATOR 1 A12 - $2.93
  • 16596-78521 MARK 1 A12 - NLA
  • 01237-00011 NUT-WING 1 A12 - 2 16551-H1000 superceded
  • 16551-08000 NUT-WING 1 A12 - 2 01237-00011 superceded
  • 16551-W7000 16551-08000 $2.04
  • 16551-H1000 NUT-WING 1 A12 - superceded
  • 16525-H1001 STUD-AIR CLEANER 1 A12 - superceded
  • 16525-H5000 STUD-AIR CLEANER 1 A12 0573- 2 16525-H1001 $1.82
  • 16573-H1001 SUPPORT-AIR CLEANER 1 A12 - $5.99
  • 08915-43610 WASHER-RLAIN 2 A12 -
  • 08120-61210 BOLT 5 A12 -
  • 08915-13610 WASHER-LOCK 5 A12 -
  • 16574-H1001 SUPPORT-AIR CLEANER,FRONT 1 A12 - $3.19
  • 08915-53610 WASHER-PLAIN 1 A12 -
  • A6530-70N40 DUCT-COVER TO AIR CLEANER 1 A12 - 16530-H1001 $39.24
  • 16530-H1001 DUCT-COVER TO AIR CLEANER 1 A12 - superceded
01555-00291 CLAMP-DUCT 2 A12 - 08723-14400 $2.41
  • 08723-14400 CLAMP-DUCT 2 A12 - superceded
  • 16590-H1000 ASSY-COVER,EXHAUST MANIFOLD 1 A12 - $30.41
16400-H8501 ASSY-STRAINER,FUEL 1 A12 0671- 0 16400-E3000 $4.74
  • 16400-E3000 ASSY-STRAINER,FUEL 1 A12 0671- 0 16400-A0600 superceded
  • 16400-A0600 ASSY-STRAINER FUEL 1 A12 - superceded
  • 16440-H1002 TUBE-FLEXIBLE L=200 1 A12 - superceded
A8742-20020 TUBE-FLEXIBLE 1 A12 - 08742-20020 $33.00
  • 08742-20020 TUBE-FLEXIBLE 1 A12 - 4 16440-H1002 superceded
  • 16439-A0600 CLAMP-HOSE FUEL STRAINER SIDE 1 A12 -
  • 08723-11500 CLAMP-HOSE FUEL PUMP SIDE 1 A12 -
  • 17523-H1900 TUBE-FUEL PUMP TO CARBURETOR 1 A12 0671-0370 0
  • 17523-H1901 TUBE-FUEL PUMP TO CARBURETOR 1 A12 0470-0970 0 superceded
  • 17523-H1902 TUBE-FUEL PUMP TO CARBURETOR 1 A12 1070- 2 17523-H1901
  • 08742-20020 HOSE-FUEL (6X13.3X2.2M) 1 A12 - 2 A7515-H1800
  • A7515-H1800 TUBE-FUEL FLEXIBLE (6X13.5X5M) 1 A12 - superceded
  • 16439-22100 CLAMP-FUEL TUBE 4 A12 -370 0
  • 17106-H1001 CLAMP-FUEL TUBE 1 A12 0470- 2 17106-H1000
  • 17106-H1000 CLAMP-FUEL TUBE 1 A12 -370 0 superceded
  • 17107-H1000 CLAMP-FUEL TUBE 1 A12 -370 0 superceded
  • 17107-H2300 CLAMP-FUEL TUBE 1 A12 0470- 2 17107-H1000
  • 17108-H1000 CLAMP-FUEL TUBE 1 A12 -370 0 superceded
  • 17108-M0100 CLAMP-FUEL TUBE 1 A12 0470- 2 17108-H1000
  • 22328-H1002 CLAMP-TUBE VC 1 A12 0470-
  • 31139-49006 BOLT 1 A12 -
  • 08915-13810 WASHER-LOCK 1 A12 -
  • 08120-61210 BOLT 2 A12 -
  • 08915-13610 WASHER-LOCK 2 A12 -
  • 17010-H1926 ASSY-PUMP FUEL 1 A12 - 17010-H1900 $50.69
  • 17010-H1900 ASSY-PUMP FUEL 1 A12 - superceded
  • 17065-13210 ASSY-VALVE FUEL PUMP 2 A12 -
  • 17061-50000 GASKET-VALVE FUEL PUMP 2 A12 -
  • 17072-01300 RETAINER-VALVE FUEL PUMP 1 A12 -
  • 17075-13210 SCREW-RETAINER 2 A12 -
  • 17082-18010 CAP-BODY UPPER 1 A12 -
  • 17076-18010 DIAPHRAGM-AIR CHAMBER 1 A12 -
  • 17089-13210 SCREW-CAP & BODY SET 6 A12 -
  • 17090-32200 WASHER-SPRING CAP & BODY SET 6 A12 -
  • 17020-85060 SPRING-ROCKER ARM 1 A12 -
  • 17053-18010 ASSY-DIAPHRAGM 1 A12 - superceded
  • 17053-M0100 ASSY-DIAPHRAGM 1 A12 - 2 17053-18010
  • 17048-18010 SEAL-OIL 1 A12 -
  • 17047-18010 RETAINER-OIL SEAL 1 A12 -
  • 17052-18010 SPRING-DIAPHRAGM 1 A12 -
  • 17010-H1902 ASSY-FUEL PUMP 1 A12 0670- 2 17010-H1900 superceded
  • 17010-H1903 ASSY-FUEL PUMP 1 A12 1071-0873 32 17010-H1902 superceded
  • 17010-H1904 ASSY-FUEL PUMP 1 A12 0973- 2 17010-H1903
  • 17076-13211 GASKET 1 A12 -
  • 17065-13210 VALVE 2 A12 -
  • 17061-50000 GASKET-VALVE 2 A12 -
  • 17103-M0800 CONNECTOR-INLET 1 A12 -
  • 17103-M0801 CONNECTOR-OUTLET 1 A12 -
  • 17013-H2310 COMP-BODY LOWER 1 A12 -
  • 17013-H2315 COMP-BODY LOWER 1 A12 1071- superceded
  • 17013-M2000 COMP-BODY LOWER 1 A12 - 2 17013-H2315
  • 17053-32201 ASSY-DIAPHRAGM 1 A12 -
  • 17048-13910 SEAL-OIL 1 A12 -
  • 17047-13911 RETAINER-OIL SEAL 1 A12 -
  • 17052-37010 SPRING-DIAPHRAGM 1 A12 -
  • 17075-M0100 SCREW 2 A12 1071-
  • 17075-13210 SCREW 2 A12 -
  • 17089-13210 SCREW 1 11 A12 -
  • 17089-M0100 SCREW 1 11 A12 1071-
  • 17090-32200 WASHER-SPRING 1 11 A12 -
  • 08915-13810 WASHER-LOCK M8 2 A12 -
  • 08911-10810 NUT-HEX M8 2 A12 -
  • 00915-41510 WASHER-PLAIN 5/16 2 A12 -
  • 17099-21002 GASKET-FUEL PUMP 2 A12 -
  • 16420-21000 SPACER-FUEL PUMP 1 A12 - superceded
  • 16420-21001 SPACER-FUEL PUMP 1 A12 - 2 16420-21000
  • 08915-13610 WASHER-SPRING M6 2 A12 -
  • 08723-11400 CLAMP-FUEL TUBE 4 A12 -370 0
  • 17201-H1001 ASSY-TANK FUEL 40L 1 SEDAN 0570- 2 17201-H1000 superceded
  • 17201-H1902 ASSY-TANK FUEL 40L 1 SEDAN 1070- 4 17201-H1001 superceded
  • 17201-H2800 ASSY-TANK FUEL 40L 1 SEDAN - 0 17201-H1902 $333.05
  • 17201-H1000 ASSY-TANK FUEL 40L 1 SEDAN - superceded
  • 17342-18000 RING-O 1 SEDAN -
  • 17343-14801 PLATE-LOCK 1 SEDAN - 2 17343-H1001
  • 17343-H1001 PLATE-LOCK 1 SEDAN -
  • 25060-H1000 GAUGE-FUEL TANK 1 SEDAN - superceded
  • 25060-H1900 GAUGE-FUEL TANK 1 SEDAN 1070- 0 25060-H1000 $31.52
  • 17312-14800 PACKING-DRAIN 1 SEDAN - superceded
  • 17312-H1000 PACKING-DRAIN 1 SEDAN - 2 17312-14800 superceded
  • 17312-P0101 PACKING-DRAIN 1 SEDAN -370 2 17312-H1000 superceded
  • 17312-P0102 PACKING-DRAIN 1 SEDAN - 2 17312-P0101
  • 17310-H1000 PLUG-DRAIN 1 SEDAN - 2 08931-44210 superceded
  • 17310-P0100 PLUG-DRAIN 1 SEDAN -370 2 17310-H1000
  • 08931-44210 PLUG 1 SEDAN - superceded
  • 17251-H1000 CAP-FILLER 1 SEDAN - NLA
  • 17264-18000 PACKING 1 SEDAN - $0.66
  • 17220-H1000 ASSY-TUBE FILLER UPPER 1 SEDAN - NLA
  • 17222-H1000 NECK-FILLER 1 SEDAN - $3.43
  • 17221-H1000 PACKING FILLER NECK 1 SEDAN - NLA
  • 08310-40812 SCREW 3 SEDAN -
17229-H1900 HOSE-FILLER 1 SEDAN - 17229-H1000 $29.26
  • 17229-H1000 HOSE-FILLER 1 SEDAN - superceded
  • 08723-15800 CLAMP-HOSE 2 SEDAN -
  • A7325-H1000 TUBE(10X14DX5M) 1 SEDAN -
  • 08723-11400 CLAMP-HOSE 2 SEDAN -
  • 16439-22100 CLAMP-HOSE 2 SEDAN - 2 08723-11400
  • 17335-H1000 TUBE-VINYL 1 SEDAN -
  • 08360-82014 BOLT WITH LOCK WASHER 4 SEDAN -
  • 08915-53810 WASHER-PLAIN 4 SEDAN -
  • 17314-H1000 GROMMET 1 SEDAN -
17201-H1802 ASSY-TANK FUEL 38L 1 COUPE - 17201-H1801 $297.76
  • 17201-H1801 ASSY-TANK FUEL 38L 1 COUPE - superceded
  • 17342-18000 RING-O 1 COUPE -
  • 17343-H1001 PLATE-LOCK 1 COUPE -
  • 17343-14801 PLATE-LOCK 1 COUPE - 2 17343-H1001
  • 25060-H1800 GAUGE-FUEL TANK 1 COUPE -
  • 17312-P0102 PACKING-DRAIN 1 COUPE - 2 17312-P0101
  • 17312-14800 PACKING-DRAIN 1 COUPE -
  • 17312-H1000 PACKING-DRAIN 1 COUPE - 2 17312-14800
  • 17312-P0101 PACKING-DRAIN 1 COUPE - 2 17312-H1000
  • 17310-P0100 PLUG-DRAIN 1 COUPE - 2 17310-H1000
  • 08931-44210 PLUG-DRAIN 1 COUPE -
  • 17310-H1000 PLUG-DRAIN 1 COUPE - 2 08931-44210
  • 17251-H1900 CAP-FILLER 1 COUPE -
  • 17251-H1000 CAP-FILLER 1 COUPE - 2 17251-H1900
  • 17264-18000 PACKING 1 COUPE -
  • 17220-H1801 TUBE-FILLER 1 COUPE -
  • 17222-H1000 NECK-FILLER 1 COUPE -
  • 17221-H1000 PACKING FILLER NECK 1 COUPE -
  • 08310-40812 SCREW-MACHIN 3 COUPE -
  • 17229-H1801 HOSE-FILLER 1 COUPE - $34.35
  • 17228-H1400 GROMMET 1 COUPE -
  • 08723-15800 CLAMP-HOSE 2 COUPE -
  • A7325-H1000 TUBE(10X14DX5M) 1 COUPE -
  • 08723-11400 CLAMP-HOSE 2 COUPE - superceded
  • 16439-22100 CLAMP-HOSE 2 COUPE - 2 08723-11400
  • 17335-H1800 TUBE 1 COUPE -
  • 17324-H1400 GROMMET 1 COUPE -
  • 17334-H1801 CLIP 1 COUPE - 2 17310-H1000
  • 08510-51012 SCREW 1 COUPE -
  • 77700-89915 PLUG-RUBBER 30 1 COUPE -
  • 08110-82062 BOLT-WITH LOCK WASHER 5 COUPE -
  • 08915-53810 WASHER-PLAIN 5 COUPE -
  • 74890-H1800 PROTECTOR-FILLER HOSE 1 COUPE -
  • 08110-62010 BOLT FIXING PROTECTOR 3 COUPE -
  • 08915-23610 WASHER FIXING PROTECTOR 3 COUPE -
  • 08915-43610 WASHER FIXING PROTECTOR 3 COUPE -
  • 08742-20020 HOSE-FUEL STRAINER TO TUBE (6X13.5X2200 1 SEDAN COUPE -
  • 08742-20020 HOSE-FUEL STRAINER TO TUBE (6X13.5X2.2M 1 SEDAN COUPE - 2 A7515-H1800
  • A7515-H1800 HOSE-FUEL STRAINER TO TUBE (6X13.5X5M) 1 SEDAN COUPE -
  • 08723-11400 CLAMP-HOSE 2 -
  • 16439-22100 CLAMP-HOSE 2 - 2 08723-11400
  • 17501-H1801 TUBE-FUEL 1 COUPE MANUAL -
  • 17501-H1001 TUBE (L=378) 1 SEDAN MANUAL -
  • 17501-H1002 TUBE-FUEL (L=353) 1 SEDAN MANUAL - 4 17501-H1001
  • 17501-H1100 TUBE-FUEL 1 SEDAN MANUAL - 4 17501-H1002
  • 17501-H3500 TUBE-FUEL 1 SEDAN MANUAL 1271- 0 17501-H1100
  • 17501-H3510 TUBE-FUEL 1 SEDAN AUTOMATIC 1271- 0 17501-H1120
  • 17501-H3900 TUBE-FUEL 1 COUPE MANUAL 1271-
  • 17501-H1720 TUBE-FUEL 1 COUPE AUTOMATIC - 4 17501-18120
  • 17501-H3910 TUBE-FUEL 1 COUPE AUTOMATIC 1271- 0 17501-H1720
  • 17501-H1120 TUBE-FUEL 1 SEDAN AUTOMATIC -
  • 24252-36700 GROMMET 1 SEDAN -
  • 24250-89968 GROMMET 1 SEDAN EVAPO -
  • A7515-H1800 HOSE-FUEL(6X13.5X5M) 1 SEDAN COUPE -
  • 08742-20020 HOSE-FUEL (6X13.5X2.2M) 1 SEDAN COUPE - 2 A7515-H1800
  • 16439-22100 CLAMP-HOSE 2 SEDAN & COUPE - 2 08723-11400
  • 08723-11400 CLAMP-HOSE 2 SEDAN & COUPE -
  • 18010-H1902 COMP-ARM ACCELERATOR PEDAL 1 AUTOMATIC - NLA
  • 18010-H1602 COMP-ARM ACCELERATOR PEDAL 1 MANUAL - NLA
  • 18100-H1602 ASSY-ARM ACCELERATOR PEDAL 1 MANUAL - NLA
  • 18100-H1902 ASSY-ARM ACCELERATOR PEDAL 1 AUTOMATIC - NLA
  • 18017-H1600 PAD-ACCELERATOR PEDAL 1 - NLA
  • 18021-H1600 BRACKET-ACCELERATOR PEDAL 1 -
  • 18215-H1600 SPRING-RETURN ACCELERATOR 1 -
  • 18215-H1601 SPRING-RETURN ACCELERATOR 1 1070- 2 18215-H1600
  • 18137-10600 RING-SNAP E TYPE 1 -
  • 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX 3 -
  • 18056-H1600 BOLT-PEDAL STOPPER 1 -
  • 08911-30610 NUT-HEX M6 FOR PEDAL STOPPER 1 -
  • 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER 1 -
  • 18036-18000 SPRING-CLAMP ACCELERATOR WIRE 1 -
A8200-G1300 ASSY-WIRE ACCELERATOR 1 18200-H1600 $7.15
  • 18200-H1600 ASSY-WIRE ACCELERATOR 1 - superceded
  • 18410-H1601 COMP-WIRE CHOKE CONTROL 1 - superceded
  • 18410-H1602 COMP-WIRE CHOKE CONTROL 1 - 2 18410-H1601 $13.38
  • 18415-H1000 ASSY-KNOB CHOKE CONTROL 1 - superceded
  • 18415-H1001 ASSY-KNOB CHOKE CONTROL 1 SEDAN & COUPE 0171- 2 18415-H1000 $4.72
  • 00951-10400 GROMMET 1 -
  • 21010-18026 ASSY-PUMP WATER WITH GASKET 1 A12 - 2 21010-18003 superceded
  • 21010-18027 ASSY-PUMP WATER WITH GASKET 1 A12 0870-0871 12 21010-18026 superceded
  • 21010-H1025 ASSY-PUMP WATER WITH GASKET 1 A12 0971-1072 22 21010-18027 superceded
  • 21010-H5025 ASSY-PUMP WATER WITH GASKET 1 A12 1172- 2 21010-H1025 superceded
  • BA010-M6626 ASSY-PUMP WATER WITH GASKET 1 A12 1172- 2 21010-H5025 $42.71
  • 21010-18003 ASSY-PUMP WATER 1 A12 - superceded
  • 21022-18003 VANE-WATER PUMP 1 A12 -
  • 21026-73000 ASSY-SEAL WATER PUMP 1 A12 -
  • 21027-73000 ASSY-SEAT 1 A12 -
  • 21035-13202 BEARING-WATER PUMP 1 A12 -
  • 21054-18000 HUB-WATER PUMP 1 A12 -
  • 21014-18000 GASKET-WATER PUMP COVER 1 A12 -
  • 08911-10810 NUT-HEX M8 FIXING WATER PUMP 3 A12 -
  • 08110-84810 BOLT-HEX M8 FIXING WATER PUMP 2 A12 -
  • 08110-85010 BOLT-HEX M8 FIXING WATER PUMP 2 A12 1172- 2 08110-84810
  • 08915-13810 WASHER-LOCK FIXING WATER PUMP 5 A12 -
  • 21051-18000 PULLEY-FAN & WATER PUMP 1 A12 -
  • 21060-H1001 FAN-COOLING 1 A12 - $24.86
  • 21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA 1 OP A12 CRANK - superceded
  • 21060-N0100 FAN-COOLING,FOR TROPICAL USE 1 OP.A12 - 2 21060-A4605 $24.86
  • 08120-62010 BOLT-HEX FIXING FAN 4 A12 -
  • 21069-21000 WASHER-COCK FIXING FAN 2 A12 -
11720-G0300 BELT-FAN L=838 1 A12 - 11720-18002 $8.88
  • 11720-18002 BELT-FAN L=838 1 A12 - superceded
  • 21400-H1900 ASSY-RADIATOR 1 - 2 21400-H1002 NLA
  • 21400-H1003 ASSY-RADIATOR 1 A12 0871- 2 21400-H1900 NLA
  • 21400-H1002 ASSY-RADIATOR 1 - NLA
  • 21430-10600 ASSY-CAP 1 - superceded
21430-89902 ASSY-CAP PADIATOR 1 A12 1272- 21430-U0100 $10.83
  • 21430-U0100 ASSY-CAP PADIATOR 1 A12 1272- 2 21430-10600 superceded
  • 21480-18000 HANDLE-DRAIN COCK 1 -
  • 21481-18000 PACKING-DRAIN COCK 1 -
  • 08110-61662 BOLT-HEX,WITH WASHER 4 -
  • 21501-H1000 HOSE-RADIATOR,UPPER 1 - $4.28
  • 21503-H1000 HOSE-RADIATOR,LOWER 1 - superceded
  • 21506-H1101 ASSY-HOSE,RADIATOR,LOWER,FORHEATER 1 OP. 0970- 21503-H1000,21503-H1100,21504-H1100 $10.74
  • 21503-H1100 HOSE-RADIATOR,LOWER,FRONT FOR HEATER 1 OP. -870 0 superceded
  • 21504-H1100 HOSE-RADIATOR,LOWER,REAR FORHEATER 1 OP -870 0 superceded
  • 08723-13600 CLAMP-HOSE 4 -
27075-H1000 CONNECTOR-HEATER 1 OP. - 27075-27700 $7.48
  • 27075-27700 CONNECTOR-HEATER 1 OP. - superceded
  • 21475-H2300 SHROUD-RADIATOR UPPER 1 AUTOMATIC - $18.71
  • 21475-H2300 SHROUD-RADIATOR,UPPER FOR HEAVY DUTY S 1 OP. - $18.71
  • 21476-H2300 SHROUD-RADIATOR,LOWER 1 AUTOMATIC - $20.40
  • 21476-H2300 SHROUD-RADIATOR,FOR HEAVY DUTY SPEC 1 OP. - $20.40
  • 08513-51612 SCREW-TAPPING M5 6 -
  • 08915-43510 WASHER-PLAIN 6 -
  • 08963-10510 NUT-SPRING M5 4 -
  • 11223-H1000 INSULATOR-ENGINE MOUNTING FRONT 2 A12 - $9.53
  • 11221-H1000 BRACKET-ENGINE MOUNTING FRONT RH 1 A12 -
  • 11222-H1001 BRACKET-ENGINE MOUNTING FRONT LH 1 A12 -
  • 08915-53810 WASHER-PLAIN FIXING INSULATOR TO 8 A12 -
  • 08915-23810 WASHER-LOCK FIXING INSULATOR TO BRACKET 8 A12 -
  • 08911-20810 NUT-HEX FIXING INSULATOR TO BRACKET 8 A12 -
  • 11321-H1000 ASSY-INSULATOR ENGINE MOUNTING REA 1 A12 MANUAL - $26.39
  • 11321-H1020 ASSY-INSULATOR ENGINE MOUNTING REA 1 A12 AUTOMATIC - $40.64
  • 11322-H1002 MEMBER-ENGINE MOUNTING REAR 1 A12 MANUAL - NLA
  • 11322-H1020 MEMBER-ENGINE MOUNTING REAR 1 A12 AUTOMATIC - NLA
  • 08110-61410 BOLT-HEX M6 FIXING INSULATOR TO MEMBER 4 A12 -
  • 08915-13610 WASHER-SPRING LOCK M6 INSULATOR TO 4 A12 -
  • 08154-02510 BOLT-HEX MEMBER TO BODY FIX 2 A12 -
  • 08915-14010 WASHER-SPRING LOCK TO BODY FIX 2 A12 -
  • 08915-44010 WASHER-PLAIN M10 TO BODY FIX 2 A12 -
  • 11335-18000 BOLT-ENGINE MOUNTING REAR INSULATOR TO 2 A12 MANUAL -
  • 11335-20300 BOLT-ENGINE MOUNTING REAR INSULATOR TO 2 A12 AUTOMATIC -
  • 08915-14010 WASHER-SPRING LOCK M10 2 A12 -
  • 08911-14010 NUT-HEX M10 2 A12 -
  • 62611-H1000 COVER-UNDER,FRONT 1 A12 - NLA
  • 08915-43610 WASHER-PLAIN 4 A12 -
  • 08915-13610 WASHER-LOCK 4 A12 -
  • 08110-62010 BOLT 4 A12 -
  • 16010-H1901 ASSY-CARBURETOR 1 A12 EXHAUST & EVAPO - 2 16010-H1900 superceded
  • 16010-H1902 ASSY-CARBURETOR HITACHI DCG306-3A 1 A12 EXHAUST & EVAPO 1070- 2 16010-H1901, 16010-H1602 $243.83
  • 16010-H1900 ASSY-CARBURETOR 1 A12 EXHAUST & EVAPO -
  • 16118-H1910 ASSY-CHAMBER FLOAT 1 A12 EXHAUST & EVAPO -
  • 16145-91460 SPRING-IDLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16145-50000 SPRING-THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16129-14811 SCREW-THROTTLE ADJUST 1 A12 EXHAUST & EVAPO - 2 16129-25715
  • 16129-25715 SCREW-THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO - superceded
  • 16455-H6200 SET-GASKET 1 A12 EXHAUST & EVAPO - 2 16455-H1000
  • 16144-B0815 SCREW-IDLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16082-18010 PLATE-ADJUST THROTTLE 1 A12 EXHAUST & EVAPO -
  • 16133-H1000 LEVER-STARTING 1 A12 EXHAUST & EVAPO -
  • 16116-18010 SLEEVE 1 A12 EXHAUST & EVAPO -
  • 16134-H1910 LEVER-THROTTLE 1 A12 EXHAUST & EVAPO -
  • 16236-H1910 LEVER (A) 1 A12 EXHAUST & EVAPO -
  • 16116-H1910 SLEEVE (A) 1 A12 EXHAUST & EVAPO -
  • 16249-H1910 LEVER 1 A12 EXHAUST & EVAPO -
  • 16034-19915 JET-MAIN #98 1 A12 EXHAUST & EVAPO -
  • 16135-33815 JET-MAIN #135 1 A12 EXHAUST & EVAPO -
  • 16272-36710 PLUG-DRAIN 2 A12 EXHAUST & EVAPO -
  • 16059-14810 VALVE-POWER #60 1 A12 EXHAUST & EVAPO -
  • 16148-H1000 SPRING-PISTON RETURN 1 A12 EXHAUST & EVAPO -
  • 16151-H1000 PISTON 1 A12 EXHAUST & EVAPO -
  • 16025-H1000 TUBE-EMULSION P 1 A12 EXHAUST & EVAPO - superceded
  • 16026-25710 TUBE-EMULSION S 1 A12 EXHAUST & EVAPO -
  • 16026-B0810 TUBE-EMULSION S 1 A12 EXHAUST & EVAPO - 2 16026-25710
  • 16050-18010 BLEED-MAIN AIR #80 2 A12 EXHAUST & EVAPO -
  • 16171-25710 WEIGHT-INJECTOR 1 A12 EXHAUST & EVAPO -
  • 16055-14811 JET-SLOW #43 1 A12 EXHAUST & EVAPO -
  • 16054-B0810 JET-SLOW #50 1 A12 EXHAUST & EVAPO -
  • 16011-H1600 ASSY-CHOKE CHAMBER 1 A12 EXHAUST & EVAPO - superceded
  • 16011-H1601 ASSY-CHOKE CHAMBER 1 A12 EXHAUST & EVAPO - 2 16011-H1600
  • 16204-08000 BLEED-SLOW AIR #100 1 A12 EXHAUST & EVAPO -
  • 16213-08000 BLEED-SLOW AIR #220 1 A12 EXHAUST & EVAPO -
  • 16052-85060 BLEED-SLOW AIR #200 1 A12 EXHAUST & EVAPO - 1 16213-08000
  • 16098-25710 FILTER 1 A12 EXHAUST & EVAPO -
  • 16101-H1000 VALVE-NEEDLE 1 A12 EXHAUST & EVAPO -
  • 16066-18010 SHAFT-FLOAT 1 A12 EXHAUST & EVAPO -
  • 16061-18010 FLOAT 1 A12 EXHAUST & EVAPO -
  • 16307-04000 COVER-PUMP 1 A12 EXHAUST & EVAPO -
  • 16302-H1910 LEVER-PUMP 1 A12 EXHAUST & EVAPO -
  • 16305-19915 SHAFT-PUMP LEVER 1 A12 EXHAUST & EVAPO -
  • 16452-H1000 SPRING-PUMP LEVER 1 A12 EXHAUST & EVAPO -
  • 16453-H1000 WASHER (T=2MM) 1 A12 EXHAUST & EVAPO -
  • 16155-H1910 ARM-THROTTLE 1 A12 EXHAUST & EVAPO -
  • 16161-H1911 HANGER-SPRING 1 A12 EXHAUST & EVAPO 1170- 2 16161-H1910
  • 16161-H1910 HANGER-SPRING 1 A12 EXHAUST & EVAPO - superceded
  • 16165-H1600 ARM-CHOKE WIRE 1 A12 EXHAUST & EVAPO -
  • 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H 1 A12 EXHAUST & EVAPO 1070- 2 16160-H1000
  • 16160-H1000 SPRING-THROTTLE RETURN 1 A12 EXHAUST & EVAPO - superceded
  • 16248-H1000 ROD-CHOKE CONNECTOR 1 A12 EXHAUST & EVAPO -
  • 16143-H1910 ROD-PUMP 1 A12 EXHAUST & EVAPO -
  • 16141-18010 ROD-CONNECTOR 1 A12 EXHAUST & EVAPO -
  • 16262-H1910 DIAPHRAGM-SURVO 1 A12 EXHAUST & EVAPO -
  • 16455-H1000 SET-GASKET 1 A12 EXHAUST & EVAPO - superceded
  • 16475-H1910 SCREW & WASHER SET B 1 A12 EXHAUST & EVAPO -
  • 16465-H1000 SCREW & WASHER SET A 1 A12 EXHAUST & EVAPO -
  • 16009-H1910 KIT-REPAIR A CARBURETOR 1 A12 EXHAUST & EVAPO - superceded
  • 16009-H7000 KIT-REPAIR A CARBURETOR 1 A12 EXHAUST & EVAPO - 2 16009-H1910 superceded
  • 16009-H6200 KIT-REPAIR A CARBURETOR 1 A12 EXHAUST & EVAPO - 2 16009-H7000
  • 16307-04000 PUMP-COVER 1 A12 EXHAUST & EVAPO -
  • 16009-H1911 KIT-REPAIR B CARBURETOR 1 A12 EXHAUST & EVAPO -
  • 16129-25715 THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO - superceded
  • 16129-14811 THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO - 2 16129-25715
  • 16144-B0815 IDLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16101-H1000 NEEDLE VALVE 1 A12 EXHAUST & EVAPO -
  • 16066-18010 FLOAT SHAFT 1 A12 EXHAUST & EVAPO -
  • 16453-H1000 WASHER 1 A12 EXHAUST & EVAPO -
  • 16010-H3901 ASSY-CARBURETOR (DCH306-1A) 1 A12,MANUAL - 2 16010-H3900
  • 16010-H3902 ASSY-CARBURETOR (DCH306-1B) 1 A12,MANUAL -672 22 16010-H3901
  • 16010-H7000 ASSY-CARBURETOR (DCH306-4) 1 A12,MANUAL 0772- 0 16010-H3902
  • 16010-H3920 ASSY-CARBURETOR (DCH306-3) 1 A12,AUTO -
  • 16010-H3921 ASSY-CARBURETOR (DCH306-3A) 1 A12,AUTO - 2 16010-H3920
  • 16010-H3922 ASSY-CARBURETOR (DCH306-3B) 1 A12,AUTO -672 22 16010-H3921
  • 16010-H7100 ASSY-CARBURETOR (DCH306-5) 1 A12,AUTO 0772- 0 16010-H3900
  • 16010-H3900 ASSY-CARBURETOR (DCH306-1) 1 A12,MANUAL -
  • 16011-H7011 ASSY-CHAMBER,CHOKE 1 A12,MANUAL 0772- 0 16011-H3910
  • 16011-H3920 ASSY-CHAMBER,CHOKE 1 A12,AUTO -672 2
  • 16011-H3910 ASSY-CHAMBER,CHOKE 1 A12,MANUAL -672 2
  • 16011-H7111 ASSY-CHAMBER,CHOKE 1 A12,AUTO 0772- 0 16011-H3920
  • 16182-H3920 POT-DASH 1 A12,AUTO -
  • 16302-H3910 LEVER-PUMP 1 A12 -
  • 16258-H3920 HOLDER-DASH POT 1 A12,AUTO -
  • 16143-H3910 ROD-PUMP 1 A12 -
  • 16262-H3910 DIAPHRAGM-SERVO 1 A12 -
  • 16118-H3910 ASSY-CHAMBER,THROTTLE 1 A12 -
  • 16118-H3911 ASSY-CHAMBER,THROTTLE 1 A12 -672 22 16118-H3910
  • 16118-H7011 ASSY-CHAMBER,THROTTLE 1 A12 0772- 0 16118-H3911
  • 16145-91460 SPRING-IDLE ADJUST SCREW 1 A12 -
  • 16145-50000 SPRING-THROTTLE ADJUST SCREW 1 A12 -
  • 16129-25710 SCREW-THROTTLE ADJUST 1 A12 -
  • 16129-25715 SCREW-THROTTLE ADJUST 1 A12 -672 22 16129-25710
  • 16114-H7010 SCREW-THROTTLE ADJUST 1 A12 0772- 0 16129-25715
  • 16144-M0110 SCREW-IDLE ADJUST 1 A12 -672 2
  • 16144-H7010 SCREW-IDLE ADJUST 1 A12 0772- 0 16144-M0110
  • 16147-E6600 CAP-IDLE LIMITTEY 1 A12 1070-0672 2
  • 16082-H3910 PLATE-ADJUST 1 A12 -672 2
  • 16082-H7010 PLATE-ADJUST 1 A12 0772- 0 16082-H3910
  • 16116-H3910 SLEEVE(B) 1 A12 -
  • 16128-H3910 LEVER-FIRST IDLE 1 A12 -
  • 16249-H3910 LEVER-OPENER 1 A12 -
  • 16389-H7010 COVER-THERMO 1 A12 0772- 0 16389-H3910 $40.45
  • 16389-H3910 COVER-THERMO 1 A12 -672 2
  • 16267-H3910 PIPE-VACUUM 1 A12,MANUAL -
  • 16267-H3920 PIPE-VACUUM 1 A12,AUTO -
  • 16161-H1911 HANGER-SPRING 1 A12,MANUAL -672 2
  • 16161-H7010 HANGER-SPRING 1 A12,MANUAL 0772- 0 16161-H1911
  • 16134-H1910 LEVER-THROTTLE 1 A12,MANUAL -
  • 16134-H3920 LEVER-THROTTLE 1 A12,AUTO -
  • 16116-H1910 SLEEVE(A) 1 A12 -
  • 16236-H1910 LEVER 1 A12 -
  • 16452-H1000 SPRING-PUMP LEVER 1 A12 -
  • 16453-H1000 WASHER 1 A12 -
  • 16025-H1000 TUBE-EMULSION(P) 1 A12 -
  • 16160-H1910 SPRING-THROTTLE RETURN 1 A12 -
  • 16171-25710 WEIGHT-INJECTOR 1 A12 -672 2
  • 16171-H7010 WEIGHT-INJECTOR 1 A12 0772- 0 16171-25710
  • 16061-18010 FLOAT 1 A12 -
  • 16026-B0810 TUBE-EMULSION(S) 1 A12 -
  • 16151-H1000 PISTON-POWER 1 A12 1070-
  • 16148-H1000 SPRING-PISTON RETURN 1 A12 -
  • 16141-18010 ROD-CONNECTING 1 A12 -
  • 16305-19915 SHAFT-PUMP LEVER 1 A12 -
  • 16307-04000 COVER-PUMP 1 A12 -
  • 16272-36710 PLUG-DRAIN 2 A12 -
  • 16066-18010 SHAFT-FLOAT 1 A12 -
  • 16101-H1000 VALVE-NEEDLE 1 A12 -
  • 16098-25710 FILTER 1 A12 -
  • 16029-18010 WASHER 1 A12 -
  • 16065-H1010 SCREW 1 A12 -
  • 16033-L0101 JET-MAIN #97 1 A12 -672 2
  • 16033-H7010 JET-MAIN #95 1 A12 0772- 0 16033-L0101
  • 16043-25715 JET-MAIN #140 1 A12 -
  • 16055-14811 JET-SLOW #43 1 A12 -
  • 16054-B0810 JET-SLOW #50 1 A12 -
  • 16050-18010 BLEED-SLOW AIR #80 2 A12 -
  • 16204-08000 BLEED-SLOW AIR #100 1 A12 -
  • 16051-H3910 BLEED-SLOW AIR #215 1 A12 -
  • 16059-H3910 VALVE-POWER #50 1 A12 -671 1
  • 16059-H3911 VALVE-POWER #45 1 A12 0771-0672 22 16059-H3910
  • 16059-14810 VALVE-POWER #60 1 A12 0772- 2 16059-H3911
  • 16196-H7010 ASSY-CUT,FUEL 1 A12 0772-1072 2
  • 16196-H7011 VALVE-ANTI DIESELING SOLENOID 1 A12 1172- 0 16196-H7010
  • 16455-H1000 KIT-GASKET 1 A12 -672 2
  • 16455-H6200 KIT-GASKET 1 A12 - 2 16455-H1001
  • 16455-H6200 KIT-GASKET 1 A12 - 2 16455-H1000
  • 16455-H1001 KIT-GASKET 1 A12 0772- 2 16455-H1000
  • 16475-H3910 KIT-SCREW & WASHER(B) 1 A12 -1072 2
  • 16475-H7010 KIT-SCREW & WASHER (B) 1 A12 1172- 0 16475-H3910
  • 16465-H3910 KIT-SCREW & WASHER(A) 1 A12 -
  • 16009-H1910 KIT-REPAIR A, CARBURETOR 1 A12 -672 2
  • 16009-H7000 KIT-REPAIR A,CARBURETOR 1 A12 0772- 2 16009-H1910
  • 16009-H6200 KIT-REPAIR A CARBURETOR 1 A12 - 2 16009-H7000
  • 16009-H7010 KIT-REPAIR B,CARBURETOR 1 A12 0772- 2 16009-H3910
  • 16009-H3910 KIT-REPAIR B, CARBURETOR 1 A12 -672 2
  • 16500-H3901 ASSY-CLEANER,AIR 1 A12 0771- 5 16500-H3900 superceded
  • 16500-H7000 ASSY-CLEANER,AIR 1 A12 0772- 0 16500-H3901 $185.26
  • 16500-H3900 ASSY-CLEANER,AIR 1 A12 0671-0771 1 superceded
  • 01237-00011 NUT-WING 1 A12 0671- superceded
  • 16510-H3900 ASSY-MOTOR,VACUUM 1 A12 0671- $42.05
16580-01B01 ASSY-SENSOR,TEMPERATURE 1 A12 16580-H3900 $44.69
  • 16580-H3900 ASSY-SENSOR,TEMPERATURE 1 A12 0671- superceded
  • 16582-H3900 CLAMP-SENSOR & TUBE 1 A12 0671-
  • 22318-C0601 TUBE-VACUUM MOTOR TO TUBE L=200 1 A12 0671-
  • 22318-C0601 TUBE-VACUUM CONTROL L=320 1 A12 0671-
  • 16573-H1001 SUPPORT-AIR CLEANER 1 A12 0671-
  • 16574-H1001 SUPPORT-AIR CLEANER,FRONT 1 A12 0671-
  • 08120-61210 BOLT 5 A12 0671-
  • 08915-13610 WASHER-LOCK 5 A12 0671-
  • 08915-43610 WASHER-PLAIN 2 A12 0671-
  • 08915-53610 WASHER-PLAIN 1 A12 0671-
  • 16530-B3901 DUCT-COVER TO AIR CLEANER 1 A12 0671-
  • 08723-14400 CLAMP-DUCT 2 A12 0671-
  • 16590-H3900 ASSY-COVER,EXHAUST MANIFOLD 1 A12 0671-
  • 08190-81210 BOLT 3 A12 0671-
  • 08915-43810 WASHER-PLAIN 3 A12 0671-
  • 08915-13810 WASHER-LOCK 3 A12 0671-
  • 14896-25600 BAND-HOSE 1 A12 0671-
  • 14875-H1900 CONNECTOR-VACUUM 1 A12 0671-
  • 17201-H1902 ASSY-TANK FUEL 40L 1 SEDAN EVAPO 0570- 2 17201-H1901 superceded
  • 17201-H2800 ASSY-TANK FUEL 40L 1 SEDAN EVAPO 1070- 2 17201-H1902 $250.69
  • 17201-H1901 ASSY-TANK FUEL 40L 1 SEDAN EVAPO - superceded
  • 25060-H1900 GAUGE-FUEL TANK 1 SEDAN EVAPO -
  • 17312-P0101 PACKING-DRAIN 1 SEDAN 1070- 2 17312-H1000
  • 17312-P0102 PACKING-DRAIN 1 SEDAN 1070- 2 17312-P0101
  • 17310-P0100 PLUG-DRAIN 1 SEDAN 1070- 2 17310-H1000
  • 17251-H1900 CAP-FILLER 1 SEDAN - superceded
  • 17251-H1000 CAP-FILLER 1 SEDAN EVAPO 0570- 2 17251-H1900 superceded
  • 17251-H1900 CAP-FILLER 1 SEDAN EVAPO 0672- 2 17251-H1000 superceded
  • 17251-H1901 CAP-FILLER 1 SEDAN EVAPO 0672- 2 17251-H1900 superceded
  • 17251-H1902 CAP-FILLER 1 SEDAN EVAPO 0173- 2 17251-H1901 $22.62
  • 17220-H1901 TUBE-FILLER UPPER 1 SEDAN EVAPO -
  • 08310-40812 SCREW 3 SEDAN EVAPO -
  • 17229-H1900 HOSE-FILLER 1 SEDAN EVAPO - $29.26
  • 08723-15800 CLAMP-HOSE 2 SEDAN EVAPO -
  • 17350-H1900 ASSY-TANK RESERVOIR 1 SEDAN EVAPO -
  • 17351-H1900 CONNECTOR-3 WAY 1 SEDAN EVAPO -
  • 17351-H1901 CONNECTOR-3 WAY 1 SEDAN EVAPO - 2 17351-H1900
  • 17352-H1901 SEPARATOR 1 SEDAN EVAPO -
  • 17352-H1902 SEPARATOR 1 SEDAN EVAPO 0570- 2 17352-H1901
  • A8742-20040 HOSE-FUEL RUBBER (10X17X2.2M) 1 SEDAN EVAPO - 2 08742-20040
  • 08742-20040 HOSE-FUEL RUBBER (10X17X2.2M) 1 SEDAN EVAPO - 2 A7515-H1900
  • A7515-H1900 HOSE-FUEL RUBBER(10X16DX5M) 1 SEDAN EVAPO -
  • A7515-H1800 HOSE-FUEL RUBBER(6X13.5X5M) 1 SEDAN EVAPO -
  • 08742-20020 HOSE-FUEL RUBBER (6X13.5X2.2M 1 SEDAN EVAPO - 2 A7515-H1800
  • 08723-11400 CLAMP-HOSE 1 14 SEDAN EVAPO -
  • 16439-22100 CLAMP-HOSE 1 14 SEDAN EVAPO - 2 08723-11400
  • 17230-H1900 HOSE-FILLER 2ND 1 SEDAN EVAPO - superceded
  • 17230-H1901 HOSE-FILLER INNER 1 SEDAN EVAPO - 2 17230-H1900 $8.50
  • 08723-13600 CLAMP-HOSE 1 SEDAN EVAPO -
  • 08723-11400 CLAMP-HOSE 2 SEDAN EVAPO -
  • 16439-22100 CLAMP-HOSE 2 SEDAN EVAPO - 2 08723-11400
  • 17361-H1922 TUBE-EVAPO 1 SEDAN EVAPO AUTOMATIC -
  • 17361-H1902 TUBE-EVAPO 1 SEDAN EVAPO MANUAL -
  • 17361-H1903 TUBE-EVAPO 1 SEDAN EVAPO MANUAL - 0 17361-H1902
  • 17201-H1802 ASSY-TANK FUEL 38L 1 COUPE EVAPO -
  • 17342-18000 RING-"O" 1 COUPE -
  • 17251-H1902 CAP-FILLER 1 COUPE EVAPO 0173- 2 17251-H1901
  • 17251-H1000 CAP-FILLER 1 COUPE EVAPO 0470- 6 17251-H1900
  • 17251-H1901 CAP-FILLER 1 COUPE EVAPO 0672- 2 17251-H1000
  • 17220-H1802 HOSE-FILLER UPPER 1 COUPE EVAPO -
  • 17220-H1803 HOSE-FILLER UPPER 1 COUPE EVAPO 0470- 0 17220-H1802
  • 17229-H1802 HOSE-FILLER 1 COUPE EVAPO -
  • 17230-H1802 HOSE-FILLER INNER 1 COUPE EVAPO - 2 17230-H1801
  • 17230-H1801 HOSE-FILLER 2ND(NOT ADOPTED) 1 COUPE EVAPO -
  • 08723-13600 CLAMP-HOSE 1 COUPE EVAPO -
  • A7325-H1000 TUBE-VINYLE(10X14DX5M) 1 COUPE -
  • A7515-H1900 TUBE-RUBBER(10X16DX5M) 1 COUPE EVAPO -
  • 08742-20040 TUBE-RUBBER 1 COUPE EVAPO - 2 A7515-H1900
  • 17324-H1800 GROMMET 1 COUPE EVAPO -
  • 08110-82062 BOLT WITH LOCK WASHER 5 COUPE -
  • 17350-H1801 ASSY-TANK RESERVOIR 1 COUPE EVAPO -
  • 17350-H1802 ASSY-TANK RESERVOIR 1 COUPE EVAPO 0470- 0 17350-H1801
  • 63140-78500 NUT-JAM 3 COUPE EVAPO -
  • 08410-61610 SCREW 3 COUPE EVAPO -
  • 08915-13610 WASHER-LOCK 3 COUPE EVAPO -
  • 17335-H1801 TUBE-BREATHER RH 1 COUPE EVAPO -
  • 17335-H1802 CONNECTOR 2 COUPE EVAPO 0470- 0 17335-H1801
  • 17336-H1801 TUBE-BREATHER LH 1 COUPE EVAPO -
  • 17515-H1817 HOSE-FUEL FIX FUEL TANK TO EVAPO TANK(L 1 COUPE EVAPO - 2 17230-H1801
  • A7515-H1800 HOSE-FUEL(6X13.5X5M) 1 COUPE EVAPO -
  • 08742-20020 HOSE-FUEL(6X13.5X2200MM) 1 COUPE EVAPO -
  • A7515-H1800 HOSE-FUEL(6X13.5X10M) 1 COUPE EVAPO 0470-
  • 08742-20020 HOSE-FUEL(6X13.5X2200MM) 1 COUPE EVAPO - 2 17230-H1801
  • 08742-20020 HOSE-FUEL (6X13.5X2.2M) 1 COUPE EVAPO - 2 A7515-20020
  • 16439-22100 CLAMP-HOSE 1 16 COUPE EVAPO - 2 68723-11400
  • 08723-11400 CLAMP-HOSE 1 16 COUPE EVAPO -
  • 17351-H1800 CONNECTOR-3 WAY 1 COUPE EVAPO 0470-
  • 17351-H1801 CONNECTOR-3WAY 1 COUPE EVAPO - 2 17351-H1801
  • 17361-H1800 TUBE-EVAPORATION 1 COUPE EVAPO MANUAL -
  • 17361-H1801 TUBE-EVAPORATION 1 COUPE EVAPO MANUAL - 0 17361-H1800
  • 24251-H1801 GROMMET 1 COUPE EVAPO -
  • 00951-10600 GROMMET 2 COUPE EVAPO -
  • 00951-11000 GROMMET 4 COUPE EVAPO -
  • 00951-11200 GROMMET 2 COUPE EVAPO 0470-
  • 46115-C0400 GROMMET 2 COUPE EVAPO 0470-
  • 17337-H1800 PROTECTOR-FUEL HOSE 1 COUPE EVAPO 0470-
  • 24210-89964 CLIP 1 COUPE EVAPO 0470-
  • 74890-H1800 PROTECTOR-FILLER HOSE 1 COUPE EVAPO -
  • 08110-62010 BOLT FIXING PROTECTOR 3 COUPE EVAPO -
  • 08915-23610 WASHER FIXING PROTECTOR 3 COUPE EVAPO -
  • 08915-43610 WASHER FIXING PROTECTOR 3 COUPE EVAPO -
