16009-H7010 KIT-REPAIR B,CARBURETOR 16009-H3910 KIT-REPAIR B, CARBURETOR 16500-H3901 ASSY-CLEANER,AIR 16500-H7000 ASSY-CLEANER,AIR 16500-H3900 ASSY-CLEANER,AIR 01237-00011 NUT-WING 16551-08000 NUT-WING 16510-H3900 ASSY-MOTOR,VACUUM 16580-01B01 ASSY-SENSOR,TEMPERATURE 16580-H3900 ASSY-SENSOR,TEMPERATURE 16582-H3900 CLAMP-SENSOR & TUBE 22318-C0601 TUBE-VACUUM MOTOR TO TUBE L=200 22318-C0601 TUBE-VACUUM CONTROL L=320 16573-H1001 SUPPORT-AIR CLEANER 16574-H1001 SUPPORT-AIR CLEANER,FRONT 08120-61210 BOLT 08915-13610 WASHER-LOCK 08915-43610 WASHER-PLAIN 08915-53610 WASHER-PLAIN 16530-B3901 DUCT-COVER TO AIR CLEANER 08723-14400 CLAMP-DUCT 16590-H3900 ASSY-COVER,EXHAUST MANIFOLD 08190-81210 BOLT 08915-43810 WASHER-PLAIN 08915-13810 WASHER-LOCK 14896-25600 BAND-HOSE 14875-H1900 CONNECTOR-VACUUM 17201-H1902 ASSY-TANK FUEL 40L 17201-H2800 ASSY-TANK FUEL 40L 17201-H1901 ASSY-TANK FUEL 40L 17342-18000 RING-O 17343-H1001 PLATE-LOCK 17343-14801 PLATE-LOCK 25060-H1900 GAUGE-FUEL TANK 17312-14800 PACKING-DRAIN 17312-H1000 PACKING-DRAIN 17312-P0101 PACKING-DRAIN 17312-P0102 PACKING-DRAIN 08931-44210 PLUG 17310-H1000 PLUG-DRAIN 17310-P0100 PLUG-DRAIN 17251-H1900 CAP-FILLER 17251-H1000 CAP-FILLER 17251-H1900 CAP-FILLER 17251-H1901 CAP-FILLER 17251-H1902 CAP-FILLER 17264-18000 PACKING 17220-H1901 TUBE-FILLER UPPER 17222-H1000 NECK-FILLER 17221-H1000 PACKING FILLER NECK 08310-40812 SCREW 17229-H1900 HOSE-FILLER 08723-15800 CLAMP-HOSE 08360-82014 BOLT WITH LOCK WASHER 08915-53810 WASHER-PLAIN 17314-H1000 GROMMET 17350-H1900 ASSY-TANK RESERVOIR 17351-H1900 CONNECTOR-3 WAY 17351-H1901 CONNECTOR-3 WAY 17352-H1901 SEPARATOR 17352-H1902 SEPARATOR A8742-20040 HOSE-FUEL RUBBER (10X17X2.2M) 08742-20040 HOSE-FUEL RUBBER (10X17X2.2M) A7515-H1900 HOSE-FUEL RUBBER(10X16DX5M) A7515-H1800 HOSE-FUEL RUBBER(6X13.5X5M) 08742-20020 HOSE-FUEL RUBBER (6X13.5X2.2M 08723-11400 CLAMP-HOSE 1 16439-22100 CLAMP-HOSE 1 17230-H1900 HOSE-FILLER 2ND 17230-H1901 HOSE-FILLER INNER 08723-13600 CLAMP-HOSE 08723-11400 CLAMP-HOSE 16439-22100 CLAMP-HOSE 17361-H1922 TUBE-EVAPO 17361-H1902 TUBE-EVAPO 17361-H1903 TUBE-EVAPO 17201-H1802 ASSY-TANK FUEL 38L 17342-18000 RING-"O" 17343-H1001 PLATE-LOCK 17343-14801 PLATE-LOCK 25060-H1800 GAUGE-FUEL TANK 17312-P0101 PACKING-DRAIN 17312-P0102 PACKING-DRAIN 17312-H1000 PACKING-DRAIN 17312-14800 PACKING-DRAIN 17310-H1000 PLUG-DRAIN 17310-P0100 PLUG-DRAIN 08931-44210 PLUG-DRAIN 17251-H1902 CAP-FILLER 17251-H1900 CAP-FILLER 17251-H1000 CAP-FILLER 17251-H1901 CAP-FILLER 17264-18000 PACKING 17220-H1802 HOSE-FILLER UPPER 17220-H1803 HOSE-FILLER UPPER 17222-H1000 NECK-FILLER 17221-H1000 PACKING FILLER NECK 08310-40812 SCREW-MACHIN 17229-H1802 HOSE-FILLER 17228-H1400 GROMMET 08723-15800 CLAMP-HOSE 17230-H1802 HOSE-FILLER INNER 17230-H1801 HOSE-FILLER 2ND(NOT ADOPTED) 08723-13600 CLAMP-HOSE A7325-H1000 TUBE-VINYLE(10X14DX5M) A7515-H1900 TUBE-RUBBER(10X16DX5M) 08742-20040 TUBE-RUBBER 16439-22100 CLAMP-HOSE 08723-11400 CLAMP-HOSE 17324-H1800 GROMMET 08110-82062 BOLT WITH LOCK WASHER 08915-53810 WASHER-PLAIN 17350-H1801 ASSY-TANK RESERVOIR 17350-H1802 ASSY-TANK RESERVOIR 63140-78500 NUT-JAM 08410-61610 SCREW 08915-13610 WASHER-LOCK 17335-H1801 TUBE-BREATHER RH 17335-H1802 CONNECTOR 17336-H1801 TUBE-BREATHER LH 17515-H1817 HOSE-FUEL FIX FUEL TANK TO EVAPO TANK(L A7515-H1800 HOSE-FUEL(6X13.5X5M) 08742-20020 HOSE-FUEL(6X13.5X2200MM) A7515-H1800 HOSE-FUEL(6X13.5X10M) 08742-20020 HOSE-FUEL(6X13.5X2200MM) 08742-20020 HOSE-FUEL (6X13.5X2.2M) 16439-22100 CLAMP-HOSE 1 08723-11400 CLAMP-HOSE 1 17351-H1800 CONNECTOR-3 WAY 17351-H1801 CONNECTOR-3WAY 17361-H1800 TUBE-EVAPORATION 17361-H1801 TUBE-EVAPORATION 24251-H1801 GROMMET 00951-10600 GROMMET 00951-11000 GROMMET 00951-11200 GROMMET 46115-C0400 GROMMET 17337-H1800 PROTECTOR-FUEL HOSE 24210-89964 CLIP 74890-H1800 PROTECTOR-FILLER HOSE 08110-62010 BOLT FIXING PROTECTOR 08915-23610 WASHER FIXING PROTECTOR 08915-43610 WASHER FIXING PROTECTOR 22100-H1001 ASSY-DISTRIBUTOR(HITACHI) 22167-H2300 SET-CAP CLAMP 22108-H2300 ASSY-SHAFT 22108-H2301 ASSY-SHAFT 22109-71300 WEIGHT-GOVERNOR 22110-H1000 SPRING-GOVERNOR SET 22132-21005 ASSY-CAM 22132-22005 ASSY-CAM 22119-18000 SET-PINION 22136-H2300 ASSY-BRAKER 22145-18005 SET-CONTACT 22182-71300 WIRE-EATH 22183-71300 WIRE-LEAD 22403-18005 ASSY-TERMINAL 22157-78500 ROTOR-HEAD 22157-H1000 ROTOR-HEAD 22162-21007 ASSY-CAP 22165-30101 POINT-CARBON 22301-H1000 ASSY-CONTROL VACUUM 22102-00801 CONDENSER 22248-A5502 SEAL-DUST 22750-H2300 SET-SCREW 22180-71200 RING-"0"DISTRIBUTOR SUPPORT 08110-61210 BOLT-HEX FIXING DISTRIBUTOR TO BLOCK 08915-13610 WASHER-LOCK FIXING DISTRIBUTOR 08915-43610 WASHER-PLAIN FIXING DISTRIBUTOR 22318-18000 TUBE-DISTRIBUTOR VACUUM ADVANCE B2318-73002 TUBE-DISTRIBUTOR VACUUM ADVANCE(5M) 22328-H1000 CLAMP-TUBE VACUUM CONTROL 22328-H1001 CLAMP-TUBE VACUUM CONTROL 22328-H1002 CLAMP-TUBE VACUUM CONTROL 22450-18228 SET-CABLE HIGH TENSION 22450-H1025 SET-CABLE,HIGH TENSION 22450-18201 CABLE-HIGH TENSION COIL TO DISTRIBUTOR 22450-18202 CABLE-HIGH TENSION COIL TO DISTRIBUTOR 22451-18200 CABLE-HIGH TENSION NO.1 22451-18201 CABLE-HIGH TENSION NO.1 22452-18201 CABLE-HIGH TENSION NO.2 22452-18200 CABLE-HIGH TENSION NO.2 22453-18201 CABLE-HIGH TENSION NO.3 22453-18200 CABLE-HIGH TENSION NO.3 22454-18200 CABLE-HIGH TENSION NO.4 22454-18201 CABLE-HIGH TENSION NO.4 22433-14806 COIL-IGNITION(HITACHI) 22433-14606 COIL-IGNITION(HITACHI) 22433-A5400 COIL-IGNITION (HITACHI) 22433-U2000 COIL-IGNITION (HITACHI) 22433-14816 COIL-IGNITION(HANSHIN) 22433-14616 COIL-IGNITION(HANSHIN) 22433-A5410 COIL-IGNITION (HANSHIN) 22433-U2010 COIL-IGNITION (HANSHIN) 22460-14606 RESISTER-IGNITION COIL (HITACHI) 22460-U2210 RESISTER-IGNITION COIL (HANSIN) 22460-U2200 RESISTER-IGNITION COIL (HITACHI) 22460-14615 RESISTER-IGNITION COIL (HANSHIN) 08513-61212 SCREW-MACHINE M6 IGNITION COIL TO BODY 08915-53610 WASHER-PLAIN M6 IGNITION COIL TO BODY 22401-A4804 PLUG-SPARK L44PW(HITACHI) 22401-A4617 PLUG-SPARK 22401-75507 PLUG-SPARK BP-7E(N.G.K) 22401-75500 PLUG-SPARK BP-6E(N.G.K) 22401-75504 PLUG-SPARK BP-4E(N.G.K) 22401-A4707 PLUG-SPARK L47PW(HITACHI) 22401-21007 PLUG-SPARK L47P(HITACHI) 22401-21005 PLUG-SPARK L45P(HITACHI) 22401-A4704 PLUG-SPARK L47PW(HITACHI) 22401-21004 PLUG-SPARK L44P(HITACHI) 22401-A4706 PLUG-SPARK L46PW(HITACHI) 22401-A4705 PLUG-SPARK L45PW(HITACHI) 22401-21000 PLUG-SPARK L46P(HITACHI) 22401-A4605 PLUG-SPARK BP-5ES(N.G.K) 22401-A4616 PLUG-SPARK BP-6ES(N.G.K) 11710-H0100 BRACKET-ALTERNATOR 08131-02210 BOLT-HEX M10 FIXING ALTERNATOR B 08915-14010 WASHER-SPRING M10 FIXING ALTERNATOR B 08130-83010 BOLT-HEX M8 ALTERNATOR FIXING 08911-20810 NUT-HEX M8 ALTERNATOR FIXING 08915-43810 WASHER-PLAIN M8 ALTERNATOR FIXING 08915-13810 WASHER-SPRING ALTERNATOR FIXING 11715-18001 BAR-ADJUSTING ALTERNATOR 11715-H2300 BAR-ADJUSTING ALTERNATOR 11715-M0100 BAR-ADJUSTING ALTERNATOR 08110-81610 BOLT-HEX M8 BAR FIXING 08915-13810 WASHER-SPRING 22401-A4725 SET-IGNITION(HITACHI) 22401-A4706 PLUG-SPARK(L46-PW) 22145-18005 SET-CONTACT 23300-H6900 MOTOR-STARTER (HITACHI S11 23300-H0100 MOTOR-STARTER (HITACHI S11 23300-H0101 MOTOR-STARTER (HITACHI S11 23300-H0101 MOTOR-STARTER (HITACHI S11 23300-H5000 MOTOR-STARTER (HITACHI S11 23300-H3900 MOTOR-STARTER (HITACHI S11 23310-H3900 ASSY-ARMATURE 23310-19900 ASSY-ARMATURE 23310-19900 ASSY-ARMATURE 23321-09900 WASHER-THRUST 23312-10600 ASSY-PINION 23312-10605 ASSY-PINION 23312-E3000 ASSY-PINION 23465-E6800 SET-STOPPER PINION 23383-10600 ASSY-BEARING CENTER 23441-10600 METAL-CENTER BEARING 23306-15801 ASSY-COIL FIELD 23306-M0100 ASSY-COIL FIELD 23306-M0100 ASSY-COIL FIELD 23305-09500 SCREW-POLE,CORE 23337-18005 ASSY-COVER REAR 23337-H0100 ASSY-COVER,REAR 23337-H0100 ASSY-COVER,REAR 23337-10605 ASSY-COVER,REAR 23338-09900 METAL-COVER REAR 23380-19900 BRUSH (+) 23380-19900 BRUSH (+) 23380-10600 BRUSH (+) 23379-19900 BRUSH (-) 23379-19900 BRUSH (-) 23379-09900 BRUSH (-) 23333-09900 SPRING-BRUSH 23333-09900 SPRING-BRUSH 23333-21001 SPRING-BRUSH 23333-21001 SPRING-BRUSH 23340-15805 BOLT-THROUGH 23340-18005 BOLT-THROUGH 23340-18005 BOLT-THROUGH 23318-H0100 ASSY-GEAR CASE 23319-10600 METAL-GEAR CASE 23322-M0100 SET-LEVER SHIFT 23309-H5000 ASSY-COVER BRUSH 23309-18005 ASSY-COVER BRUSH 23309-18005 ASSY-COVER BRUSH 23309-19905 ASSY-COVER BRUSH 23343-18005 ASSY-SWITCH MAGNETIC 23470-M0100 SET-DUST COVER 23390-18005 BOLT M5 23480-M0100 SET-SCREW 24012-H7000 HARNESS-ENGINE ROOM 24012-H7005 HARNESS-ENGINE ROOM 24012-H2112 HARNESS-ENGINE ROOM 24012-H2111 HARNESS-ENGINE ROOM 24012-H7001 HARNESS-ENGINE ROOM 24012-H2102 HARNESS-ENGINE ROOM 24012-H2101 HARNESS-ENGINE ROOM 24012-H2108 HARNESS-ENGINE ROOM 24012-H1900 HARNESS-ENGINE ROOM 24012-H2118 HARNESS-ENGINE ROOM 24013-H1905 HARNESS-INSTRUMENT 24013-H2118 HARNESS-INSTRUMENT 24013-H2112 HARNESS-INSTRUMENT 24013-H7000 HARNESS-INSTRUMENT 24014-H1011 HARNESS-BODY 24014-H1811 HARNESS-BODY 24015-H1900 HARNESS-TAIL 24015-H7000 HARNESS-TAIL 24015-H1910 HARNESS-TAIL 24272-H1000 PROTECTOR-WIRING 24039-H1900 ASSY-CABLE HAND BRAKE SWITCH 24150-H1020 ASSY-CABLE INDICATOR LAMP 24250-89927 GROMMET 24029-H1400 CABLE-TANK UNIT 24220-89937 CLIP FIXING TO BODY SIDE INNER 24220-89953 CLIP FIXING TO REAR COMB LAMP 25442-H1100 LINK-FUSIBLE,TYPE C 25442-H2500 LINK-FUSIBLE,TYPE C 24110-H1600 CABLE-BATTERY(+) 24110-H1605 CABLE-BATTERY (+) 24110-H1900 CABLE-BATTERY(+) 24080-H1900 CABLE-BATTERY(-) 24160-H1100 CABLE-ROOM LAMP 24100-H1600 CABLE-FOG LAMP 24163-H1900 CABLE-HEAT GLASS D 24220-89931 CLIP-CABLE 24161-H2200 CABLE-HEAT GLASS A 24161-H1900 CABLE-HEAT GLASS,A 24162-H2200 CABLE-HEAT GLASS B 24163-H2200 CABLE-HEAT GLASS C 24163-H2000 CABLE-HEAT GLASS 24338-H4600 CABLE-SEAT BELT WARNING 24338-H7005 CABLE-SEAT BELT WARNING 24338-H4600 CABLE-SEAT BELT WARNING 25160-H1010 COMP-SWITCH LIGHTING WITH FOG SWI 25160-H4600 COMP-SWITCH LIGHTING B5160-B6800 COMP-SWITCH LIGHTING 25160-H1001 COMP-SWITCH LIGHTING B5160-B6800 COMP-SWITCH LIGHTING 25165-H1000 KNOB-LIGHTING SWITCH 25165-H4600 KNOB-LIGHTING SWITCH 25165-T3000 KNOB-LIGHTING SWITCH 25199-H1000 SPRING-SWITCH KNOB 25260-H1001 COMP-SWITCH WIPER 25260-H4600 COMP-SWITCH WIPER 25260-H7000 COMP-SWITCH WIPER 25260-H7001 COMP-SWITCH WIPER 25265-H1000 KNOB-WIPER SWITCH 25265-H4600 KNOB-WIPER SWITCH 25265-H7000 KNOB-WIPER SWITCH 25265-H7001 KNOB-WIPER SWITCH 25265-H5200 KNOB-WIPER SWITCH 25199-H1000 SPRING 25170-H2510 ASSY-LAMP,ILLUMINATION 08964-10510 NUT-SPRING 08540-51612 SCREW 25330-H1000 COMP-CIGALETTE LIGHTER 25330-H1001 COMP-CIGALETTE LIGHTER B5331-H5001 COMP-CIGALETTE LIGHTER B5330-H1001 ELEMENT-CIGAR LIGHTER 25290-H1900 COMP-SWITCH HAZARD 25290-H4600 COMP-SWITCH HAZARD 25290-H4601 COMP-SWITCH HAZARD 08513-30812 SCREW FIXING HAZARD SWITCH 08915-13310 WASHER-SPRING 25540-H1100 COMP-SWITCH TURN SIGNAL & DIMMER WITH 25540-H1006 COMP-SWITCH TURN SIGNAL & DIMMER 25540-H1007 COMP-SWITCH TURN SIGNAL & DIMMER 25410-H1000 BLOCK-FUSE 25410-B5102 BLOCK-FUSE B5415-H1000 COVER-FUSE BLOCK 08941-11000 FUSE (10A) 08941-11500 FUSE (15A) 08510-51212 SCREW 08915-13510 WASHER-SPRING 25240-G150A SWITCH-OIL PRESSURE ENGINE 25240-89910 SWITCH-OIL PRESSURE ENGINE 25360-89900 SWITCH-DOOR 25360-89915 SWITCH-DOOR 25320-H1000 SWITCH-STOP LAMP 25520-89911 UNIT HAZARD FLASHER 25520-89997 UNIT HAZARD FLASHER 25520-89990 UNIT HAZARD FLASHER 08510-51012 SCREW-TAPPING 08915-13510 WASHER-SPRING B5520-89993 UNIT-FLASHER 12V 50W 25520-89901 UNIT-FLASHER 12V 50W 08510-51012 SCREW-TAPPING 08915-13510 WASHER-SPRING 26310-H1000 HORN-HIGH 26310-H1800 HORN-HIGH 26330-H1000 HORN-LOW 25620-G2501 HORN-LOW 26330-H1800 HORN-LOW 08110-81410 BOLT-HEX M8 08915-13810 WASHER-SPRING 26320-14800 RELAY-HORN 08310-51062 SCREW-MACHINE WITH LOCK WASHER 26320-89905 ASSY-RELAY,PASSING 08513-51012 SCREW 25390-20300 SWITCH-KICK DOWN 36011-89901 SWITCH-HAND BRAKE 36011-H1900 SWITCH-HAND BRAKE WARNING 25230-H2200 SWITCH-HEAT GLASS 08510-51212 SCREW 22110-N0901 ASSY-SWITCH, THERMOSTAT 08510-51212 SCREW 25235-P0101 ASSY-RELAY,HEATER,AUTO CHOKE 25235-P0100 ASSY-RELAY,HEATER,AUTO CHOKE 08513-61212 SCREW 26350-89905 BUZZER 08513-51012 SCREW 48780-H1900 BRACKET-BUZZER 25230-89918 ASSY-RELAY 25231-H4600 BRACKET-RELAY 08513-51012 SCREW 26495-H4600 LAMP-SEAT BELT WARNING 08961-44810 NUT-PUSH 25310-H4600 SWITCH-SEATING 27010-H1600 KIT-ROOM HEATER 27013-H1001 ASSY-CORE HEATER 27013-H1000 ASSY-CORE HEATER 27014-H1000 ASSY-MOTOR HEATER 27015-H3100 ASSY-RESISTANCE WITH FUSE 27135-H1600 COMP-CONTROL HEATER 27137-H1000 KNOB-HEATER CONTROL'A' 27138-H1000 KNOB-HEATER CONTROL'B' 08310-30612 SCREW 08915-13310 WASHER 27139-H1600 ASSY-CABLE HEATER CONTROL'A' 27140-H1600 ASSY-CABLE HEATER CONTROL'B' 27141-H1600 ROD-HEATER CONTROL 27142-H1000 PIN-CONTROL ROD 27143-H1000 WASHER CONTROL ROD 08915-13510 WASHER 08410-51212 SCREW 08310-61014 SCREW 27018-H1000 VALVE-ROOM HEATER 27161-H1000 HOSE-DEFROSTER 27161-H1001 HOSE-DEFROSTER 27171-H1000 NOZZLE-DEFROSTER 27171-H1001 NOZZLE-DEFROSTER 08513-51212 SCREW 08915-43510 WASHER 08964-10510 NUT-SPRING 27020-H1000 HOSE-WATER 27020-G1900 HOSE-WATER 27021-H1000 HOSE-WATER B7021-H1002 HOSE-WATER 08723-12000 CLAMP-HOSE 27051-E0100 CLIP-WATER 08723-13600 CLAMP-HOSE 27070-H1000 CONNECTOR-WATER INLET 27075-H1000 CONNECTOR-WATER OUTLET 27078-B2000 CLIP 08510-51012 SCREW-TAPPING 08915-43510 WASHER-PLAIN 27363-18001 GROMMET-HEATER 27363-18200 GROMMET-HEATER 08915-53610 WASHER-PLAIN 08915-13610 WASHER-SPRING 08460-61612 SCREW 27012-H1000 PLATE-AIR INTAKE FOR HEATER LESS 08915-53610 WASHER-PLAIN PLATE FIX 08915-13610 WASHER-SPRING X2160-30231 KNOB-VENTIRATOR X2160-30213 ASSY-PANEL HEATER BOX X2160-30600 ASSY-VALVE WATER CONTROL X2161-30600 ASSY-VALVE WATER CONTROL B7017-B8500 ASSY-VALVE WATER CONTROL X2160-30503 HOSE-HEATR 27022-H1000 HOSE-HEATR 27900-H1105 KIT-RADIO WITH ANTENNA (CLARION) 27900-H1110 KIT-RADIO WITH ANTENNA (HITACHI) 27900-H1102 KIT-RADIO WITH ANTENNA (CLARION) 27962-H1100 ASSY-ANTENNA 99993-00090 ASSY-ANTENNA 27962-H1110 ASSY-ANTENNA 27984-89900 CONDENSER-TYPE B 27984-H5001 CONDENSER-TYPE B 68470-H1100 MASK-RADIO DATSUN MARK 27978-H1000 PLUG-RUBBER 27979-H1000 PLUG-RUBBER 27380-H2000 ASSY-CLOCK 27389-H2300 SPACER FIXING CLOCK TO CONCOLE BOX 24410-03021 BATTERY,DRY,N50(12-50AH) 24410-38301 BATTERY,DRY,N50Z (12-60AH) 28800-H1600 ASSY-DRIVE WINDSHIELD WIPER B8800-H1900 ASSY-DRIVE WINDSHIELD WIPER 28800-H1602 ASSY-DRIVE WINDSHIELD WIPER 28810-H1600 ASSY-MOTOR(ISO THREAD) B8810-H1900 ASSY-MOTOR(ISO THREAD) 28810-H1602 ASSY-MOTOR (ISO THREAD) 26389-H1600 ARM-WIPER MOTOR 28835-H1600 ASSY-BRACKET WIPER MOTOR (ISO THREAD) 26389-73000 RING-STOP 28860-H1600 ASSY-CONNECTING ROD NO.1 28865-H1000 ASSY-CONNECTING ROD NO.2 28870-H1600 ASSY-PIVOT NO.1 28875-H1000 ASSY-PIVOT NO.2 08360-61614 SCREW MOTOR FIX 08915-43610 WASHER MOTOR FIX 08320-51419 SCREW MOTOR FIX 28876-H1000 SEAL-PIVOT WINDSHIELD WIPER 26380-H1600 ASSY-ARM WIPER 26375-A4601 ASSY-BLADE WIPER 26375-A4600 ASSY-BLADE WIPER 26381-H1000 NUT-WIPER ARM 27400-H1000 KIT-WINDSHIELD WASHER 27400-H1001 KIT-WINDSHIELD WASHER 27400-G1600 KIT-WINDSHIELD WASHER 27480-89901 ASSY-BAG WINDSHIELD WASHER 27480-H1001 ASSY-BAG WINDSHIELD WASHER 27410-H7020 SET-TANK &BRKT WINDSHIELD WASHER 27480-H7020 ASSY-TANK 27440-H6200 BRKT-WASHER TANK 27446-89901 BRACKET-BAG 08513-61212 SCREW BACK FIX 08915-43610 WASHER BACK FIX 27440-H1001 NOZZLE-WINDSHIELD WASHER 27441-H1000 CLIP 24220-89964 CLIP B7460-89910 TUBE-VINYL 27461-89955 TUBE-VINYL 26010-H1611 ASSY-LAMP HEAD RH(KOITO) 26010-H1610 ASSY-LAMP HEAD RH(KOITO) 26010-H1600 ASSY-LAMP HEAD RH(ICHIKHO) 26010-H1900 ASSY-LAMP HEAD RH(ICHIKHO) 26060-H1600 ASSY-LAMP HEAD LH(ICHIKHO) 26060-H1900 ASSY-LAMP HEAD LH(ICHICHO) 26060-H1610 ASSY-LAMP HEAD LH(KOITO) 26705-89905 UNIT-SEALED BEAM (KOITO) 26705-04201 UNIT-SEALED BEAM (ICHIKHO) 26705-89925 UNIT-SEALED BEAM (ICHIKHO) 26022-H1010 SCREW-ADJUST(KOITO) 26022-H1000 SCREW-ADJUST(ICHIKHO) 26023-H1000 NUT(ICHIKHO) 26023-H1010 NUT(KOITO) 26024-58000 SPRING(ICHIKHO) 26024-H1000 SPRING (ICHIKHO) 26024-H1010 SPRING(KOITO) 26024-H1011 SPRING(KOITO) 26017-14801 RING-RETAINING(ICHIKHO) 26017-18010 RING-RETAINING(KOITO) 26029-A4601 COVER-TERMINAL 26029-A4600 COVER-TERMINAL 26120-H1900 ASSY-LAMP FRONT COMBINATION RH(ICHIKHO) 26120-H1901 ASSY-LAMP,FRONT COMBINATION R.H 26120-H7000 ASSY-LAMP,FRONT COMBINATION R.H 26125-H1900 ASSY-LAMP FRONT COMBINATION LH(ICHIKHO) 26125-H1901 ASSY-LAMP,FRONT COMBINATION L.H 26125-H7000 ASSY-LAMP,FRONT COMBINATION L.H 26121-H1000 LENS RH AMBER(ICHIKHO) 26121-H1901 LENS RH AMBER(ICHIKHO) 26126-H1000 LENS LH AMBER(ICHIKHO) 26126-H1901 LENS LH AMBER(ICHIKHO) 26123-H1000 PACKING RH(ICHIKHO) 26128-H1000 PACKING LH(ICHIKHO) 26717-89920 BULB 12V-23-8W(ICHIKHO) 08310-44020 SCREW TO FIX LENS(ICHIKHO) (M4X0.7) 26127-04100 SEAT TO FIX LENS(ICHIKHO) 01221-00023 FLANGE NUT 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO) 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH 26185-H7000 ASSY-LAMP SIDE MARKER FRONT LH 26185-H1900 ASSY-LAMP SIDE MARKER FRONT LH(ICHIKHO) 26181-H1900 LENS(ICHIKHO) 26182-H1900 RIM(ICHIKHO) 26184-H1900 PACKING RH(ICHIKHO) 26189-H1900 PACKING LH(ICHIKHO) 01451-00041 SCREW(ICHIKHO) 08964-10410 NUT-SPRING(ICHIKHO) 26715-89902 BULB 12V-8W(ICHIKHO) 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) 26195-H1900 ASSY-LAMP SIDE MARKER REAR LH(ICHIKHO) 26195-H1910 ASSY-LAMP SIDE MARKER REAR LH(ICHIKHO) 26191-H1900 LENS(ICHIKHO) 26182-H1900 RIM(ICHIKHO) 26194-H1900 PACKING RH(ICHIKHO) 26194-H1910 PACKING RH(ICHIKHO) 26199-H1900 PACKING LH(ICHIKHO) 26199-H1910 PACKING LH(ICHIKHO) 01451-00061 SCREW(ICHIKHO) 01451-00041 SCREW(ICHIKHO) 08964-10410 NUT-SPRING(ICHIKHO) 26715-89902 BULB 12V-8W(ICHIKHO) 26550-H1902 ASSY-LAMP REAR COMBNATION RH(ICHIKHO) 26550-H7000 ASSY-LAMP REAR COMBINATION RH 26555-H1902 ASSY-LAMP REAR COMBNATION LH(ICHIKHO) 26555-H7000 ASSY-LAMP REAR COMBINATION LH 26552-H1001 ASSY-RIM (ICHIKHO) 26553-H1000 ASSY-PACKING (ICHIKHO) 26599-H1000 SEAT (ICHIKHO) 26551-H1902 ASSY-LENS RH RED-RED-WHITE (ICHIKHO) 26556-H1902 ASSY-LENS LH RED-RED-WHITE (ICHIKHO) 26563-H1600 ASSY-HARNESS,R.H 26564-H1600 ASSY-HARNESS,L.H 26717-89900 BULB 12V-23W (ICHIKHO) 26717-89920 BULB 12V-23/8W (ICHIKHO) 08911-10410 NUT (ICHIKHO) 1 08915-13410 WASHER-SPRING 1 08915-43410 WASHER-PLAIN 1 26510-H1900 ASSY-LAMP LICENCE(ICHIKHO) 26511-H1000 LENS 26512-H1000 COVER 26513-H1000 PACKING 08310-41420 SCREW 08915-43510 WASHER-PLAIN 08915-13510 WASHER-PLAIN 08911-10510 NUT 26715-89901 BULB 12V-7.5W(ICHIKHO) 26510-H7000 ASSY-LAMP LICENCE,RH 26515-H7000 ASSY-LAMP LICENCE,LH 26715-89901 BLUB 12V-7.5W 01221-00011 NUT-FLANGE 24147-H7000 CABLE-LAMP,LICENCE 26410-H1000 ASSY-LAMP ROOM(ICHIKHO) 26411-H1000 LENS 26736-89902 BULB 08310-41210 SCREW-MACHINE (M4X0.7) 08510-41212 SCREW-TAPPING ROOM LAMP FIX 22100-H1901 DISTRIBUTOR(HITACHI) 22100-H1902 DISTRIBUTOR (HITACHI D412-63A) 22100-H7100 DISTRIBUTDR (HITACHI) 22100-H3900 DISTRIBUTOR(HITACHI) 22100-H3901 DISTRIBUTOR (HITACHI D412-80A) 22167-H2300 SET-CLAMP,CAP 22108-H1900 ASSY-SHAFT 22108-H2300 ASSY-SHAFT 22108-H2301 ASSY-SHAFT 22160-M0800 SET-WASHER THRUST 22109-71300 WEIGHT-GOVERNOR 22110-H1900 SPRING-GOVERNOR 22110-H1901 SPRING-GOVERNOR 22110-H7100 SPRING-GOVERNOR 22132-H1901 ASSY-CAM SET 22132-H1900 ASSY-CAM SET 22119-18000 SET-PINION 22136-H2300 ASSY-BRAKER PLATE 22136-E4600 ASSY-BRAKER PLATE 22145-18005 SET-CONTACT 22145-89901 SET-CONTACT 22182-71300 ASSY-WIRE,EARTH 22183-71300 ASSY-WIRE,LEAD 22403-18005 ASSY-TERMINAL 22248-A5502 SEAL-DUST 22157-78500 ASSY-ROTOR,HEAD 22157-H1000 ASSY-ROTOR,HEAD 22157-D1290 ASSY-ROTOR,HEAD 22162-21007 ASSY-CAP 22165-30101 POINT-CARBON 22301-B3000 ASSY-CONTROL,VACUUM 22301-B3001 ASSY-CONTROL,VACUUM 22301-H1900 ASSY-CONTROL,VACUUM 22301-E4603 ASSY-CONTROL,VACUUM 22301-H3900 ASSY-CONTROL,VACUUM 22301-H3901 ASSY-CONTROL,VACUUM 22102-00801 ASSY-CONDENSER 22102-D1100 ASSY-CONDENSER 22750-H2300 SET-SCREW 22180-18000 PLATE-FIX 22201-18005 BOLT 23100-U0100 ASSY-ALT.12V-35A (HITACHI LT135-13)(DE 23100-A5501 ASSY-ALTERNATOR(HITACHI) 23108-A5501 ASSY-ROTOR 23120-14801 BEARING-BALL 23102-A5501 ASSY-STATOR 23127-H0300 ASSY-COVER,REAR 23127-61700 ASSY-COVER,REAR 23127-61701 ASSY-COVER REAR 23236-H0300 COVER-DIODE 23236-H0301 COVER-DIODE 23230-H0300 ASSY-DIODE 23133-H0300 ASSY-HOLDER,BRUSH 23133-H0301 ASSY-HOLDER,BRUSH 23135-H0300 ASSY-BRUSH,F 23135-H0301 ASSY-BRUSH,E 23156-H0300 ASSY-TERMINAL BOLT 23118-H0300 ASSY-COVER,FRONT 23122-21000 PACKING 23121-21000 RETAINER-PACKING 23120-14800 BEARING-BALL 23123-21005 RETAINER-BEARING 23164-H0100 BOLT-SETTING 23131-H0300 BOLT-THROUGH,L=85 23131-H0301 BOLT-THROUGH,L=95 23150-21001 ASSY-PULLEY 23150-21002 ASSY-PULLEY 23153-H0100 ASSY-NUT 23200-E3400 SCREW-SET 23500-N3300 REGULATOR-VOLTAGE (HITACHI TLI 23500-29906 REGULATOR-VOLTAGE (HITACHI TLI 23500-29902 REGULATOR-VOLTAGE (HITACHI TLI 23500-29901 REGULATOR-VOLTAGE (HITACHI TL1 23500-29911 REGULATOR-VOLTAGE (MITSUBISHI 08513-61212 SCREW-TAPPING 08916-13610 WASHER-LOCK (INTERNAL TOOTH) 23100-U0100 ASSY-ALTERNATOR 12V-35A (LT135-13) 23108-U0100 ASSY-ROTOR 23120-14801 BEARING-BALL 23102-U0101 ASSY-STATOR 23102-U0100 ASSY-STATOR 23127-U0100 ASSY-COVER,REAR 23127-U0101 ASSY-COVER,REAR 23133-U0100 ASSY-HOLDER,BRUSH 23133-U0101 ASSY-BRUSH 23135-H0300 ASSY-BRUSH(F) 23135-H0301 ASSY-BRUSH(E) 23193-P0100 TERMINAL-N 23236-U0100 COVER-BRUSH 23230-U0100 DIODE 23236-H0300 COVER-DIODE 23236-H0301 COVER-DIODE 23156-H0300 ASSY-BOLT,TERMINAL 23247-H0300 SLEEVE 23118-H0300 ASSY-COVER,FRONT 23120-14800 BEARING-BALL 23121-21000 RETAINER-PACKING 23122-21000 PACKING 23131-H0300 BOLT-THROUGH 23131-H0301 BOLT-THROUGH 23164-H0100 BOLT-SETTING 23150-21002 ASSY-PULLEY 23153-H0100 ASSY-NUT,PULLEY 23200-E3400 SET-SCREW 24820-H1911 COMBINED-INSTRUMENT 100MILE/H 24820-H7000 COMBINED-INSTRUMENT 100MPH 24850-H1816 ASSY-SPEEDOMETER 100MILE/H 24850-H7000 ASSY-SPEEDOMETER 100MILE/H 24860-H1800 GAUGE-FUEL 24880-H1800 GAUGE-WATER TEMP 25010-H1701 LID-CLUSTER 25010-H4600 LID-CLUSTER 25010-H7000 LID-CLUSTER 25012-H1800 COVER-FRONT 25013-H1800 GASKET 25014-H1800 PLATE-SHADOW 25030-H1701 ASSY-CASE REAR 25030-H1710 ASSY-CASE REAR 26260-89900 SOCKET-WEDGE 26261-89902 BLUB 1.7W 26260-H1800 SOCKET-WITH LIED WIRE 26711-89900 BLUB 1.7W 25005-H1810 MASK-TACHOMETER "DATSUN" 24855-H1800 ASSY-TACHOMETER 24854-78501 KNOB-TACHOMETER 25006-H1000 SCREW 25050-H1601 ASSY-SHAFT FLEXIBLE L=1700 25050-H1602 ASSY-SHAFT FLEXIBLE 25080-89900 GAUGE-TEMP ENGINE UNIT 25251-30100 NUT 25035-H7000 ASSY-AMPLIFIER SPEED SWITCH 66502-H1000 ASSY-PLATE, AIR VENTILATOR 66511-H1000 ASSY-LID, AIR VENTILATOR 66504-18001 SPRING-AIR VENTILATOR R.H. 66505-18001 SPRING-AIR VENTILATOR L.H. 66507-18000 PIN-AIR VENTILATOR 66520-H1000 ASSY-CONTROL, AIR VENTILATOR 27137-H1000 KNOB-HEATER CONTROL 84371-78200 HOLDER-ROD 08915-53610 WASHER-PLAIN 08915-13610 WASHER-LOCK 08460-61612 SCREW M6 08310-51214 SCREW M5 66522-H1600 ROD-CONTROL, VENTILATOR 26550-H1911 ASSY-LAMP REAR COMBINATION RH(ICHIKHO) 26550-H7100 ASSY-LAMP REAR COMBINATION RH 26555-H1911 ASSY-LAMP REAR COMBINATION LH(ICHIKHO) 26555-H7100 ASSY-LAMP REAR COMBINATION LH 26521-H1911 LENS-TURN SIGNAL RED (ICHIKHO) 26541-H1800 LENS-REVERSE LAMP RH UNCOLOR(ICHIKHO) 26546-H1800 LENS-REVERSE LAMP LH UNCOLOR(ICHIKHO) 26551-H1910 LENS-TAIL & STOP RH RED (ICHIKHO) 26556-H1910 LENS-TAIL & STOP LH RED (ICHIKHO) 26552-H1800 RIM (ICHIKHO) 26533-H1800 PACKING-LENS (ICHIKHO) 26553-H1800 PACKING-BODY (ICHIKHO) 26534-H1910 ASSY-HARNESS RH (ICHIKHO) 26539-H1910 ASSY-HARNESS LH (ICHIKHO) 26717-89920 BULB 12V-23/8W (ICHIKHO) 26717-89900 BULB 12V-23W (ICHIKHO) 08310-31410 SCREW 1 08911-10510 NUT 1 08915-13510 WASHER-SPRING 1 08915-43510 WASHER-PLAIN 1 26558-H1800 WASHER-SPONGE 1 26510-H1800 ASSY-LAMP LICENCE(ICHIKHO) 26511-H1800 LENS(ICHIKHO) 26513-H1800 PACKING(ICHIKHO) 26513-H1801 PACKING(ICHIKHO) 26715-89901 BULB 12V-7.5W 08310-41420 SCREW FIXING LENS 08310-51412 SCREW-MACHINE
