Special Tool Part Numbers
Revision as of 07:35, 10 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Special factory Datsun service tools
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Tools
Special Tool - Engine, Clutch, Transmission
ST093-50000 SET-C TOOL
2 ST110-80000 REAMER SET-VALVE GUIDE FOR ENGINE
3 ST113-20000 DRIFT-VALVE GUIDE FOR ENGINE
4 ST116-70000 CUTTER SET-VALVE SEAT FOR ENGINE
5 ST130-40000 PRESS STAND-PISTON PIN FOR ENGINE
6 ST161-10000 DRIFT-CAMSHAFT BEARING FOR ENGINE
7 ST166-80000 PULLER-PILOT BUSH FOR ENGINE
8 ST206-10000 BAR-CLUTCH ALIGNING FOR CLUTCH
9 ST223-50000 DRIFT-MAIN SHAFT BEARING FOR TRANSMIS
10 ST230-30000 PRESS STAND-COUNTER SHAFT BEARING FOR
11 ST230-50000 HEIGHT GAUGE-COUNTER GEAR FOR TRANSMIS
12 ST235-20000 PUNCH-SOLID FOR TRANSMISSION
13 ST236-20000 GUIDE-FORKE ROD FOR TRANSMISSION
14 ST238-20000 PLATE-ADAPTER SETTING FOR TRANSMISSION
15 ST227-30000 PULLER-BEARING FOR TRANSMISSION
Special Tool - Differential, Front Axle, Rear Axle
16 ST306-00000 DRIFT-DRIVE PINION BEARING FOR DIFFEREN
17 ST311-20000 GAUGE-DRIVE PINION ARANGEMENT F
18 ST315-40000 WRENCH-DRIVE PINION FLANGE FOR DIFFEREN
19 ST325-00000 WEIGHT-SIDE BEARING ADJUST FOR DIFFEREN
20 ST332-20000 DRIFT-SIDE BEARING FOR DIFFERENCIAL
21 ST311-90000 GAUGE-PRELORD FOR DIFFERENCIAL
22 ST312-30000 ASSY-DUMMY SHAFT FOR DIFFERENCIAL
23 ST353-10000 DRIFT-FRONT WHEEL HUB BRG OUTER RACE F
24 ST355-50000 GUIDE-GRAND PACKING FOR AXLE
25 ST371-30000 PULLER-REAR AXLE SHAFT BEARING FOR
26 ST382-70000 PRESS STAND-REAR AXLE SHAFT BEARING FOR
27 ST367-20000 REPLACER SET-TRANSVERS LINK BUSHING FOR
28 ST271-90000 PULLER-STEERING LINKAGE JOINT FOR AX
