Front Body Panels Part Numbers
Revision as of 01:22, 15 January 2012; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main articles for usage, photos, cross-reference:
Fender (guard/wing)
Hood (bonnet)
Mirrors
Core Support
Battery
Sedan
1 62500-H1000 ASSY-SUPPORT,RADIATOR CORE SEDAN
2 62512-H1000 RAIL-SUPPORT,RADIATOR CORE, UPPER SEDAN
3 62522-H1001 STAY-HOOD CATCH SEDAN
4 62612-H1000 PANEL-APRON,FRONT SEDAN
5 63100-H1900 ASSY-FENDER,FRONT,RH SEDAN
6 63101-H1900 ASSY-FENDER,FRONT,LH SEDAN
7 01111-00022 BOLT-HEX WITH WASHER FENDER FIX 1 (16) SEDAN
8 08915-43610 WASHER-PLAIN FENDER FIX 1 (16) SEDAN
9 63810-H1001 SEALER-COWL TOP(L=250MM) (2) SEDAN 0670-
9 63810-H1000 SEALER-COWL TOP(L=200MM) (2) SEDAN
10 63811-H1000 SEALER-FRONT FENDER (2) SEDAN
11 64100-H1000 ASSY-HOODLEDGE,RH SEDAN
11 64100-H3100 ASSY-HOODLEDGE.R.H. SEDAN 1271-
11 64100-H7000 ASSY-HOODLEDGE,RH SEDAN 0772-
12 64101-H1000 ASSY-HOODLEDGE,LH SEDAN
12 64101-H7000 ASSY-HOODLEDGE,LH SEDAN 0772-
13 24420-21401 FRAME-BATTERY,FIX SEDAN
13 24420-J0600 FRAME-BATTERY,FIX SEDAN
14 24440-21000 ROD-BATTERY,FIX (2) SEDAN
14 24422-18001 ROD-BATTERY,FIX (2) SEDAN
14 24438-21000 ROD-BATTERY,FIX (2) SEDAN
15 24427-H1000 STAY-BATTERY BRACKET SEDAN
15 24427-H1001 STAY-BATTERY BRACKET (2) SEDAN
16 77720-89910 BOLT-SPECIAL (3) SEDAN
16 77720-89913 BOLT-SPECIAL (3) SEDAN
17 24428-19102 TRAY-BATTERY SEDAN
17 24428-89920 TRAY-BATTERY SEDAN 1170-
18 08911-10610 NUT-HEX (2) SEDAN
19 08915-43610 WASHER-PLAIN (2) SEDAN
19 08915-4361A WASHER-PLAIN (2) SEDAN
20 65100-H1000 ASSY-PANEL,HOOD SEDAN
20 F5100-G1902 ASSY-PANEL,HOOD SEDAN
21 65400-H1001 ASSY-HINGE,HOOD,RH SEDAN
22 65401-H1001 ASSY-HINGE,HOOD,LH SEDAN
23 65409-H1000 PIN-HINGE,TO BRACKET (2) SEDAN
 65409-80W00 PIN-HINGE,TO BRACKET (2) SEDAN
24 08915-13810 WASHER-LOCK,HINGE TO BRACKET (2) SEDAN
25 08110-61210 BOLT-HEX,HINGE TO HOOD (4) SEDAN
26 08915-43610 WASHER-PLAIN,HINGE TO HOOD (4) SEDAN
27 08915-13610 WASHER-LOCK,HINGE TO HOOD (4) SEDAN
28 65510-H1000 ROD-HOOD SUPPORT SEDAN
28 65510-G1200 ROD-HOOD SUPPORT SEDAN
29 65512-H1000 GROMMET-ROD,HOOD SEDAN
29 65512-H2500 GROMMET-ROD,HOOD SEDAN 1070-
30 65514-H1000 CLAMP-ROD,HOOD SEDAN
30 65514-55W00 CLAMP-ROD,HOOD SEDAN
31 96302-H1900 ASSY-DOOR MIRROR LH SEDAN
 96301-H5950 ASSY-DOOR MIRROR RH SEDAN
31 96302-H5950 ASSY-DOOR MIRROR LH SEDAN
32 62845-78500 RUBBER-RADIATOR CORE SUPPORTSIDE (2) SEDAN
Coupe
1 63100-H1900 ASSY-FRONT FENDER RH COUPE
2 63101-H1900 ASSY-FRONT FENDER LH COUPE
3 01111-00022 BOLT-HEX WITH WASHER FENDER FIX 1 (16) COUPE
4 08915-43610 WASHER-PLAIN FENDER FIX 1 (16) COUPE
5 63810-H1001 SEALER-COWL TOP (2) COUPE 0670- 2 63810-H1000
5 63810-H1000 SEALER-COWL TOP (2) COUPE
6 63811-H1000 SEALER-FRONT FENDER (2) COUPE
7 64100-H1000 ASSY-HOODLEDGE RH COUPE
7 64100-H3100 ASSY-HOODLEDGE R.H. COUPE 1271- 5 64100-H1000
7 64100-H7000 ASSY-HOODLEDGE RH COUPE 0772- 0 64100-H3100
8 64101-H1000 ASSY-HOODLEDGE LH COUPE
8 64101-H7000 ASSY-HOODLEDGE LH COUPE 0772- 0 64101-H1000
9 24420-J0600 FRAME-BATTERY FIX COUPE 2 24420-21401
9 24420-21401 FRAME-BATTERY FIX COUPE
10 24440-21000 ROD-BATTERY FIX C (2) COUPE 2 24438-21000
10 24438-21000 ROD-BATTERY FIX A (NOT ADOPTED (2) COUPE
11 24427-H1000 STAY-BATTERY BRACKET COUPE
11 24427-H1001 STAY-BATTERY BRACKET (2) COUPE 2 24427-H1000
12 24428-19102 TRAY-BATTERY COUPE
12 24428-89920 TRAY-BATTERY COUPE 1170- 2 24428-19102
13 08911-10610 NUT-HEX M6X1.0 (2) COUPE
14 08915-43610 WASHER-PLAIN M6 (2) COUPE
15 65100-H1000 ASSY-PANEL HOOD COUPE
16 65400-H1001 ASSY-HINGE HOOD RH COUPE
17 65401-H1001 ASSY-HINGE HOOD LH COUPE
18 65409-H1000 PIN-HINGE HOOD HINGE TO BRACKET (2) COUPE
19 08915-13610 WASHER-LOCK M6 HINGE TO BRACKET (2) COUPE
20 08110-61210 BOLT-HEX M6X1.0 HINGE TO HOOD (4) COUPE
21 08915-43610 WASHER-PLAIN M6 HINGE TO HOOD (4) COUPE
22 08915-13610 WASHER-LOCK M6 HINGE TO HOOD (4) COUPE
23 65510-H1000 ROD-HOOD SUPPOUT COUPE
24 65512-H1000 GROMMET-HOOD ROD COUPE
24 65512-H2500 GROMMET-HOOD ROD COUPE 1070- 2 65512-H1000
25 65514-H1000 CLAMP-ROD HOOD COUPE
26 96302-H1900 ASSY-DOOR MIRROR COUPE
27 62845-78500 RUBBER-RADIATOR CORE SUPPORTSIDE (2) COUPE
