Also see:
Part Numbers Index Main article for usage, photos, cross-reference Carburetor
From June 1971 with Auto Choke
1 16010-H3901 ASSY-CARBURETOR (DCH306-1A) A12,MANUAL 2 16010-H3900 1 16010-H3902 ASSY-CARBURETOR (DCH306-1B) A12,MANUAL -672 22 16010-H3901 1 16010-H7000 ASSY-CARBURETOR (DCH306-4) A12,MANUAL 0772- 0 16010-H3902 1 16010-H3920 ASSY-CARBURETOR (DCH306-3) A12,AUTO 1 16010-H3921 ASSY-CARBURETOR (DCH306-3A) A12,AUTO 2 16010-H3920 1 16010-H3922 ASSY-CARBURETOR (DCH306-3B) A12,AUTO -672 22 16010-H3921 1 16010-H7100 ASSY-CARBURETOR (DCH306-5) A12,AUTO 0772- 0 16010-H3900 1 16010-H3900 ASSY-CARBURETOR (DCH306-1) A12,MANUAL 2 16011-H7011 ASSY-CHAMBER,CHOKE A12,MANUAL 0772- 0 16011-H3910 2 16011-H3920 ASSY-CHAMBER,CHOKE A12,AUTO -672 2 2 16011-H3910 ASSY-CHAMBER,CHOKE A12,MANUAL -672 2 2 16011-H7111 ASSY-CHAMBER,CHOKE A12,AUTO 0772- 0 16011-H3920 3 16182-H3920 POT-DASH A12,AUTO 4 16302-H3910 LEVER-PUMP A12 5 16258-H3920 HOLDER-DASH POT A12,AUTO 6 16143-H3910 ROD-PUMP A12 7 16262-H3910 DIAPHRAGM-SERVO A12 8 16118-H3910 ASSY-CHAMBER,THROTTLE A12 8 16118-H3911 ASSY-CHAMBER,THROTTLE A12 -672 22 16118-H3910 8 16118-H7011 ASSY-CHAMBER,THROTTLE A12 0772- 0 16118-H3911 9 16145-91460 SPRING-IDLE ADJUST SCREW A12 10 16145-50000 SPRING-THROTTLE ADJUST SCREW A12 11 16129-25710 SCREW-THROTTLE ADJUST A12 11 16129-25715 SCREW-THROTTLE ADJUST A12 -672 22 16129-25710 11 16114-H7010 SCREW-THROTTLE ADJUST A12 0772- 0 16129-25715 12 16144-M0110 SCREW-IDLE ADJUST A12 -672 2 12 16144-H7010 SCREW-IDLE ADJUST A12 0772- 0 16144-M0110 13 16147-E6600 CAP-IDLE LIMITTEY A12 1070-0672 2 14 16082-H3910 PLATE-ADJUST A12 -672 2 14 16082-H7010 PLATE-ADJUST A12 0772- 0 16082-H3910 15 16116-H3910 SLEEVE(B) A12 16 16128-H3910 LEVER-FIRST IDLE A12 17 16249-H3910 LEVER-OPENER A12 18 16389-H7010 COVER-THERMO A12 0772- 0 16389-H3910 18 16389-H3910 COVER-THERMO A12 -672 2 19 16267-H3910 PIPE-VACUUM A12,MANUAL 19 16267-H3920 PIPE-VACUUM A12,AUTO 20 16161-H1911 HANGER-SPRING A12,MANUAL -672 2 20 16161-H7010 HANGER-SPRING A12,MANUAL 0772- 0 16161-H1911 21 16134-H1910 LEVER-THROTTLE A12,MANUAL 21 16134-H3920 LEVER-THROTTLE A12,AUTO 22 16116-H1910 SLEEVE(A) A12 23 16236-H1910 LEVER A12 24 16452-H1000 SPRING-PUMP LEVER A12 25 16453-H1000 WASHER A12 26 16025-H1000 TUBE-EMULSION(P) A12 27 16160-H1910 SPRING-THROTTLE RETURN A12 28 16171-25710 WEIGHT-INJECTOR A12 -672 2 28 16171-H7010 WEIGHT-INJECTOR A12 0772- 0 16171-25710 29 16061-18010 FLOAT A12 30 16026-B0810 TUBE-EMULSION(S) A12 31 16151-H1000 PISTON-POWER A12 1070- 32 16148-H1000 SPRING-PISTON RETURN A12 33 16141-18010 ROD-CONNECTING A12 34 16305-19915 SHAFT-PUMP LEVER A12 35 16307-04000 COVER-PUMP A12 36 16272-36710 PLUG-DRAIN (2) A12 37 16066-18010 SHAFT-FLOAT A12 38 16101-H1000 VALVE-NEEDLE A12 39 16098-25710 FILTER A12 40 16029-18010 WASHER A12 41 16065-H1010 SCREW A12 42 16033-L0101 JET-MAIN #97 A12 -672 2 42 16033-H7010 JET-MAIN #95 A12 0772- 0 16033-L0101 43 16043-25715 JET-MAIN #140 A12 44 16055-14811 JET-SLOW #43 A12 45 16054-B0810 JET-SLOW #50 A12 46 16050-18010 BLEED-SLOW AIR #80 (2) A12 47 16204-08000 BLEED-SLOW AIR #100 A12 48 16051-H3910 BLEED-SLOW AIR #215 A12 49 16059-H3910 VALVE-POWER #50 A12 -671 1 49 16059-H3911 VALVE-POWER #45 A12 0771-0672 22 16059-H3910 49 16059-14810 VALVE-POWER #60 A12 0772- 2 16059-H3911 50 16196-H7010 ASSY-CUT,FUEL A12 0772-1072 2 50 16196-H7011 VALVE-ANTI DIESELING SOLENOID A12 1172- 0 16196-H7010
51 16455-H1000 KIT-GASKET A12 -672 2 51 16455-H6200 KIT-GASKET A12 2 16455-H1001 51 16455-H6200 KIT-GASKET A12 2 16455-H1000 51 16455-H1001 KIT-GASKET A12 0772- 2 16455-H1000 52 16475-H3910 KIT-SCREW & WASHER(B) A12 -1072 2 52 16475-H7010 KIT-SCREW & WASHER (B) A12 1172- 0 16475-H3910 53 16465-H3910 KIT-SCREW & WASHER(A) A12 54 16009-H1910 KIT-REPAIR A, CARBURETOR A12 -672 2 54 16009-H7000 KIT-REPAIR A,CARBURETOR A12 0772- 2 16009-H1910 54 16009-H6200 KIT-REPAIR A CARBURETOR A12 2 16009-H7000 55 16009-H7010 KIT-REPAIR B,CARBURETOR A12 0772- 2 16009-H3910 55 16009-H3910 KIT-REPAIR B, CARBURETOR A12 -672 2
1 16010-H3901 ASSY-CARBURETOR (DCH306-1A) A12,MANUAL 2 16010-H3900 1 16010-H3902 ASSY-CARBURETOR (DCH306-1B) A12,MANUAL -672 22 16010-H3901 1 16010-H7000 ASSY-CARBURETOR (DCH306-4) A12,MANUAL 0772- 0 16010-H3902 1 16010-H3920 ASSY-CARBURETOR (DCH306-3) A12,AUTO 1 16010-H3921 ASSY-CARBURETOR (DCH306-3A) A12,AUTO 2 16010-H3920 1 16010-H3922 ASSY-CARBURETOR (DCH306-3B) A12,AUTO -672 22 16010-H3921 1 16010-H7100 ASSY-CARBURETOR (DCH306-5) A12,AUTO 0772- 0 16010-H3900 1 16010-H3900 ASSY-CARBURETOR (DCH306-1) A12,MANUAL 2 16011-H7011 ASSY-CHAMBER,CHOKE A12,MANUAL 0772- 0 16011-H3910 2 16011-H3920 ASSY-CHAMBER,CHOKE A12,AUTO -672 2 2 16011-H3910 ASSY-CHAMBER,CHOKE A12,MANUAL -672 2 2 16011-H7111 ASSY-CHAMBER,CHOKE A12,AUTO 0772- 0 16011-H3920 3 16182-H3920 POT-DASH A12,AUTO 4 16302-H3910 LEVER-PUMP A12 5 16258-H3920 HOLDER-DASH POT A12,AUTO 6 16143-H3910 ROD-PUMP A12 7 16262-H3910 DIAPHRAGM-SERVO A12 8 16118-H3910 ASSY-CHAMBER,THROTTLE A12 8 16118-H3911 ASSY-CHAMBER,THROTTLE A12 -672 22 16118-H3910 8 16118-H7011 ASSY-CHAMBER,THROTTLE A12 0772- 0 16118-H3911 9 16145-91460 SPRING-IDLE ADJUST SCREW A12 10 16145-50000 SPRING-THROTTLE ADJUST SCREW A12 11 16129-25710 SCREW-THROTTLE ADJUST A12 11 16129-25715 SCREW-THROTTLE ADJUST A12 -672 22 16129-25710 11 16114-H7010 SCREW-THROTTLE ADJUST A12 0772- 0 16129-25715 12 16144-M0110 SCREW-IDLE ADJUST A12 -672 2 12 16144-H7010 SCREW-IDLE ADJUST A12 0772- 0 16144-M0110 13 16147-E6600 CAP-IDLE LIMITTEY A12 1070-0672 2 14 16082-H3910 PLATE-ADJUST A12 -672 2 14 16082-H7010 PLATE-ADJUST A12 0772- 0 16082-H3910 15 16116-H3910 SLEEVE(B) A12 16 16128-H3910 LEVER-FIRST IDLE A12 17 16249-H3910 LEVER-OPENER A12 18 16389-H7010 COVER-THERMO A12 0772- 0 16389-H3910 18 16389-H3910 COVER-THERMO A12 -672 2 19 16267-H3910 PIPE-VACUUM A12,MANUAL 19 16267-H3920 PIPE-VACUUM A12,AUTO 20 16161-H1911 HANGER-SPRING A12,MANUAL -672 2 20 16161-H7010 HANGER-SPRING A12,MANUAL 0772- 0 16161-H1911 21 16134-H1910 LEVER-THROTTLE A12,MANUAL 21 16134-H3920 LEVER-THROTTLE A12,AUTO 22 16116-H1910 SLEEVE(A) A12 23 16236-H1910 LEVER A12 24 16452-H1000 SPRING-PUMP LEVER A12 25 16453-H1000 WASHER A12 26 16025-H1000 TUBE-EMULSION(P) A12 27 16160-H1910 SPRING-THROTTLE RETURN A12 28 16171-25710 WEIGHT-INJECTOR A12 -672 2 28 16171-H7010 WEIGHT-INJECTOR A12 0772- 0 16171-25710 29 16061-18010 FLOAT A12 30 16026-B0810 TUBE-EMULSION(S) A12 32 16148-H1000 SPRING-PISTON RETURN A12 33 16141-18010 ROD-CONNECTING A12 34 16305-19915 SHAFT-PUMP LEVER A12 35 16307-04000 COVER-PUMP A12 36 16272-36710 PLUG-DRAIN (2) A12 37 16066-18010 SHAFT-FLOAT A12 38 16101-H1000 VALVE-NEEDLE A12 39 16098-25710 FILTER A12 40 16029-18010 WASHER A12 41 16065-H1010 SCREW A12 42 16033-L0101 JET-MAIN #97 A12 -672 2 42 16033-H7010 JET-MAIN #95 A12 0772- 0 16033-L0101 43 16043-25715 JET-MAIN #140 A12 44 16055-14811 JET-SLOW #43 A12 45 16054-B0810 JET-SLOW #50 A12 46 16050-18010 BLEED-SLOW AIR #80 (2) A12 47 16204-08000 BLEED-SLOW AIR #100 A12 48 16051-H3910 BLEED-SLOW AIR #215 A12 49 16059-H3910 VALVE-POWER #50 A12 -671 1 49 16059-H3911 VALVE-POWER #45 A12 0771-0672 22 16059-H3910 49 16059-14810 VALVE-POWER #60 A12 0772- 2 16059-H3911 50 16196-H7010 ASSY-CUT,FUEL A12 0772-1072 2 50 16196-H7011 VALVE-ANTI DIESELING SOLENOID A12 1172- 0 16196-H7010 51 16455-H1000 KIT-GASKET A12 -672 2 51 16455-H6200 KIT-GASKET A12 2 16455-H1001 51 16455-H6200 KIT-GASKET A12 2 16455-H1000 51 16455-H1001 KIT-GASKET A12 0772- 2 16455-H1000 52 16475-H3910 KIT-SCREW & WASHER(B) A12 -1072 2 52 16475-H7010 KIT-SCREW & WASHER (B) A12 1172- 0 16475-H3910 53 16465-H3910 KIT-SCREW & WASHER(A) A12 54 16009-H1910 KIT-REPAIR A, CARBURETOR A12 -672 2 54 16009-H7000 KIT-REPAIR A,CARBURETOR A12 0772- 2 16009-H1910 54 16009-H6200 KIT-REPAIR A CARBURETOR A12 2 16009-H7000
